Configure roles and privileges
Legacy:
ArcGIS Enterprise Sites has been renamed ArcGIS Hub starting at the ArcGIS Enterprise 12.2 release.
The features and functions available in ArcGIS Hub depend on the user type, role, and privileges assigned to your account. A user type determines which default roles can be assigned to a member. Roles are comprised of privileges.
Learn more about user types, roles, and privileges
Members can create and manage content in Hub with the following roles: Administrator and Publisher (default).
All roles to create and manage content with Hub require the Creator user type.
Administrator
An administrator in Hub is basically the default Administrator role that is part of any organization, or a custom role with certain privileges. An administrator has full administrative access to ArcGIS Enterprise used by internal staff to create and manage content with Hub.
The Enterprise administrator can assign the default administrator role to other members. The Administrator can also create a custom role based on the Publisher role with certain administrative privileges, such as view all members, invite new members, create categories, change member roles, and manage security access for configuring enterprise logins.
Assign roles and create custom roles
Administrators can configure roles and privileges for members of the organization. Members who have a custom Administrator role that includes the View all (Members), Change roles (Members), and Member roles (Organization Settings) privileges can also assign roles and privileges. This includes assigning privileges to custom roles.
Assign a default or custom role
To assign a default role or configure a custom role for a member of an organization, ensure that you have the appropriate administrative privileges for the correct organization.
To configure a custom role, follow the steps under Configure member roles.
To assign a default or custom role to a member of your organization, follow the steps under Change member roles.
If you don't see the user to add, they may not be a member of the organization yet. Follow the steps provided in Add members to your portal to add the user to ArcGIS Enterprise.
