Migration from legacy distance functions to distortion-free distance functions
Significant improvements have been made to distance analysis, and new distance raster functions that have enhanced capabilities were made available. In addition, the results of the operations are now calculated with greater precision and accuracy.
Since there are improved raster functions available, the Distance (Legacy) raster functions are deprecated and will be removed in a future release. This topic identifies for each of these functions the function that replaces it.
Function organization and mapping
The new functions are as follows:
Function
Distance Accumulation
Calculates accumulated distance for each cell to sources, allowing for straight-line distance, cost distance, and true surface distance, as well as vertical and horizontal cost factors.
Distance Allocation
Calculates distance allocation for each cell to the provided sources based on straight-line distance, cost distance, and true surface distance, as well as vertical and horizontal cost factors.
Least Cost Corridor
Calculates the sum of two accumulative cost distance rasters with the option to apply a threshold based on percentage or accumulative cost.
Optimal Path As Raster
Calculates the optimal path from destinations to sources.
The following table shows the mapping between the Legacy Distance raster functions and the replacement functions that offer enhanced functionality and performance:
Legacy distance functions
New distortion-free distance functions
Corridor
Least Cost Corridor
Cost Allocation
Distance Allocation
Cost Back Link
Distance Accumulation with the Out back direction raster parameter specified
Cost Distance
Cost Path
Euclidean Allocation
Distance Allocation
Euclidean Back Direction
Euclidean Direction
Distance Accumulation with the Out source direction raster parameter specified
Euclidean Distance
Least Cost Path
Distance Accumulation and Optimal Path As Raster
Path Distance
Path Distance Allocation
Distance Allocation
Path Distance Back Link
