Configure your portal for Indoors
Available with the ArcGIS Indoors Maps extension.
An ArcGIS Enterprise portal administrator must import the license file for Indoors into your portal. You can then set permissions for members of your organization and certain functionality in ArcGIS Pro. Once you set permission levels for members and enable access to ArcGIS Pro functionality, they can access the Indoors geoprocessing tools in ArcGIS Pro after they successfully connect and sign in to your Enterprise portal.
Import the licenses for Indoors
The portal must be licensed for the ArcGIS Indoors Maps and ArcGIS Indoors Spaces organization extensions for the app to successfully connect to it.
ArcGIS Indoors Spaces allows you to share a web map for use in Floor Plan Editor for floor plan management and Indoors Space Planner for space management. ArcGIS Indoors Spaces also enables workspace reservation capabilities in Indoors Viewer and Indoors mobile. ArcGIS Indoors Spaces is an add-on to the ArcGIS Indoors Maps license; you cannot have ArcGIS Indoors Spaces without ArcGIS Indoors Maps.
If your organization licensed Indoors using the legacy Indoors organization extension, it is supported until the license expires.
To import the Indoors license file, complete the following steps:
  1. Import the license files into your portal.
  2. Ensure that the Indoors license files are listed as organizational extensions.
    1. Click the Organization tab and click Licenses.
    2. Click Organization extensions.
    3. Verify that the correct licenses are listed.
Set up access for ArcGIS Pro
To assign privileges to members of an organization that need access to ArcGIS Pro, complete the following steps:
  1. Assign the Professional Plus user type to named users in the organization that need access to ArcGIS Pro.
  2. Grant these named users access to the following extensions:
    1. 3D Analyst
    2. Network Analyst
  3. Assign these named users the Publisher role.
    Members of the organization that need access to ArcGIS Pro must sign in to the organization in ArcGIS Pro before using the ArcGIS Indoors geoprocessing tools.
Configure the security certificate
Your portal must have a valid Secure Sockets Layer (SSL) certificate from a trusted entity for Floor Plan Editor to run without warnings. Web browsers have built-in security features that prevent connection to servers that do not have a valid certificate.
If your organization uses self-signed or Enterprise CA certificates for Floor Plan Editor, you must add exceptions in some browsers to access the Floor Plan Editor URL. Use a trusted certificate signed by a certificate authority to avoid disruptions.
Configure the identity store
ArcGIS Enterprise allows you to use enterprise accounts and groups to control access to your ArcGIS organization. Use an organization-specific identity store to set policies for password expiration and complexity; control access using existing Active Directory, LDAP, or SAML groups; or use authentication.
Create users and assign roles and types
When you create users, review the type of users available for details about assigning roles and access.
You can change the user type for multiple members of an ArcGIS organization at the same time. For example, you can change the user type for many users to Contributor.
To access the Floor Plan Editor app, a user must be assigned the Contributor user type or higher.
To create the Floor Plan Editor app, create a plan, import PDF, CAD drawings, and BIM models, or upload images in the app, a user must have the privileges associated with the default role of Publisher or higher.
To upload images, a user must meet one of the following conditions: be the owner of the web map, or be a member of a group with shared update capability enabled to which the web map is shared.
To open, edit, and merge changes in plans, a user must have the privileges associated with the default role of Data Editor or higher.
