System requirements for Floor Plan Editor
Available for an ArcGIS organization licensed with the ArcGIS Indoors Spaces extension.
To use Indoors Floor Plan Editor, you need an ArcGIS Enterprise base deployment licensed for the ArcGIS Indoors Maps and ArcGIS Indoors Spaces extensions. Review the ArcGIS Enterprise help for system requirements and instructions on how to install and configure an Enterprise deployment.
To use Indoors Floor Plan Editor, an ArcGIS Online organization licensed for the ArcGIS Indoors Maps and ArcGIS Indoors Spaces extensions is required. Refer to the help to set up an ArcGIS Online organization for use with Indoors.
Required ArcGIS software
The following ArcGIS software is required for Floor Plan Editor on ArcGIS Enterprise:
ArcGIS Pro 3.0 or later
ArcGIS Server Standard
An ArcGIS Server Advanced license is required to import PDFs (beta), CAD drawings or BIM models.
Portal for ArcGIS 11.2 or later licensed for ArcGIS Indoors Maps and ArcGIS Indoors Spaces
The following ArcGIS software is required for Floor Plan Editor on ArcGIS Online:
An ArcGIS Online organization licensed for ArcGIS Indoors Maps and ArcGIS Indoors Spaces
You can optionally create a Floor Plan Editor app and floor plan data from the Indoors apps gallery without the use of ArcGIS Pro.
Required user types and roles
Certain permissions are required to interact with the Floor Plan Editor app. These requirements are summarized in the table below.
Action |
Required user type or role |
Access the Floor Plan Editor app |
Contributor user type or higher |
Create the Floor Plan Editor app |
Publisher default role or higher |
Create or edit a floor plan, or edit and merge changes in floor plans |
Data Editor default role or higher |
Import PDFs (beta), CAD drawings or BIM models |
Upload images |
Create floor plan image overlays |
To upload images, a user must meet one of the following conditions: be the owner of the web map, or be a member of a group with shared update capability enabled to which the web map is shared.
Action |
Create a floor plan or merge changes in floor plans |
Edit a floor plan or create floor plan image overlays |
Upload Images |
To upload images, you must either own the web map or be a member of a group with shared update capability to which the web map is shared.
Read more about configuring roles and permissions for Floor Plan Editor
Branch versioning
Branch versioning is required to share feature layers for use in Floor Plan Editor. Branch versioning is supported by geodatabases created in ArcGIS Pro 3.0 or later. The database platform you use must also support branch versioning.
Learn more about branch versioning data for use with Floor Plan Editor
Supported browsers and devices
This app supports all of the browsers that the Portal for ArcGIS supports.
This app supports all of the browsers that ArcGIS organizations in ArcGIS Online support.
Supported languages
This app supports all of the languages that the ArcGIS Enterprise supports.
This app supports all of the languages that the ArcGIS Online organization supports.
The language used by the app is determined by your browser's language setting.
