Create the Floor Plan Editor app
Available with the ArcGIS Indoors Spaces extension.
Indoors Floor Plan Editor is a browser-based app that allows you to modify floor plan data of indoor spaces to reflect real-world changes to your workplace. Floor Plan Editor is available in the Indoors apps gallery of your ArcGIS organization with the ArcGIS Indoors Spaces extension.
Before creating the Floor Plan Editor app, you must prepare a map for Floor Plan Editor and share the map to your organization. Alternatively, you can create an indoor map from the Indoors apps gallery.
Before creating the Floor Plan Editor app, you must prepare a map for Floor Plan Editor and share the map to your ArcGIS organization.
Once you create the Floor Plan Editor app, you can configure app settings for merge permissions and the automatic sign-out timer. You can use a custom object palette or the default palette and define wall features from the Details layer.
ArcGIS Enterprise 11.2 or later is required to create the Floor Plan Editor app.
Create the app from an existing web map
Once the Floor Plan Editor web map is prepared and shared from ArcGIS Pro, and the required layers and tables have been verified, create the Floor Plan Editor app from the Indoors apps gallery.
Caution:
If you added custom fields to the Indoors schema that include 64-bit ObjectID, Big integer, Date only, Time only, or Timestamp offset, you cannot use them with the sync capability, which is necessary for Floor Plan Editor functionality.
Learn more about compatibility between field types and the sync capability
To create the Floor Plan Editor app, complete the following steps:
Verify that you are signed in to your ArcGIS organization and have the necessary privileges to create content in ArcGIS Online.
Verify that you are signed in to your ArcGIS Enterprise organization and have the necessary privileges to create content.
Browse to the Indoors apps gallery page using one of the following methods:
Click Apps
in the header of the site to see the apps available to you, and click Indoors.On the My Content page, click Create app, and click Indoors.
On the item details page of the web map shared for Indoors, click Create Web App, and click Indoors.
Click Create on the Indoors Floor Plan Editor card.
Choose a map from the list of available web maps, and click Select Map.
To select from maps created by another member of your organization or maps shared with a group, click the My Content drop-down menu to change the selection of maps available.
Provide the title, tags, summary, and folder.
Click Create App.
Floor Plan Editor opens and the Configure App panel appears. You can use the default configuration or use the Configure App panel to configure the app and preview changes.
Create the app and web map
You can create a Floor Plan Editor app and web map from the Indoors apps gallery without the need to use ArcGIS Pro. This option creates the necessary layers that conform to the ArcGIS Indoors Information Model. After creating the app, you can use Floor Plan Editor to import PDFs, CAD drawings, or BIM models of floor plans, create floor plan image overlays, or create floor plans from scratch by tracing over an image.
To create a Floor Plan Editor and an associated indoor web map, complete the following steps:
Click Apps
Click New Indoor Map.
The Get Started window appears.
Choose an option for creating floor plan data:
Yes, I have a PDF file of my floor plan—Use an existing vector PDF to import floor plan data or a raster PDF to create a floor plan image overlay.
Yes, I have a CAD or BIM file of my floor plan—Use an existing CAD or BIM drawing to import floor plan data.
No, I need to create my floor plan from scratch—Draw a floor plan data manually or trace over an imported image.
Click Next.
Provide a title.
This title is shared by the created indoor web map and Floor Plan Editor app, and can be changed later.
Click Create.
The following items are created in the ArcGIS organization:
A feature layer containing the Occupants, Units, Details, Levels, Facilities, and Sites layers, and the Areas and Area Roles tables from the Indoors model
A web map with the provided title
A Floor Plan Editor app with the provided title
A blank floor plan, accessible with the created Floor Plan Editor app
You can update the sharing level for the created Floor Plan Editor app and associated items from the Indoors apps gallery.
Configure the Floor Plan Editor app
Use the Configure App panel to configure the following options in the Floor Plan Editor app:
App—Open the item details page for the current app item or web map. You can also restrict merge permissions and configure automatic sign-out timers.
Palette—Choose a custom palette or use the default palette for object placement.
Walls—Define features from the Details layer as walls based on the
USE_TYPEfield.
