Create and edit floor plans
Available with the ArcGIS Indoors Spaces extension.
With Indoors Floor Plan Editor, you can create floor plans and edit floor plan data to reflect real-world physical changes in the workplace.
To create, open, and edit floor plans, you must have privileges associated with the default Data Editor role or higher. To import PDF (beta), CAD, or BIM, and to upload images, you must have privileges associated with the default Publisher role or higher. If you're using a custom role, you must enable the Edit privilege for features in ArcGIS Enterprise to open and edit floor plans.
To create, open, edit floor plans, and create floor plan image overlays, you must have privileges associated with the default Data Editor role or higher. To import PDF (beta), CAD, or BIM, and to upload images, you must have privileges associated with the default Publisher role or higher. If using a custom role, you must enable the Edit privilege for features in ArcGIS Online to open and edit floor plans.
To upload images, a user must be the owner of the web map or the web map must be shared to a group with shared update capability enabled.
To upload images, you must be the owner of the web map or the web map must be shared to a group with shared update capability enabled.
You can keep new floor plans private or share them with your organization. You can also update the sharing level of existing floor plans at any time.
Create a floor plan
You can use Floor Plan Editor to make edits to existing floor plans, import PDFs (beta), CAD drawings, BIM models of floor plans, or create floor plans from scratch by tracing over an image. All updates are made in a plan, which is a working copy of the indoor data. You can review the updates made in a plan with others and merge them to the default plan to make the updates available in the indoor data shared to your organization.
You can use Floor Plan Editor to make edits to existing floor plans, import PDF files (beta), CAD drawings, BIM models of floor plans, select a page of a PDF and place an image overlay representation of the floor plan, or create floor plans from scratch by tracing over an image. All updates are made in a plan, which is a working copy of the indoor data. You can review the updates made in a plan with others and merge them to the default plan to make the updates available in the indoor data shared to your organization.
To create a plan in Floor Plan Editor, complete the following steps:
  1. Verify that you are signed in to your ArcGIS organization and have privileges to create content.
  2. Open the Floor Plan Editor app.
  3. Click New Plan.
    The Create Plan panel appears.
  4. In the Create Plan panel, provide a title for the plan.
  5. Choose the appropriate Share With option as follows:
    • Private—The plan is only visible to you.
    • Organization—The plan is visible to the organization.
  6. Click Create Plan.
To create a floor plan in Floor Plan Editor, complete the following steps:
  3. Click New Plan.
  5. Optionally, add tags and a summary describing the plan.
  6. Click the Save in Folder drop-down arrow, and choose the folder where you want to save the plan.
  7. Choose the appropriate Share With option as follows:
  8. Optionally, configure Group Sharing.
  9. If the floor plan data contains more than 200,000 features, do the following:
    1. Click Next.
    2. Choose a plan type as follows:
      • Blank Plan—Best for adding new facilities. No features are imported from the floor plan dataset.
      • Focused Plan—Best for working on a select number of facilities. Selected facilities and their associated features are imported from the floor plan dataset. When this plan type is selected, the Facilities drop-down menu appears with a list of facilities in the floor plan dataset. Select one or more facilities from the list to import their features.
      • Full Plan—Best for working on all indoors data. All features are imported from the floor plan dataset.
  10. Click Create Plan.
    Creating a plan can take up to a minute or longer if the floor plan data contains more than 100,000 features.
The new plan opens in Floor Plan Editor and is ready for floor plan editing.
Open an existing floor plan
In Floor Plan Editor, you can open floor plans created by others if the floor plan is shared with the organization.
After opening the Floor Plan Editor app, a list of available floor plans appears. You can open a floor plan from the list, or create a floor plan.
If you have trouble opening a floor plan, ensure that you have the necessary permissions. Contact your ArcGIS organization administrator to request access.
To delete a floor plan, click Delete next to the plan. You can only delete a floor plan if you created it, unless you are an administrator. Administrators can delete all plans. A plan cannot be deleted while it is open.
Tip:
Consider deleting floor plans that have been merged to manage file storage in your ArcGIS organization and lower storage credit costs.
Floor plan editing
After creating or opening a floor plan, you can access the navigation pane containing a variety of tools for editing floor plan data in a web browser.
Any saved changes to a floor plan exist only in that plan until you push them to the default floor plan.
The following functionality is available when editing floor plans:
  • Plan—Create, delete, open, and update sharing of plans.
  • Edit—Select a feature on the map, and access the editing tools by clicking Edit on the pop-up.
    Editing feature attachments is not supported.
  • Draw—Draw new units or walls, and set attributes.
  • Split units—Split a unit into two units and insert a wall where you want to split the unit. Available options for the new wall are determined by the configuration option that defines walls.
  • Add—Draw a new site, facility, or level and set its attributes.
  • Place—Place entryways, windows, floor transitions, and furniture from the palette.
  • Copy and paste—Copy and paste objects in the drawing.
  • Merge—Merge multiple Units or Details features into a single feature.
  • Manage plan—Push changes from the current plan to the default plan, or pull changes from the default plan to the current plan.
  • Import—Create floor plans by importing data from PDF files (beta), CAD drawings, or BIM models.
  • Overlay—Choose a page from a PDF to create an image representing the floor plan and overlay it on a level.
  • Split units—Split a unit into two units and insert a wall where you want to split the unit. The configuration option that defines walls determines the available options for the new wall.
  • Import—Create floor plans by importing data from PDF (beta), CAD drawings, or BIM models.
  • Grid—Customize the grid spacing, rotation, and placement.
  • Images—Add floor plan images and adjust their transparency to trace over while drawing features.
The accuracy of measurements and area calculations depends on the spatial reference of the web map.
Import PDF (beta)
You can import floor plans from PDFs. An ArcGIS Server Advanced license is required and you must have privileges associated with the default role of Publisher or higher to import PDFs (beta).
A PDF can have vector data, raster data, or both. PDFs with vector data, such as a PDF exported from CAD, store floor plan information in scalable graphics. PDFs with raster data store floor plan information in images using pixels. Floor Plan Editor supports PDFs with vector data, but not PDFs with raster data. If a PDF contains both vector and raster data, only the vector elements are imported. You can choose a specific page of a PDF to import when uploading the PDF.
Tip:
You can verify whether the floor plan on the chosen page of the uploaded PDF is vector or raster by zooming in using any PDF viewer. Sharp and clear lines indicate vector; pixelation indicates raster.
After a PDF loads, you can define the site, facility name, and the level information. Floor Plan Editor automatically detects doors and places them in the Details layer with the USE_TYPE populated as Door.
Floor Plan Editor automatically excludes text in the PDF. You can also draw a processing boundary around your floor plan to exclude content from importing, such as linework from text boxes, tables, PDF symbology, or architectural information. Floor Plan Editor imports anything completely inside the processing boundary. It does not import anything partially intersecting or outside of the processing boundary.
Import PDF files (beta)
You can import floor plans from PDF files. You must have the privileges associated with the default role of Publisher or higher to import PDF files.
A PDF can have vector data, raster data, or both. PDF files with vector data, such as PDF files exported from CAD, store floor plan information in scalable graphics. PDF files with raster data store floor plan information as images using pixels. Floor Plan Editor supports PDF files with vector data, but not PDF files with raster data. If a PDF contains both vector and raster data, only the vector elements are imported. You can choose a specific page of a PDF to import when uploading the PDF.
You can check if the floor plan on the selected page of the uploaded PDF is a vector or raster image by zooming in using any PDF viewer. Sharp and clear lines indicate a vector image; pixelation indicates a raster image. This is not applicable to all PDFs as some raster PDFs may not show pixelation. Upload the PDF in Floor Plan Editor to know if the file is supported.
After previewing a PDF, you can define the site, facility name, and level information. Floor Plan Editor automatically detects doors and places them in the Details layer as features with the USE_TYPE field populated with a value of Door.
Floor Plan Editor automatically excludes text in the PDF. You can also draw a processing boundary around a floor plan to exclude content from the import, such as line work from text boxes, tables, PDF symbology, or architectural information. Floor Plan Editor imports anything completely inside the processing boundary and does not import anything partially intersecting or outside of the processing boundary.
Import BIM models
You can import BIM models to create 2D floor plans. You must have privileges associated with the default role of Publisher or higher to import a BIM model. An ArcGIS Server Advanced license is required to import BIM models. Floor Plan Editor supports only BIM models from .rvt files; it does not support .ifc files.
Floor Plan Editor supports importing BIM models only for .rvt file versions 2021–2026.
After a BIM model loads, you can define the site, facility name, and the ground floor, and choose the floors to import from the model. You can also define the fields to use for the room name and room use type attributes.
You can import BIM models to create 2D floor plans. You must have privileges associated with the default role of Publisher or higher to import a BIM model. The option to import BIM models is available when you choose Full Plan. Only BIM models from .rvt files are supported; .ifc files are not supported.
Importing BIM models is supported only for .rvt file versions 2021-2026. Files larger than 350 MB are not supported. To help reduce file size, try purging unused objects in Revit.
After a BIM model finishes loading, you can define the site, facility name, and the ground floor, and select the floors to import from the model. You can also define the fields to use for the room name and room use type attributes.
Import CAD drawings
You can import CAD drawings to create floor plans. After a CAD drawing loads, you can define room boundaries and doors. You can also define lines that represent detail features such as walls, windows, stairs, and furniture. You must have privileges associated with the default role of Publisher or higher to import a CAD drawing. An ArcGIS Server Advanced license is required to import CAD drawings.
If the CAD drawing has not been prepared for use in ArcGIS Indoors, you can use ArcGIS Indoors for AutoCAD to prepare the drawing for import. Floor Plan Editor supports only CAD drawings from .dwg files; it does not support .dgn files.
You may have CAD drawings that have different spatial references depending on their geographic location. The imported floor plan data matches the spatial reference of the branch versioned feature layer that contains the Indoors data.
You can import CAD drawings to create floor plans. After a CAD drawing finishes loading, you can define room boundaries and doors. You can also define lines that represent detail features such as walls, windows, stairs, and furniture. The option to import CAD drawings is available when you choose Full Plan. You must have privileges associated with the default role of Publisher or higher to import a CAD drawing.
If the CAD drawing has not been prepared for use in ArcGIS Indoors, you can use ArcGIS Indoors for AutoCAD to prepare the drawing for import. Only CAD drawings from .dwg files are supported; .dgn files are not supported.
You may have CAD drawings that have different spatial references depending on their geographic location. The imported floor plan data matches the spatial reference of the hosted feature layer that contains the Indoors data.
Georeference a PDF (beta), CAD drawing, or BIM model using Floor Plan Editor
You can use Floor Plan Editor to georeference a PDF (beta), CAD drawing, or BIM model to place it in the correct geographic location. Georeferencing involves placing control points to set the geographic location of the building.
If you already have associated auxiliary files (.aux.xml), projection files (.prj), and world files (.wld3), you do not need to georeference the data.
To georeference a PDF, CAD drawing, or BIM model using the Floor Plan Editor app, complete the following steps:
  1. Upload the PDF (.pdf), CAD (.dwg), or BIM (.rvt) file.
  2. Click Align to map, and click Georeference.
    A split-screen view opens. One screen displays the data from the uploaded PDF, CAD, or BIM file. The other screen displays the map.
  3. Add the first control point in the PDF, CAD, or BIM preview on a corner of the level.
    Tip:
    You can snap to lines in the preview to help with placing a control point.
  4. Add a corresponding first point on the map that represents the same corner of the level chosen from the preview.
    Tip:
    You can search for an address using the Search tool on the map to find the facility you want to import floor plans for. If you are importing floor plans of the ground floor of a facility, you can use the basemap to identify the facility boundary, and use it to place the control points.
    Tip:
  5. Add a second control point in the preview on a different corner of the chosen level.
    Place the second control point on an opposite and diagonal corner for increased georeferencing accuracy.
  6. Add a second control point on the map matching the location of the level's second control point from the preview.
  7. Click Apply.
    You can click Undo to make corrections as needed.
The PDF, CAD, or BIM preview now appears on the map at the location specified by the control points and is ready to continue the import process.
Georeference a CAD drawing using ArcGIS for AutoCAD
To georeference a CAD drawing using ArcGIS for AutoCAD, complete the following steps:
  1. Download and install the ArcGIS for AutoCAD plug-in for Autodesk AutoCAD.
  2. Set the coordinate system for the CAD drawing.
  3. Save the CAD drawing.
You can use the CAD drawing to import floor plan data in Floor Plan Editor.
Georeference a PDF, CAD drawing, or BIM model using ArcGIS Pro
To georeference a PDF, CAD drawing, or BIM model using ArcGIS Pro, complete the following steps:
  1. Add the PDF, CAD drawing, or BIM model to a map in ArcGIS Pro.
  2. Georeference the PDF, CAD drawing, or BIM model.
  3. Save the transformation.
ArcGIS Pro creates associated auxiliary files (.aux.xml), projection files (.prj), and world files (.wld3) in the same folder location as the PDF, CAD drawing, or BIM model as part of the georeferencing process. When importing a PDF, CAD, or BIM data georeferenced using ArcGIS Pro, be sure to upload these associated .aux.xml, .prj, and .wld or .wld3 files with the PDF, CAD, or BIM file.
After georeferencing a PDF in ArcGIS Pro, do not apply or save rotation changes in a PDF viewer. Doing so alters the file content and invalidates the georeferencing, resulting in misalignment when the PDF is uploaded to Floor Plan Editor.
When uploading a PDF, CAD drawing, or BIM model georeferenced using ArcGIS Pro, you also upload the .pdf, .dwg, or .rvt file and the associated .aux.xml, .prj, and .wld or .wld3 files in a zip file as an item in your ArcGIS organization. After you upload the PDF, CAD, or BIM file, Floor Plan Editor generates a preview that you can edit before importing. You can open the saved preview again to continue making edits in a later session.
Caution:
Closing the browser window during the import process causes the import to fail, and uploaded items associated with the import process remain in the organization.
If you have a Sites layer in the map, you must draw a site before importing a PDF, CAD drawing, or BIM model to ensure that all facilities are accessible using the floor filter. The site can be a general boundary that contains the buildings planned for import. Some common site examples include a university campus or a hospital, which includes a large area containing multiple facilities.
After importing a PDF, CAD drawing, or BIM model in the current plan, use the Manage Plan panel to push your changes before importing other PDFs, CAD drawings, or BIM models to ensure your changes are committed.
Floor plan overlays
Floor plan overlays provide a way to display visual representations of floor plans, allowing the user to create an image of floor plans directly from a PDF file without the need to first import the floor plan data. For example, first responders may need quick access to building floor plans in a floor-aware map, and their workflows may not require Units representing rooms and spaces and Details representing doors, walls, and windows.
You can choose a page of a PDF to convert it into an image and overlay it on a level. After you choose a level, upload a PDF, and choose a page, the image overlay appears in the center of the map. You can move, resize, and adjust the transparency of the image to align it with the level. You can enable or disable Lock Aspect Ratio when resizing the image. You can also choose to keep the entire image, clip the image to match the level footprint, or draw a custom clipping shape.
The floor plan image overlay exists as an attachment on the Levels feature. If you have an existing Floor Plan Editor app, you can enable attachments on the Levels feature class in the enterprise geodatabase, and then overwrite the branch versioned feature service to support floor plan image overlays. The maximum PDF upload size is 100 MB. If you have a map with multi-facility mode set in the floor filter, Floor Plan Editor does not support showing floor plan overlays across the same vertical order.
The floor plan image overlay exists as an attachment on the Levels feature. If you have an existing Floor Plan Editor app, you can enable attachments on the Levels layer, and then create a new plan to start creating floor plan image overlays. If you have existing plans, make sure to push those changes into the default service before enabling attachments on the Levels layer to ensure your edits are not lost. The maximum PDF upload size is 100 MB. If you have a map with multi-facility mode set in the floor filter, Floor Plan Editor does not support showing floor plan overlays across the same vertical order.
Update floor plan symbology with feature templates
The indoor map used in Floor Plan Editor includes a set of values for different types of indoor spaces, such as Classroom, Restroom, and Kitchen, as well as a unique symbol color associated with each value. Assigning a symbol color to similar types of spaces can provide more visual context to the floor plan. You can create new values or modify existing values for indoor space types.
The symbology of the floor plan, specifically for Units and Details, is associated with the USE_TYPE attribute.
To update floor plan symbology with feature templates, complete the following steps:
  1. Sign in to your ArcGIS organization.
  2. Open the item page for the web map used in Floor Plan Editor.
  3. Click Open in Map Viewer.
    The Floor Plan Editor web map opens in Map Viewer.
  4. Select the Units or Details layer in the layer list.
    The Properties pane appears and displays the symbology settings of the layer.
  5. In the Symbology section, click Edit Layer Style.
    Editing the layer style of the web map and saving changes is only available to the owner of the feature layer or administrators of the organization.
    The Styles pane appears.
  6. Under Pick a style, click Types (unique symbols).
  7. Add all existing values by doing the following:
    1. Click Options next to the Other category.
    2. Click Select all Values.
    3. Click Move to group, and click Use Type.
      All unassigned values are added to the map symbology as use type values, and a random color is assigned to each new use type. You can change the color assigned to any use type value.
      Tip:
      To add a new value from scratch, click Options , and click Add value.
    4. Click Done.
  8. Update existing templates by doing the following:
    1. Click Configure Editing , and click Templates.
    2. If a warning appears for templates being out of sync with the layer's style, click Update in the warning message.
    3. Click OK.
  9. Save the web map.
  10. Create a new plan in Floor Plan Editor.
In the new plan, use types with an updated symbol color are visible in the map and available to use for creating and editing features.
Editing templates is not available for creating and editing features in plans created before the updates.
Credit usage
Creating a floor plan in Floor Plan Editor creates a copy of the indoor data in your organization content, which adds storage credit costs. Feature layer settings, such as Enable Sync and Keep track of created and updated features, can increase storage size and costs over time. For example, a plan with 100,000 features could be approximately 75 MB in size and consume approximately 18 credits for a given month.
Saving previews created while importing PDF (beta), CAD, or BIM files also consumes storage credits. Consider deleting previews that are no longer needed to lower storage credit costs.
Learn more about credits by capability
