Add required attributes to an indoor dataset
Available with the ArcGIS Indoors Spaces extension.
An Indoors geodatabase, created using the Create Indoors Geodatabase tool, contains all of the feature classes, fields, and tables required for indoor space planning.
If you created an indoor dataset using the Create Indoor Dataset tool, you must add the following items to the dataset before you can use it with the Space Planner app:
A coded value domain that describes the types of assignable spaces in the Units feature class
Additional attribute fields in the Units feature class
The Areas table
Create coded value domains
To create the required coded value domain that describes the types of assignable spaces in the Units feature class, complete the following steps:
If you are using an Indoors geodatabase that was created using the Create Indoors Database tool, the coded domain described below already exists so you do not need to create it.
Open the ArcGIS Pro project that contains the indoor dataset.
Right-click the Units feature class in the Catalog pane and click Data Design > Domains.
The Domains view appears.
Click New Domain
on the Domains tab.A row is created in the Domains view, and the pointer is positioned in the Domain Name column of this row.
Configure the new domain as follows:
Name—Type DOM_ASSIGNMENT_TYPE.
Description—Leave this blank.
Field Type—Text
Domain Type—Coded Value Domain
Split Policy—Use the default value.
Merge Policy—Use the default value.
In the grid by the Domains view, type the following codes and descriptions:
Code
hotdesk
Hot Desk
hotel
Hotel
none
None
not assignable
Not Assignable
office
Office
Click Save
to save the new coded domain.Create another coded domain as follows:
Name—DOM_AREA_TYPE
Description— Leave this blank
Field Type— Text
Domain Type— Coded Value Domain
Split Policy— Default
Merge Policy—Default
Code
hotdesk
Hot Desk
hotel
Hotel
Name—DOM_RESTRICTED
Field Type— Long
Code
Unrestricted
Restrict bookings to assigned occupants
Add required attributes to the Units feature class
To use the Units feature class for space assignment in the Space Planner app, add fields for area ID and assignment type, and add global IDs, complete the following steps:
If you are using an Indoors geodatabase created using the Create Indoors Database tool, the attributes listed below already exist so you do not need to create them.
Open the ArcGIS Pro project that contains the indoor dataset and the coded domain that you created in the previous section.
In the Catalog pane, right-click the Units feature class and click Design > Fields.
The Fields view appears.
Click New Field on the Fields tab or click Click here to add a new field in the last row in the view.
The pointer is positioned in the Field Name column.
Configure the new attribute as follows:
Field Name—Type AREA_ID.
Alias—Type Area ID.
Data Type—Text
Allow NULL—Checked
Domain—None
Default—Leave this blank.
Length—Type 255.
Add another field and configure it as follows:
Field Name—Type ASSIGNMENT_TYPE.
Alias—Type Assignment Type.
Data Type—Text
Allow NULL—Checked
Domain—Type DOM_ASSIGNMENT_TYPE.
Length—Type 255.
Click Save
.In the Catalog pane, right-click the Units feature class and click Manage > Add Global IDs.
Global IDs are created for features in the Units feature class and a
GlobalIDfield is appended to the attribute table.
The Units feature class contains the necessary attributes for use with the Space Planner app.
Add the Areas table to the indoor dataset
To create workspace areas in the Space Planner app, the indoor dataset must contain the Areas table.
In the Catalog pane, right-click the geodatabase that contains the indoor dataset and click New > Table.
The Define view of the Create Table pane appears.
For the Name parameter, type AREAS.
For the Alias parameter, type Areas.
Click Next.
Create fields for the Areas table with the following field property configurations:
Alias—Type Area ID.
Data Type—Text
Allow Null—Checked
Length—Type 255.
Field Name—Type AREA_NAME.
Alias—Type Area Name.
Data Type—Text
Allow Null—Checked
Length—Type 255.
Field Name—Type AREA_TYPE.
Alias—Type Area Type.
Data Type—Text
Allow Null—Checked
Domain—Type DOM_AREA_TYPE.
Length—Type 255.
Field Name— RESTRICTED
Alias— Restricted
Data Type— Long
Allow Null—Checked
Domain—DOM_RESTRICTED
Length— 255
Optionally, create additional fields in the Areas table with the following field property configurations:
If included, the
SCHEDULE_EMAILfield is used to facilitate booking spaces in the Indoors web and mobile apps.Field Name—Type SCHEDULE_EMAIL.
Alias—Type Schedule Email.
Data Type—Text
Allow Null—Checked
Length—Type 255.
If included, the
CAPACITYfield is used to provide details to aid in space planning in the Indoors web and mobile apps.Field Name—Type CAPACITY.
Alias—Type Capacity.
Data Type—Short
Allow Null—Checked
Click Finish to create the Areas table.
In the Catalog pane, right-click the Areas table and click Manage > Add Global IDs.
A
GlobalIDfield is appended to the Areas table.
You can now prepare a Space Planner map for ArcGIS Online.
