Prepare a map for use in Space Planner
Available for an ArcGIS organization licensed with the ArcGIS Indoors Spaces extension.
Sharing a Space Planner web map to ArcGIS Online requires sharing web maps to support visualization and space planning management workflows.
Before you prepare a Space Planner map and share it to your ArcGIS organization for use in the Space Planner app, you must create data that conforms to the ArcGIS Indoors Information Model. This involves creating an Indoors database and loading data using geoprocessing tools in the Indoors toolbox.
The Indoors geodatabase created using the Create Indoors Database tool contains the required fields, attributes, and domains for Space Planner. If you are using an Indoors geodatabase created using a previous version of ArcGIS Pro, you can use the Upgrade Indoors Database tool to update the geodatabase schema with the most recent Indoors model schema for your version of ArcGIS Pro. This includes the feature classes, tables, fields, and domains required for space planning and workspace reservations with the Indoors apps. If you created an indoor dataset using the Create Indoor Dataset tool, you can also use the Upgrade Indoors Database tool to upgrade the workspace with additional Indoors model schema items required for full functionality of space planning and workspace reservations in the Indoors apps.
Required layers
Web maps used in Space Planner must have the following feature classes and stand-alone table populated in the Indoors geodatabase:
Occupants—Corresponds to the Occupants feature class in the Indoors model. This feature class is created when you use the Create Indoors Database tool in ArcGIS Pro and populated using the Update Occupant Features tool.
Units—Corresponds to the Units feature class in the Indoors model.
- If you plan to use the workspace reservation function in Indoors Viewer, the Units layer must contain populated
USE_TYPEfields.
Levels—Corresponds to the Levels feature class in the Indoors model.
Facilities—Corresponds to the Facilities feature class in the Indoors model.
Areas table—Corresponds to the stand-alone Areas table in the Indoors model. If you are using an indoor dataset created using the Create Indoor Dataset tool, you must create the Areas table.
If you're sharing to an ArcGIS Enterprise organization, enable branch versioning in the enterprise geodatabase connection before loading data from the connection to the map.
Learn more about loading data into the Indoors geodatabase
Calculate Assignment Type field values
You can precalculate the ASSIGNMENT_TYPE field values for features in the Units layer to use in the Space Planner app. You can do this manually or by calculating fields using tools in ArcGIS Pro. You can also define the assignment type for units features later in the app.
For example, you can set the ASSIGNMENT_TYPE field values for Units features to fast track your planning in the Space Planner app as follows:
None—Spaces that have no occupant or unit assignment
Not Assignable—Spaces that should not be used for space assignment and planning, such as kitchens, restrooms, storage rooms, and circulation areas
Office—Spaces that are assigned to occupants
Hot Desk—Spaces available for short-term use that are not intended for individual assignment
Hotel—Spaces available for booking
Meeting Room—Conference or collaboration spaces available for booking
If a unit is configured as Not Assignable, you can enable assignments for the unit in Space Planner to assign an occupant to the unit or assign the unit as a hot desk, office hotel, or meeting room in a workspace area.
The following is a sample workflow to set the ASSIGNMENT_TYPE field value of Office for units that are assigned to employees:
Open the Space Planner map in ArcGIS Pro.
Right-click the Units layer in the Contents pane and click Joins and Relates > Add Join.
Choose Units from the Input Table drop-down list.
Choose UNIT_ID from the Input Join Field drop-down list.
Choose Occupants from the Join Table drop-down list.
Choose UNIT_ID from the Join Table Field drop-down list.
Click OK to create the join.
On the Map tab in the Selection group, click Select by Attributes.
The Select by Attributes pane appears.
For Input Rows, choose the units layer.
For Selection type, choose New selection.
Click New Expression and choose values from the drop-down menus to construct the following clause:
UNIT_ID IS NOT NULL.Click OK.
All the units with occupants assigned to them are selected in the map.
Use the Calculate Field tool to set the
ASSIGNMENT_TYPEfield value for the selected units to office.Caution:
Check the Enforce Domains check box before running the tool to ensure that your updates conform to the field's associated coded domain. If the field value does not match one of the values in the coded domain, it can cause errors in map symbology and app functionality.
These units features include an Office designation on their info card in the Space Planner app.
Optional layers
You can include additional layers in a map, such as the Area Roles table to enable reservation management capabilities or feature layers for enhanced visualization in the app.
Add the Area Roles table
When configuring workspace areas in Space Planner, you can assign one or more reservation managers if you include the Area Roles table and are using the Reservations layer. Reservation managers can book hotels and meeting rooms on behalf of other occupants, and manage bookings for others in the Viewer and Indoors Mobile apps. The Area Roles table must be shared as part of the same feature service as the Occupants and Units layers and the Areas table.
The Area Roles table is created when you use the Create Indoors Database tool in ArcGIS Pro 3.0 and later. If you have an Indoors geodatabase created in an earlier version of ArcGIS Pro, you can use the Upgrade Indoors Database tool to update the Indoors database schema with the latest Indoors model schema for your version of ArcGIS Pro and create any missing feature classes and tables, including the Area Roles table.
Add layers for visualization
You can add the Details layer to a Space Planner map to enhance visualization. This layer describes your facility's linear asset footprint and includes features such as walls, doors, and columns.
You can include additional layers for features in Space Planner to help visualize spaces and assist with space assignments. For example, you can add layers for exits, events, or zones.
Caution:
Be careful when including map layers derived from the required layers for Space Planner. For example, the ASSIGNMENT_TYPE field should only be present in the Units layer, and the AREA_ID field should only be present in the Units and Occupants layers. Ensure that layers derived from the Units and Occupants layers do not include these fields, or the Space Planner app may not load the map properly.
Prepare a Space Planner map to share to ArcGIS Enterprise
When preparing the Space Planner map in ArcGIS Pro to share to your ArcGIS Enterprise organization, you must set up the ArcGIS Indoors workspace in an enterprise geodatabase with branch versioning enabled in the database connection.
In ArcGIS Pro, you must register the following datasets as versioned:
Occupants
Units
Areas
Tip:
To protect the default version from accidental edits, you can modify version properties.
After creating the Space Planner map in ArcGIS Pro, share it with your ArcGIS Enterprise organization and use it in a Space Planner app.
Tip:
You can use the Space Planner map templates included in the product data to prepare a map for Space Planner. You can update the source of layers in the map template to point to the corresponding layers in your Indoors workspace and share the map with your organization for use in Space Planner.
Create a Space Planner web map
To create and prepare the versioned Space Planner feature layer for use in the Space Planner web map, complete the following steps:
Start ArcGIS Pro.
Sign in to your ArcGIS Enterprise organization if necessary.
Open the project that contains a connection to the Indoors geodatabase.
The database connection must be registered as versioned and have the branch versioning option checked.
Click the Insert tab and click New Map
to create a map if necessary.Add the layers listed in the following table and set the corresponding recommended visibility:
Filters that impact the Occupants layer must be applied to the map service or feature service before you share the web map.
Layer
Required
Recommended layer visibility
Occupants
Yes
On
Units
Yes
On
Areas
Yes
Not applicable (stand-alone table)
Area Roles
No
You must register the Areas and Area Roles tables and the dataset that contains the Occupants and Units feature classes as branch versioned.
Layer
Required
<Category source> layers
No
Off
Details
No
On
Levels
Yes
On
Facilities
Yes
On
The database connection for these layers does not need to be registered as versioned. You can use the same connection that you used for the Units and Occupants feature classes, but it is not required.
Set the visible scale range of the layers as necessary.
Set the symbology properties for the following layers:
Details
Set the symbology according to the
USE_TYPEattribute.Units
ASSIGNMENT_TYPEattribute.Occupants
Use an empty point symbol (no color or outline, and size 1).
Use caution when applying symbols for feature layers that have dense coverage. For example, offices, which are stored in the Units layer, are symbolized by the color of the unit polygon and shouldn't have individual point symbols.
Turn on labeling for the Units layer (
NAMEattribute), the Occupants layer (KNOWNASattribute), and any other features that you want labeled in the Space Planner app.You can configure labels so that occupied office units display the occupant's name and unoccupied offices display the unit's name to visually identify which offices are vacant or available to assign in the app. To hide the unit name label for occupied offices, configure labels for the Units layer as follows:
Right-click the Units layer in the Contents pane and click Labeling Properties.
The Label Class pane appears.
Click the SQL query tab
and click New expression.The expression builder appears.
Click the SQL toggle button.
The SQL text box appears.
Type the following expression in the SQL text box:
ASSIGNMENT_TYPE <> 'office'Click Apply.
Optionally, if occupant labels overlap the labels for adjacent units, you can use an Arcade expression to stack the occupant labels.
Right-click the Occupants layer in the Contents pane and click Labeling Properties.
Click the Label expression tab
if necessary.Replace the expression in the Expression text box with the following Arcade expression:
Replace($feature.KNOWNAS, ' ', TextFormatting.NewLine)Click Apply.
Set the display field in the layer properties for the Occupants layer to KNOWNAS and all other map layers to NAME.
The Space Planner app uses the display field value for labeling certain items in the app, such as the info card title. Setting this in ArcGIS Pro helps avoid confusion for app users.
Enable pop-ups for the Occupants and Units layers and any other layers that you want to identify on the map.
Configuring pop-ups enables interaction with features in the Space Planner app. These pop-ups determine what is displayed on the info cards for occupants and units features.
Not all number formats in ArcGIS Pro are supported in the web apps.
Ensure that the map has a coordinate system set for Current XY, such as WGS 1984 Web Mercator (Auxiliary Sphere).
Geographic and projected coordinate systems are supported in Space Planner.
Rename the map to make it easily identifiable and complete all metadata fields.
Set the display extent of the map to display all of the map data.
Add any Esri-hosted basemaps or custom basemaps to the map.
Configure a basemap to use either an Esri-hosted basemap or a custom vector tile package basemap.
Clear all feature selections.
You can now configure and share the web map for use in Space Planner. This includes first sharing a branch versioned feature layer that includes the Units and Occupants feature classes and the Areas table, updating the data source for these items in the map in ArcGIS Pro, and sharing the web map for use in Space Planner.
If you have an existing map symbolized by assignment types, you can update it based on new assignment types in the Indoors model.
Prepare a Space Planner map to share to ArcGIS Online
To prepare a map in ArcGIS Pro to share to ArcGIS Online for use in Space Planner, you can create a single map and add all the necessary layers to the map. You can then share it to ArcGIS Online. The Space Planner web map must contain all the layers required by Space Planner.
Tip:
You can use the Space Planner map templates included in the product data to prepare a map for Space Planner. You can update the source of layers in the map template to point to the corresponding layers in your Indoors workspace and share the map to your organization for use in Space Planner.
To create and prepare a map for use in Space Planner, complete the following steps:
Start ArcGIS Pro.
Sign in to your ArcGIS Online account, if necessary.
Create a project and add a connection to the Indoors geodatabase or open an existing project that contains the Indoors geodatabase.
to create a map if necessary.Add the required layers listed in the following table, along with any optional layers, and set the corresponding visibility:
Layer
Required
Visibility
Events
No
Off
Occupants
Yes
On
Details
No
On
Units
Yes
On
Levels
Yes
On
Facilities
Yes
On
Areas
Yes
Area Roles
No
Configure the map and additional layers as floor-aware.
Maps that aren't floor-aware are not supported in the Space Planner app.
You must apply filters that impact the Occupants layer to the map service or feature service before you share the web map.
Optionally, use the floor filter to specify Single Facility or Multi Facility filtering mode as follows:
Single Facility—Display a different floor level for the selected facility when using the floor filter. Other facilities continue to display the ground floor.
Multi Facility—Display the same floor level for all facilities when using the floor filter. If a facility does not have a matching vertical order, no floor is displayed for that facility.
The selected floor filtering option is honored in Indoors web apps when the web map is shared.
The option to select Single Facility or Multi Facility filtering is available in ArcGIS Pro 3.5 or later.
Details
NAMEattribute) and the Occupants layer (KNOWNASattribute).You can configure labels so that occupied office units display the occupant's name and unoccupied offices display the unit's name to visually identify which offices are vacant or available to assign in the app. To hide the unit name label for occupied offices, configure labels for the Units layer as follows:
Set the display field in the layer properties for the Occupants layer, if present, to
KNOWNASand all other map layers toNAME.Note:
The Space Planner app uses the display field value for labeling certain items in the app, such as the info card title. Setting this in ArcGIS Pro can help avoid confusion for app users.
Configure pop-ups for any layers you want to identify on the map.
Configuring pop-ups enables interaction with features in the Space Planner app. How you configure the pop-ups determines what appears on the info cards for occupant and unit features.
Optionally, rename the map to make it easily identifiable, and complete all metadata fields.
Configure a basemap
A basemap is an essential component of an indoor map that provides context and perspective for nearby features. When selecting a basemap, consider the scale of the map. Unlike image tile basemaps, vector tile basemaps are smaller in size and support higher levels of detail.
The following workflows outline the necessary steps to configure a basemap for Indoors.
Use an Esri-hosted basemap
In ArcGIS Pro, you can add basemaps from the Basemap gallery in the Layer group on the Map tab. Depending on your active ArcGIS organization's configuration, the gallery may include default Esri basemaps, maps shared to your organization's basemap gallery group, and basemaps added to a project in ArcGIS Pro.
To add Esri vector basemaps to a map, complete the following steps:
Copy the URL for the vector basemap you want to add.
Click the Add Data drop-down arrow in the Layer group.
Choose the Data From Path option.
The Add Data From Path dialog box appears.
Paste the URL.
Click Add.
Use a custom basemap hosted on your organization
To use a custom basemap hosted on your ArcGIS organization, complete the following steps:
Author a custom basemap.
Create a vector tile package using the Create Vector Tile Package tool.
When running the Create Vector Tile Package tool, make the following adjustments to support an indoor level of detail and scale the tile down by a factor of 17:
Uncheck the Package for ArcGIS Online | Bing Maps | Google Maps check box.
Choose the
VectorBasemapTilingScheme.xmlfile included in the Indoors symbology resources for the Tiling scheme parameter.
Share the vector tile package to your ArcGIS organization.
Sign in to your ArcGIS Enterprise organization in a browser and publish the vector tile package as a hosted layer.
Sign in to your ArcGIS Online organization in a browser and publish the vector tile package as a hosted layer.
Add the ArcGIS organization items to the map in ArcGIS Pro.
Tip:
Alternatively, if you have a hosted tile layer, click the Add Data drop-down arrow in the Layer group and click Data From Path to specify the URL to the hosted tile layer.
