Edit attributes
Available with the ArcGIS Indoors Spaces extension.
You can edit attributes for units and occupants from the Allocate and Assign tabs of Indoors Space Planner. For example, you can set whether a unit is assignable, modify the use type or capacity of a unit, or update an occupant's name or contact information.
Editing feature attachments is not supported.
To make fields in the units and occupants layers editable in Space Planner, ensure that the Read Only field property is turned off in ArcGIS Pro before sharing the web map to your ArcGIS organization. Attribute fields that are set as read-only in the web map are not available for editing in the app.
Caution:
The following new field data types are available in ArcGIS Pro 3.2: date only, time only, timestamp offset, big integer, and 64-bit object IDs. Although you can publish these data types to an ArcGIS organization, some client apps may not fully support these field types and are subject to change.
Some attributes are not editable by default in Space Planner. For example, you cannot edit managed fields, such as ObjectID, Shape_Area, Shape_Length, GlobalID, and editor tracking fields in the app. The following fields are managed by Space Planner if they are present and cannot be edited in the app, even if editing is available in the web map:
  • Units—ASSIGNMENT_TYPE, AREA_ID, NAME, NAME_LONG, UNIT_ID, and LEVEL_ID.
  • Occupants— UNIT_ID, LEVEL_ID, and SITE_ID.
Edits made on the Properties tab only affect the current plan. Once you have made all the necessary edits, you can merge the updated attributes with your organization’s default space plan.
Space Planner resolves conflicts in edited attributes by honoring edits in the most recently merged space plan. For example, if a unit is assigned to a workspace area in one plan and merged, and the same unit is made unassignable in a second plan and merged, the app updates the unit as unassignable and unassigns it from the workspace area.
In ArcGIS Online, you can also save updated attributes for units and occupants to a new plan using the Save As option.
You must have privileges associated with the default role of Data Editor or higher to make changes to a plan. If you’re using a custom role, the Edit features privilege must be enabled to open and edit plans.
Edit unit attributes
You can edit a unit's attributes or make a unit unassignable to change the way it is used for space planning.
Enable or disable assignments
To make a unit unassignable, complete the following steps on a unit’s info card to disable assignments to that unit:
  1. Click a unit feature on the map.
    The unit’s info card appears.
    Tip:
    You can also access a unit’s info card by clicking the unit in either Units list.
  2. Ensure that the Assignments tab on the info card is the active tab.
  3. Click the Assignment Settings button and click Disable Assignments.
    If the unit has no assignments, it can no longer be assigned. If the unit has assignments, the Disable Assignments dialog box appears and lists any occupants, office hotels, or workspace areas that will be unassigned from the unit.
  4. If there were assignments, click Unassign to confirm.
The unit no longer appears in the Assigned or Unassigned units lists. If any occupants were unassigned from the unit and they have multiple assignments, their other associated assignments are also updated.
Tip:
To revert the changes to the occupant's attribute, click Undo . This restores any other assignments that were associated with the unit.
You can also re-enable assignments from the Assignments tab of the unit's info card.
To edit a unit’s attributes, complete the following steps on a unit’s info card:
  1. Click a unit on the map.
    Tip:
  2. Ensure that the Properties tab is the active tab on the info card.
  3. Click Edit.
    The dialog box for the unit appears and lists the unit’s editable attributes.
  4. Edit the attributes as necessary.
    Editable fields are restricted to allowable values based on the field's properties in the web map, for example, domain values or attribute values of the correct data type.
    The following fields are managed by Space Planner if they are present in the Units layer and cannot be edited in the app, even if editing is available in the web map: ASSIGNMENT_TYPE, AREA_ID, NAME, NAME_LONG, UNIT_ID, and LEVEL_ID.
  5. Optionally, click the Add button to add a value to the Use Type drop-down list.
    You can also choose an existing field value from the drop-down list.
  6. Optionally, click an equipment's drop-down arrow and change the value to Yes for it to appear as a filter option in the Viewer and mobile app equipment filter.
    The equipment options that appear here are configured in ArcGIS Pro.
  7. Click Update.
Updates are incorporated in the current plan. Merge the plan with your organization's default space plan to make updates available to other app users.
Edit occupant attributes
You can edit an occupant’s attributes to update their information and facilitate facility planning. You can add custom attributes to the Occupants layer, such as comments or notes, and configure the fields as editable in the web map.
To edit attributes in Space Planner, complete the following steps:
  1. Click an occupant on the map.
    Tip:
    You can also access an occupant’s info card by clicking the occupant in the Assignments list or in the People list in the Not Assigned section.
    The occupant’s info card appears.
  3. Click Edit.
    The Edit occupant dialog box appears and lists the occupant’s editable attributes.
    Updates you make to any of the attributes are reflected in all records for the occupant.
    The following fields are managed by Space Planner if they are present in the Occupants layer and cannot be edited in the app, even if editing is available in the web map: UNIT_ID, LEVEL_ID, and SITE_ID.
  5. Click Update.
Tip:
To revert the changes to an occupant's attribute back to its original state, click Undo .
