Create the Space Planner app
Available with the ArcGIS Indoors Spaces extension.
Indoors Space Planner is available in the Indoors apps gallery of your ArcGIS organization with the ArcGIS Indoors Spaces extension.
Before creating the Space Planner app, you must prepare a map for Space Planner in ArcGIS Pro and share the map to your ArcGIS organization.
After you create the Space Planner app, you can configure app settings for merge permissions and the automatic sign-out timer. You can also create floor plans and configure workspace areas.
Create the app
After the Space Planner web map is configured and the required layers and tables have been verified, create the Space Planner app from the Indoors apps gallery.
To create the Space Planner app, complete the following steps:
Verify that you are signed in to your ArcGIS Enterprise organization and have the necessary privileges to create content.
Verify that you are signed in to your ArcGIS organization and have the necessary privileges to create content in ArcGIS Online.
Browse to the Indoors apps gallery page using one of the following methods:
Click Apps
in the header of the site to see the apps available to you, and click Indoors.On the My Content page, click Create app, and click Indoors.
On the item details page of the web map shared for Indoors, click Create Web App, and click Indoors.
Click Create on the Indoors Space Planner card.
Choose a map from the list of available web maps, and click Select Map.
To select from maps created by another member of your organization or maps shared with a group, click the My Content drop-down menu to change the selection of maps available.
Provide the title, tags, summary, and folder.
Click Create App.
You must choose a Space Planner web map to configure the Space Planner app. The Space Planner app is created using the Space Planner web map as the source and the chosen options in the active Configure App panel. You can switch to a different Space Planner web map in the Configure App panel and make configuration changes, such as setting merge permissions or configuring automatic sign out.
Tip:
At any point during the configuration process, you can do one of the following:
Click Save to save the recent updates.
Click Save As to save a copy of the existing app configuration.
Click Close
at the top of the Configure App panel to close it. If you have unsaved changes, you will be prompted to discard them.
Alternatively, you can close the Configure App panel and start creating plans on the specified map.
Restrict plan merging to a group
You can restrict the ability to merge plans to a specific group of people in your ArcGIS organization.
In ArcGIS Enterprise, anyone who has access to the plan and is assigned the Default Editor role or higher editing privileges can make changes to plans and merge them.
If merging is not restricted, you can only merge changes for plans you create.
Only one group can be chosen to restrict the ability to merge plans. Configure the group settings so it is only visible to group members and members can only join the group by invitation.
To restrict the ability to merge plans to a group, complete the following steps:
Create a group in your ArcGIS organization that contains members that you want to allow to merge plans.
Browse to the Space Planner app and click the app title.
The app's item details page appears.
Click Configure.
The Space Planner app opens with the Configure App panel displayed.
Turn on the Restrict merging capability to authorized users only toggle button in the Space Planner Merge section.
The Select authorized groups drop-down menu appears.
Click the Select authorized groups drop-down arrow and choose the group you created.
Click Save.
A confirmation message appears, confirming that the configuration options were saved.
Tip:
Click Close
Configure automatic sign out
You can configure Space Planner to automatically sign out users after a period of inactivity. This can help prevent unauthorized access to corporate floor plans and other related indoor information by people who have access to staff computers when staff are away.
To configure automatic sign out, complete the following steps:
Ensure that changes are saved in the Configure App panel before closing it.
Click Configure.
Turn on the Enable Auto-Sign out for app inactivity toggle button in the App Auto-Sign out section.
The Idle Time (seconds) and Popup Time (seconds) parameters are turned on.
Specify a duration for the Idle Time (seconds) parameter.
This is the time in seconds that the app can be left idle before displaying a pop-up to determine whether the app is still in use.
Specify a duration for the Popup Time (seconds) parameter.
This is the time in seconds that the pop-up appears before anyone who is signed in is automatically signed out. The duration is included in the pop-up and counts down.
Click Save.
Tip:
Click Close
Configure list filters
You can configure the fields used to filter the Assignments, Unassigned People, Units, and Unassigned Units lists in the app.
To configure list filters, complete the following steps:
Click Configure.
Click Next
in the Configure App panel to access the filters section.Review the list of fields used to filter data for Assignments, Unassigned People, Units, and Unassigned Units. You can select which fields are available for filtering and reorder the fields based on your organization's preference by clicking Select.
The following fields are on by default:
Filter (Assignments)—Site, Facility, Level, Assigned To, Department, Job Title, Team
Filter (Unassigned People)—Site, Department, Job Title, Team
Filter (Units)—Site, Facility, Level
Filter (Unassigned Units)—Site, Facility, Level
Fields can be filtered differently based on their data type:
Field type
Filter by
Number
A single value or a range of values. You can define the range by setting a minimum value, a maximum value, or both.
Date
A single date or a range of dates. You can define the range by setting a minimum value, a maximum value, or both.
String
A single field value.
Coded value
Geometry fields, such as the
Shapefield, and editor tracking fields cannot be set as filters.Click Save.
Tip:
Click Close
Display a configured unit name
You can configure how the unit name appears throughout the app. For example, you can display a unit's long name if some units have identical short names. The third breadcrumb in the Configure App panel contains the configuration option.
To configure a unit's name, complete the following steps:
Click Configure.
Click Next
in the Configure App panel to access the Unit Name section.In the Unit Name section, click the drop-down arrow to review the fields you can use to configure the unit's name throughout the app.
The options in the drop-down menu include text fields from the Units feature class.
Click Save.
Tip:
Click Close
Configure workspace areas
You can configure workspace areas to enable booking capabilities for the types of units that are relevant to your organization. For example, if your organization plans to manage only office hotels using Space Planner and does not need to do the same for hot desks or meeting rooms, you can create a workspace area that includes only office hotels.
To configure workspace areas in Space Planner, complete the following steps:
Click Configure.
Click Next
in the Configure App panel to access the Workspace Areas section.In the Workspace Areas section, ensure that the check boxes for the types of units that your organization manages are checked:
Hot Desks
Office Hotels
Meeting Rooms
If office hotel or meeting room types are enabled, choose either Microsoft 365 or the Reservations layer as the reservation method for each.
The Microsoft 365 or Reservations layer option is for use in Space Planner. Ensure that the same option is selected for configuring workspace reservations in Indoors Viewer.
Click Save.
Tip:
Click Close
You can create workspace areas in plans based on the selected configuration and assign units and occupants to them.
Configure organization areas
You can enable organization areas to help with space allocation across an organization. Spaces can be allocated to different organization areas or reallocated to other organization areas based on changing business needs, or when undergoing restructuring. Allocating spaces to organization areas also facilitates workspace area planning by giving space planners insight into which units are available for assignment. For example, you can allocate units for Human Resources so that the organization area has enough units to assign to staff and meet their occupancy needs.
Configure restricted allocation
You can enable restricted allocations to limit area planning to a specific group of people in your ArcGIS organization. When enabled, only members of the selected group have the ability to do organization area planning. Users who are not members of the group cannot see the Allocate tab.
Configure restricted organization area assignments
You can restrict the ability to make unit and occupant assignments to one or more designated area managers for organization areas. Area managers can be designated when creating an organization area, or at any time in the settings for an existing organization area.
Configure shared allocation
You can enable shared allocation to allow allocating common spaces to more than one organization area. For example, a classroom or laboratory shared between chemistry and biology classes at a university, or a conference room shared by sales, marketing, and accounting departments in a corporate office.
