Create the Indoors Viewer app
Available with the ArcGIS Indoors Maps extension.
Indoors Viewer is available in the Indoors apps gallery of your ArcGIS organization with the ArcGIS Indoors Maps extension.
Before creating the Viewer app, you must prepare a map for Viewer in ArcGIS Pro and share the map to your organization.
Once you create the Viewer app, you can configure app settings, a 2D Indoors web map, and an optional 3D Indoors web scene. You can also configure a route service, a closest facility service, app launch actions, a scale bar, a print layout template, indoor positioning, hotel booking, kiosk automatic reset, a virtual keyboard for kiosk mode, a logo, and a theme.
Some options, such as routing and printing, may not be available if there is no access to the supporting services.
Create the app
Once the Viewer web map is configured and the required layers and tables have been verified, create the Viewer app from the Indoors apps gallery.
To create the Viewer app, complete the following steps:
Verify that you are signed in to your ArcGIS Enterprise organization and have the necessary privileges to create content.
Verify that you are signed in to your ArcGIS organization and have the necessary privileges to create content in ArcGIS Online.
Browse to the Indoors apps gallery page using one of the following methods:
Click Apps
in the header of the site to see the apps available to you, and click Indoors.On the My Content page, click Create app, and click Indoors.
On the item details page of the web map shared for Indoors, click Create Web App, and click Indoors.
Click Create on the Indoors Viewer card.
Choose a map from the list of available web maps, and click Select Map.
To select from maps created by another member of your organization or maps shared with a group, click the My Content drop-down menu to change the selection of maps available.
Provide the title, tags, summary, and folder.
Click Create App.
Viewer opens and the Configure App panel appears. You can leave the default configuration or use the Configure App panel to configure the web app and preview your changes. While configuring the app, you can preview changes in the preview window in real time.
Tip:
At any point during the configuration process, you can do one of the following:
Click Save to save the recent updates.
Click Save As to save a copy of the existing app configuration.
Click Close
at the top of the Configure App panel to close it. If you have unsaved changes, you will be prompted to discard them.
Update configuration parameters
The following parameters can be modified:
Parameter |
Description |
App |
Information about the saved app, including the app title and link to the item page. Note:Click Details to view the item details page for the web app in your ArcGIS organization. After the app has been saved, you can modify the app title and change access permissions from the item page. |
Web Map |
An Indoors 2D web map to use in the app. Note:Click Details to view the item details page for the web map in your ArcGIS organization. |
Web Scene |
An Indoors 3D web scene to use in the app. Note:Click Details to view the item details page for the web scene in your ArcGIS organization. |
Route Service |
The route service used by the Directions widget. Note:
Closest Facility Service |
The closest facility service used in the Explore panel. The URL for the Network Analyst service containing the closest facility service must be registered as an item with the ArcGIS organization (for example, Note:Network Analyst services are not available directly in ArcGIS Online, but they can be added as an item using the URL of a network analysis service published to ArcGIS Enterprise. You can click Details to view the item details in the ArcGIS organization. |
Measurement Tool |
Configure a measurement tool for the app to measure spaces in 2D and 3D using the following option: Show measurement tool on the map—Turn on this option to use the measurement tool. The measurement tool is hidden by default. Note:The measurement tool is available on tablet devices but is not available on mobile devices. |
Scalebar |
Configure a scale bar for the app using the following options:
Print Layout |
The template used to display the map when printing directions. The ArcGIS Enterprise print service is used to derive the list of available templates. The ArcGIS Online print service is used to derive the list of available templates. Possible options: Map Only | Letter | A4 Note:When the value is Map Only, the printed map doesn’t contain page layout features (such as print date, map scale, and scale bar). Only portrait orientation is supported for the A4 and Letter print layouts. A4 corresponds to the A4 Portrait layout and Letter corresponds to the Letter ANSI A Portrait layout. |
Native App |
A link that opens the native app on iOS or Android devices. You can choose to have links open in Indoors Mobile or Indoors Mobile Classic when this option is enabled. The Indoors Mobile (Classic) option is selected by default. This option is turned on by default. Turn it off if you want users on mobile devices to be taken directly to Viewer in their device's browser, rather than being presented with a link to open the native app. |
Indoor Positioning |
Allows the Viewer app to show the current location of the device with a blue dot using Apple indoor positioning on iOS devices. This option is turned off by default. Turn it on if you are participating in the Apple Indoor Maps Program and want to use the available indoor position in Viewer. Indoor positioning is supported only for Safari. Note:Enabling indoor positioning can shorten battery life on mobile devices. |
Workspace Reservation |
Allows users to search for and book office hotels or meeting rooms in Viewer. Workspace reservations can be configured using Microsoft 365, a Reservations layer that conforms to the ArcGIS Indoors Information Model, or a mix of both. A custom name can also be specified for the buttons used to book office hotels and meeting rooms. Enabling workspace reservations requires configuring units for office hotels or meeting rooms in ArcGIS Pro. Learn more about workspace reservations Configure workspace reservations using the following options:
About Section |
Customize the content displayed in the app's About section using supported HTML elements. Customize the content displayed in the app's About section using supported HTML elements. |
App Launch |
Configure app launch actions. This option allows you to launch to third-party apps, such as Survey123 or a work order management form, from the Viewer app. |
App Auto-Sign out |
Automatically sign a user out of the app after a period of inactivity for desktop and mobile modes of Viewer. You can set the following options:
Kiosk |
Configure options that are specific to the kiosk mode of the app. You can set the following:
Logo |
Customize the logo used in the app. |
Theme |
Customize the color scheme of the app. |
Mobile Map Package |
Associate shared indoor mobile map packages to use the Indoors Viewer app configuration when opening the map in ArcGIS Indoors Mobile. Shared configuration settings include custom labels, mixed reservation configuration methods, and check in settings for meeting rooms. Note:Mobile maps can only be associated with one Indoors Viewer app. If more than one Indoors Viewer app is configured to be associated to a mobile map, the configuration of the latest modified Indoors Viewer app is used when opening the mobile map in Indoors Mobile. Click Details on a selected mobile map package to open the item details page for the mobile map package in your ArcGIS organization. Note:Connecting mobile maps to Viewer apps is incompatible with Indoors Mobile Classic. |
On the completed Viewer item page, you can share the completed app or choose Configure App to open the configuration again and make changes.
