Prepare a map for Indoors Viewer
Available with the ArcGIS Indoors Maps extension.
The Indoors Viewer app is configured to use a web map that contains either map image layers or feature layers. Maps that support Indoors—whether map image layers, feature layers, or mobile map packages—have layer requirements for feature classes in the Indoors geodatabase to support Indoors mobile apps and their functionality. These layers must conform to the ArcGIS Indoors Information Model, and are created and curated using ArcGIS Pro.
Before you prepare a map and share it to your ArcGIS organization for use in the Viewer app, you must create Indoors data that conforms to the Indoors model. This includes creating an Indoors database, loading data into the database, and, optionally, creating an indoor routable network in ArcGIS Pro.
You can create indoor data using an Indoors geodatabase created with the Create Indoors Database tool, or an indoor dataset created with the Create Indoor Dataset tool. An Indoors geodatabase contains all the required attributes and tables for mapping floor plans, space planning, routing, and workspace reservations, while the indoor dataset includes a simplified schema that is best suited for basic floor plan mapping.
Required data layers
The following layers are required for indoor data visualization in Indoors Viewer:
Details
Units
Levels
Facilities
This layer must be drawn on top of other indoor map layers to facilitate the 2D campus navigation experience in Viewer.
Include the Network_ND layer to support indoor routing and directions.
Include the following layers to support additional functionality in Viewer:
Events—List events, locate them on the map, and review details in the info panel, including associated images.
Occupants—Search for occupants, find them on the map, and configure workspace reservations.
<Category source> layers—Search for and explore additional features that are configured as categories.
<Barrier> layers—Use in routing when there are temporary changes to the network.
<Work order> layers—Integrate work orders.
<Oriented Imagery> layers—View 360-degree images in Viewer.
Reservations—Configure workspace reservations.
Sites—Organize facility features by the site in which they are located.
Optionally, include the following tables to support workspace reservations:
Areas—This table must be included in the branch versioned feature service if you are using the Indoors Space Planner app to assign occupants to spaces.
Area Roles—This table must be included in the branch versioned feature service if you are configuring reservation managers who can book and manage office hotels and meeting room bookings for other people.
Areas—This table is required if you are using the Indoors Space Planner app to assign occupants to spaces.
Area Roles—This table is required if you are configuring reservation managers who can book and manage office hotels and meeting room bookings for other people.
Layer names included in the indoor web map must exactly match these layer names to enable functionality in the Indoors web apps.
You can configure additional features that you want to interact with in the Viewer app as categories using the Create Indoors Category or Create Default Indoors Categories tools. These features can be from point or polygon layers in a floor-aware map and require a LEVEL_ID field that matches the LEVEL_ID field value of the associated feature in the Levels feature class.
The number of related items that are displayed for a feature in the info panel in Viewer is limited to the maximum number of features per layer. You can set this amount using the Maximum records returned by server parameter. This is important when displaying related items for a large feature such as a building.
Prepare the map
After creating the indoor data and, optionally, configuring categories, launch actions, or a routable network, you can create a map to share to your ArcGIS organization for use in Viewer. The Viewer web map must contain all of the required map image layers and feature layers.
Tip:
You can use the Indoors Viewer map templates included in the product data to prepare a map for Indoors Viewer. You can update the source of layers in the map template to point to the corresponding layers in the Indoors workspace and share the map to your organization for use in Indoors Viewer.
To create a map and prepare it for use by Indoors Viewer, complete the following steps:
Start ArcGIS Pro.
Sign in to your ArcGIS organization if necessary.
Create a project and add a connection to the Indoors geodatabase or open an existing project that contains the Indoors geodatabase.
Click the Insert tab and click New Map
to create a map if necessary.Add the following layers to the map and set the visibility as noted:
Layer name
Required
Layer visibility (recommended)
Facilities
Yes
On
The Facilities layer is particularly important in Viewer. Its position in the table of contents, visibility, and symbology determine the visibility of other layers in the map. To show the floor plans of all buildings, you can turn off the visibility or set the transparency on the Facilities layer. In this scenario, the ground floor of all unselected buildings is shown on the map at all times. The visible level in the selected building is set by the floor picker. If layers are drawn below the Facilities layer in the table of contents, only the features on the currently visible levels are shown. If layers are drawn above the Facilities layer, they are shown for all levels on unselected buildings.
Events
No
Off
Occupants
No
Off
No
Off
Details
No
On
Units
No
On
Levels
Yes
On
Keep the following in mind when adding and configuring layers:
If you want to identify features in the Viewer app, but don't need the explore or search experience and don't need to route to them, add the features to the map as basic layers (points, lines, polygons, or multipatch 3D features). You can configure pop-ups for these layers in a later step.
Indoors Viewer supports adding feature layers to the web map. Customization to display name, symbology, or other layer properties made in ArcGIS Pro for work order layers in Indoors Viewer is not available to mobile users. If you are using a feature layer for work orders that requires customization in both Indoors Viewer and mobile apps, consider making these changes in the shared layer so that users of the web and mobile apps have a similar experience.
If you are using Space Planner to make occupant and unit assignments, you must include a Units layer and the layer must contain populated
USE_TYPEfields. You can also include the following optional tables in the map:Areas—Allow signed-in users to book office hotels and meeting rooms in their assigned areas.
Area Roles—Allow signed-in users who are reservation managers to book and manage office hotel and meeting room bookings for other people in their assigned areas.
Configure the map as floor aware.
Maps must be floor aware to be used in the Viewer app.
Optionally, use the floor filter to specify Single Facility or Multi Facility filtering mode as follows:
Single Facility—Display a different floor level for the selected facility when using the floor filter. Other facilities continue to display the ground floor.
Multi Facility—Display the same floor level for all facilities when using the floor filter. If a facility does not have a matching vertical order, no floor is displayed for that facility.
The selected floor filtering option is honored in Indoors web apps when the web map is shared.
The option to select Single Facility or Multi Facility filtering is available in ArcGIS Pro 3.5 or later.
Configure additional layers as floor aware.
If you're using the Reservations layer to configure office hotels and meeting rooms, add it to the map.
Caution:
If the Reservations layer contains a definition query, remove it before sharing it in a web map or mobile map package. Definition queries applied to the published Reservations layer can cause issues with booking reservations in the Viewer and Indoors Mobile apps.
Set the visible scale range of the layers as necessary.
Set the symbology properties of the layers as follows:
Details and Units layers
Set according to the
USE_TYPEattribute.<Category source> layers
Set according to the field that describes the feature type.
Occupants and Events layers
Use an empty point symbol (no color or outline, and point size 1).
Use caution when applying symbols for category layers that have dense coverage. For example, offices are symbolized by the color of the unit polygon and shouldn't have individual point symbols.
Turn on labeling for Units (
NAMEattribute), Occupants (KNOWNASattribute), and any additional features that require a label.You can configure labels so that occupied office units display the occupant's name and unoccupied offices display the unit's name to visually identify which offices are vacant or available to assign in the app. To hide the unit name label for occupied offices, configure labels for the units layer as follows:
Right-click the Units layer in the Contents pane and click Labeling Properties.
The Label Class pane appears.
Click SQL query
and click New expression.Create the following expression:
Where Assignment Type is not equal to officeClick Apply.
Occupant labels may overlap with labels for adjacent units, which results in missing labels in the app. To avoid overlapping labels, you can stack occupant labels by creating an Arcade expression as follows:
Right-click the Occupants layer in the Contents pane and click Labeling Properties.
Click Label expression
and create the following Arcade expression:Replace($feature.KNOWNAS, ' ', TextFormatting.NewLine)Click Apply.
Set the display field in the layer properties for Occupants, if present, to
KNOWNASand all other map layers toNAME.Note:
The Viewer app uses the display field value for labeling certain items in the app, such as the info panel title. Setting this in ArcGIS Pro helps avoid confusion for app users.
Configure pop-ups for any additional layers you want to identify on the map.
Configure pop-ups for layers that you want to interact with on the map in Viewer. These basic layers don't support the explore or search experience, and action buttons, such as Directions, are not available.
Not all number formats in ArcGIS Pro are supported in the web apps.
Ensure that the map has a coordinate system set for Current XY, such as WGS 1984 Web Mercator (Auxiliary Sphere), and Current Z, such as WGS84.
Geographic and projected coordinate systems are supported in Viewer.
Optionally, rename the map to make it easily identifiable, and complete all metadata fields.
Set the display extent of the map to display all of the map data.
Add any Esri-hosted or custom basemap services to the map.
Configure a basemap to choose between an Esri-hosted basemap or a custom vector tile package basemap.
Clear all feature selections.
The map is now ready to publish and share as a web map to your ArcGIS organization.
You can further configure the map in ArcGIS Pro to configure a basemap, publish category features as a feature layer, or configure additional app functionality such as searchable events, work orders, device location and sharing, hotel booking, app launch actions, and routing barriers. You can also use the Viewer map to create a 3D scene in ArcGIS Pro for use in the Viewer app.
Web scene layers cached on the server are not supported on ArcGIS Enterprise on Kubernetes 11.2.
Configure a basemap
A basemap is an essential component of an indoor map that provides context and perspective for nearby features. When selecting a basemap, consider the scale of the map. Unlike image tile basemaps, vector tile basemaps are smaller in size and support higher levels of detail.
The following workflows outline the necessary steps to configure a basemap for Indoors.
Use an Esri-hosted basemap
In ArcGIS Pro, you can add basemaps from the Basemap gallery in the Layer group on the Map tab. Depending on your ArcGIS organization's configuration, the gallery may include default Esri basemaps, maps shared to your organization's basemap gallery group, and basemaps added to a project in ArcGIS Pro.
To add Esri vector basemaps to a map, complete the following steps:
Copy the URL for the vector basemap you want to add.
Click the Add Data drop-down arrow in the Layer group.
Choose the Data From Path option.
The Add Data From Path dialog box appears.
Paste the URL.
Click Add.
Use a custom basemap hosted on an ArcGIS Enterprise organization
To use a custom basemap hosted on your ArcGIS Enterprise organization, complete the following steps:
Author a custom basemap.
Create a vector tile package using the Create Vector Tile Package tool.
When running the Create Vector Tile Package tool, make the following adjustments to support an indoor level of detail and scale the tile down by a factor of 17:
Uncheck the Package for ArcGIS Online | Bing Maps | Google Maps check box.
Choose the
VectorBasemapTilingScheme.xmlfile included in the Indoors symbology resources for the Tiling scheme parameter.
Share the vector tile package to your ArcGIS Enterprise organization.
Sign in to your ArcGIS Enterprise organization in a browser and publish the vector tile package as a hosted layer.
Add the ArcGIS Enterprise organization items to the map in ArcGIS Pro.
Tip:
Alternatively, if you have a hosted tile layer, click the Add Data drop-down arrow in the Layer group and click Data From Path to specify the URL to the hosted tile layer.
