Prerequisites for Indoors Viewer
Available with the ArcGIS Indoors Maps extension.
The following prerequisites must be completed before deploying Indoors Viewer:
  1. Curate data in ArcGIS Pro
  2. Create a map with pop-ups configured
  3. Identify kiosk locations
  4. Share a web map or scene from ArcGIS Pro to your ArcGIS organization
  5. Provide network or closest facility services
  6. Configure user access to services
The first part of the process is preparing data to use for Viewer. The web map must contain several important layers and tables that the app uses to present a compelling indoor user experience. The layers in the map must conform to the ArcGIS Indoors Information Model and be authored in a way that's ready to use in Viewer.
Maps and scenes must contain the following layers for use in Viewer:
  • Facilities (buildings)
  • Details
  • Units
  • Levels (floors)
  • Additional layers that contain features you want to include in the Viewer app (for example, features that users may want to find on a map such as bike racks or ATMs, features to use as landmarks in routable directions, or events)
If displaying space assignments from Space Planner, the occupants feature class and Areas table are required. The IndoorsConfig table is optional.
Learn more about preparing indoor data
Ensure that values for ID fields, such as FACILITY_ID, do not have leading or trailing spaces, as these can cause the value of the associated name field to be displayed as Undefined in some cases.
Viewer supports pop-ups that are configured in ArcGIS Pro before sharing the web map or web scene, or those configured in Map Viewer in your ArcGIS organization.
You can select an individual item in the map or scene in Viewer, and information about that item will show in an info panel. Viewer uses pop-ups to determine what displays in the info panel for a selected item. Pop-ups are a convenient way to present information about any feature in an Indoors map or scene.
Learn more about preparing a map for Viewer in ArcGIS Pro or configuring pop-ups in ArcGIS Enterprise.
Learn more about preparing a map for Viewer in ArcGIS Pro or configuring pop-ups in ArcGIS Online.
When deploying kiosk mode, consider mapping out the kiosk locations. The location information can be used to help you determine if your organization requires a unique map or scene services in your ArcGIS organization for each of the kiosks. This also allows you to configure kiosks with location-specific information to ensure a consistent user experience.
To use the Viewer app, you must share a 2D web map and, optionally, a 3D web scene from ArcGIS Pro to Enterprise to use in Viewer.
To use the Viewer app, you must share a 2D web map and, optionally, a 3D web scene from ArcGIS Pro to ArcGIS Online to use in Viewer.
In addition, other services must be shared to enable other functionality in the app, such as scene views, routing, and sorting by proximity. Finally, a default print service must be set up in your organization to enable printing for Viewer.
Sharing an indoor map is similar to publishing any other map. You can maximize performance and control the presentation of information in a way that is useful.
You can prepare the maps and scenes you use in Viewer to ensure that they perform optimally and serve your target audience reliably.
Learn more about best practices for using layers in maps and best practices for scene performance.
Learn more about best practices for sharing and best practices for scene performance
To use the routing and directions functionality, a routing service is required. You can also provide a closest facility service to sort search results by distance.
Learn more about sharing route and closest facility web layers to Enterprise
ArcGIS Online does not directly support sharing network or closest facility services. However, options to use network analyst services hosted outside your ArcGIS Indoors organization are available. These options include direct links to publicly available network and closest facility services, and cross-organizational collaboration to network services that might be hosted in an internal network.
Use of network analyst services in ArcGIS Online requires access to an ArcGIS Enterprise deployment with ArcGIS Server licensed with the ArcGIS Network Analyst extension.
Learn more about using route and closest facility web layers in ArcGIS Online
Learn more about Enterprise and ArcGIS Online collaboration
Learn more about Esri Managed Cloud Services
User access to Viewer is controlled by the sharing permissions on the app’s services. You can share the services that the app uses from Enterprise to anyone who needs to use the app.
User access to Viewer is controlled by the sharing permissions on the app’s services. You can share the services that the app uses from ArcGIS Online to anyone who needs to use the app.
If the services are not shared with everyone, users are prompted to sign in with their ArcGIS organization credentials, and they cannot use the app until they do. If all services are shared with everyone, anyone can use the app without signing in. Additionally, Viewer uses the default print service set in the ArcGIS organization.
You need to license Viewer for your ArcGIS organization.
To share Viewer with everyone, ensure that anonymous access is enabled for your ArcGIS organization.
Additional configuration for kiosk mode
Access to the services for kiosk mode is configured in your ArcGIS organization. Depending on how you want to share the services from ArcGIS Enterprise, you can configure a single service to share across all kiosks or individual services for each of the kiosks in your deployment. If you don't want to require kiosk users to sign in, you can share the services kiosk mode uses with everyone. If the services are not shared with everyone, users will be required to sign in with their ArcGIS organization credentials to access kiosk mode.
Access to the services for kiosk mode is configured in your ArcGIS organization. Depending on how you want to share the services from ArcGIS Online, you can configure a single service to share across all kiosks or individual services for each of the kiosks in your deployment. If you don't want to require kiosk users to sign in, you can share the services kiosk mode uses with everyone. If the services are not shared with everyone, users will be required to sign in with their ArcGIS organization credentials to access kiosk mode.
