Configure a web map for Indoors Viewer
Available with the ArcGIS Indoors Maps extension.
Web maps shared with both feature layers and map image layers can be used for Indoors Viewer. However, if you are using a map image layer-based web map and are using the Areas table, you must add it to the web map after publishing to ArcGIS Enterprise. Add the Areas table if hotel areas have been configured in Indoors Space Planner.
Learn more about preparing a web map for Viewer
To add the tables, complete the following steps:
Sign in to your ArcGIS organization.
Click Content and search for the web map shared from ArcGIS Pro.
Click the more options button
for the web map and click Open in Map Viewer.Make any necessary changes to the web map, such as renaming layers, removing layers, and turning on the layers that should be displayed by default when the Viewer app is launched.
Add the optional Areas table to the web map:
In the Content pane, click the More Options button
for the map image layer in the web map, and click Show Item Details.In the Item Details page, scroll to URL and click View to open the tables and their links.
In the REST endpoint for the map image layer, scroll to the Tables section, right-click Areas, and click Copy link address.
Go back to Map Viewer.
Click Add > Add Layer from Web.
Ensure the type of data you are referencing is set to An ArcGIS Server Web Service.
Paste the copied URL to the table and click Add Layer.
In Map Viewer, rename the table from <nameofmapservice> - Areas to Areas.
Save the web map.
You can now use your Viewer web map to create the Viewer app.
This content does not apply to ArcGIS Online.
