Review space plans
Available with the ArcGIS Indoors Spaces extension.
You can ask for feedback on space plans and occupant moves by adding other members of your organization as reviewers. Reviewers can see a list of moves, add or reply to comments, and accept or reject the plan.``
Only the plan owner can add or remove reviewers.
For reviewers to open the plans, you must share plans with your organization and reviewers must have privileges associated with the default Data Editor role or higher. If reviewers are assigned a custom role, enable the edit privilege for features so they can open plans.
For reviewers to open the plans, you must share plans with your organization and reviewers must have privileges associated with the default Data Editor role or higher. If reviewers are assigned a custom role, enable the edit privilege for features in ArcGIS Online so they can open plans.
Add reviewers
After creating your plan, complete the following steps to add reviewers:
  1. Click the Review tab.
  2. Click Reviewers to open the Reviewers panel.
  3. Click Add Reviewer.
    The Add Reviewer dialog box appears.
  4. Choose a member of your organization who you want to set as a reviewer and click Add Reviewer.
    The reviewers you added appear in the Reviewers panel along with corresponding icons indicating their response:
    Icon
    Accepted
    The reviewer accepted the plan.
    Not accepted
    The reviewer did not accept the plan.
    Pending
    A response is pending.
    Other reviewers and the plan owner can see the list of reviewers and their responses.
The list of reviewers for a space plan is stored in your ArcGIS organization content in a folder named Indoors.
Caution:
The feature layers that are created automatically by Space Planner in that folder have names that match the name of the space plan they support. These feature layers are required and must not be deleted. Space Planner manages the feature layers.
List moves
The Moves panel contains a table that lists occupants and spaces involved in new assignments. Anyone with access to the plan can view the Moves list.
The moves list is cleared after you merge a plan.
Access the list by completing the following steps:
  2. Click Moves .
    The Moves panel appears with a list of proposed moves.
  3. Click the filter button to filter the list as necessary.
  4. Click a row in the list to center the map on the unit in the To column.
  5. Click a column heading to sort the list in ascending or descending order based on that column.
Add comments
Anyone with access to the plan can make comments on the plan. Comments are listed in the Comments panel on the Review tab.
To view, add, and reply to comments, complete the following steps:
  2. Click Comments .
    The Comments panel appears.
  3. Click +Add at the top of the panel.
    A text box appears.
  4. Type a comment in the text box.
  5. Click Save.
    The new comment appears in the Comments panel, with your name and how long ago you posted it.
    Tip:
    You can click Cancel to go back to the Comments list without posting a comment.
  6. Optionally, click Add under the comment to place a marker on the associated unit on the map to associate the unit with the comment.
    Clicking a comment with a unit associated with it centers the map on that unit. You can update the marker's location by clicking Update under a comment with an associated location, and then choosing a new location on the map.
After you post a comment, others with access to the plan can view and reply to it by clicking Reply. You can also edit or delete your comment.
Comments for a space plan are stored in your ArcGIS organization content in a folder named Indoors.
Caution:
Accept or reject a plan
After reviewing a plan and adding comments, reviewers can accept or reject the plan. Reviewer responses provide feedback to the plan owner but do not affect whether the plan can be merged. Only users with merge permissions can merge the plan.
To accept or reject a plan, complete the following steps:
  2. Click Reviewers.
  3. Find your name in the list of reviewers and click Accept to accept the plan or Not Accept to reject the plan.
    An Accepted icon appears next to your name if you accepted the plan and a Not accepted icon appears if you did not accept the plan. You can later update your choice by clicking a different option.
Other reviewers and the plan owner can see the list of reviewers and whether they accepted the plan, did not accept the plan, or have not yet responded.
