Explore data in the knowledge graph view
The knowledge graph view is the default view in a Knowledge Studio project. The knowledge graph view lists the entity types and relationship types in a graph and displays the details of the selected entity or relationship. In addition to entities and relationships, a knowledge graph can reference documents that support information recorded in the knowledge graph.
Open the knowledge graph view
The knowledge graph view is open by default in a new project. To reopen the knowledge graph view, click Knowledge Graph
in the Project Contents pane.
Browse the contents of a knowledge graph
The knowledge graph view displays the types of entities and relationships defined in the knowledge graph's data model and allows you to explore the entities or relationships of the selected type.
The numbers in the following image correspond to the descriptions below.
| Element | Description |
| The Knowledge Graph Contents pane allows you to explore entity |
| The record list pane shows all instances of the selected entity or relationship type. You can filter the list of entities or relationships using the Filter box at the top of the pane. By default, All entities are selected in the Knowledge Graph Contents pane and listed in the record list pane. The record list shows the first 1,000 records of the selected entity or relationship type. | |
| The record view allows you to explore the details of the selected record, including its nearest related records, properties, and spatial information. | |
| The context toolbar allows you to add the selected record to other content items. | |
| Each open content item appears as a tab in this area. |
Update display name for entities and relationships
You can change the display names for entities and relationships of a given type in the knowledge graph view. Updates to the display name in the knowledge graph view are not applied to entity and relationship labels on link charts or maps. The changes apply only to the current project and do not rename the entity or relationship types in the data model.
Select the entity or relationship type In the Knowledge Graph Contents and click Options
.The options menu appears.
In the options menu, click Change display name
The Set Display Name dialog box appears.
Click a property to use as the display name for the given entity or relationship type.
Click Apply.
The Set Display Name dialog box closes. The display name for all records of they selected type are updated in the Records list pane and Record view
On the main menu, click Save
The changes are saved to the project.
View details for an entity
When you choose an entity
from the record list pane, the record view lists all properties of the entity and the relationships in which it participates and provenance records documenting where information about the entity originated..
Click an entity type in the Knowledge Graph Contents pane and click an entity in the record list pane to view its information in the record view.
The display expression and entity type are displayed at the top of the record view. For example, if the type of entity represents a company, the display expression might show the company's name.
The Details tab in the record view is active by default and shows a preview of the entity’s properties and relationships. The One-hop Neighbor Link Chart displays the entity and its relationships. If the entity is spatial and has a geometry, a map of the entity’s location is displayed.
Click the Properties tab in the record view or click View All Properties on the Details tab.
All properties of the selected entity are listed. For example, an entity of type Company might have properties such as company name and the year it was established. Property names appear in the
Namescolumn, the property's data type appears in theTypecolumn, and property values appear in theValuecolumn. If the year it was established is unknown and a value has not been set for this property,<Null>appears in theValuecolumn.
Click the Relationships tab in the record view or click View All Relationships on the Details tab.
All relationships defined between the selected item and other entities in the knowledge graph are listed. Each relationship's type appears in the Relationship column. The entity with which the selected item is associated is shown in the Entity column.
For example, if the selected entity is of type Company, it might have a relationship such as WorksFor. An expression identifying the employee entity appears in the
Namecolumn.
Similarly, if the selected entity has the type Company, it might have multiple WorksFor relationships listed in various rows in which each row identifies an employee. An expression identifying each Person entity will appear in the Name column of the appropriate row.
You can navigate to connected relationships and entities through the relationships table in the record view.
Click a relationship in the Relationship column of the relationships table to navigate to a relationship.
Click an entity in the Name column of the relationships table to navigate to a related entity.
The selected record opens in the knowledge graph view.
Click the Provenance tab or click the flag in the Provenance column of the Properties table in the Details tab.
All provenance records for the properties of the selected entity are listed. You can see the properties of each provenance record in this list.
If you navigate to the provenance tab from the Properties table on the details tab, the table is filtered to the provenance records for that specific property. To clear the filter, click the X on the filter chip at the bottom of the table. All provenance records for the entity are displayed.
View details for a relationship
When you choose an instance of a relationship
in the record list, all the properties of the relationship and the entities with which it is associated are listed in the record view.
Click a relationship in the Knowledge Graph Contents pane to view its information in the record view.
The display expression and relationship type are displayed at the top of the record view.
The Details tab in the record view is active by default and shows a preview of the relationship properties and connected entities. The One-hop Neighbor Link Chart displays the origin and destination entities of the relationship.
All properties of the selected relationship are listed. For example, a WorksFor relationship might have properties such as start date and position. Property names appear in the
Namecolumn, the property's data type appears in theTypecolumn, and property values appear in theValuecolumn. If a property's value is unknown and has not been set,<Null>appears in theValuecolumn.
Click the Entities tab in the record view or click View All Entities on the Details tab.
The origin and destination entity of the relationship are listed. The display expression for the entity appears in the
Namecolumn, the entity’s type appears in theTypecolumn, and the relationship with which the selected item is associated is shown in theRelationshipcolumn.
You can navigate to related entities by clicking the name of entity in the Entity Name column of the relationships table. The selected entity opens in the knowledge graph view.
The Provenance tab will only be visible if provenance is enabled on the project's knowledge graph.
All provenance records for the properties of the selected relationship are listed. You can see the properties of each provenance record in this list.
View the custom overview tab
A customized Overview tab can provide a short summary of important information about the selected entity or relationship. By default, the Overview tab is not present in the Knowledge Studio project record view. To access the Overview tab in your Knowledge Studio project, you must have the following:
Once custom investigation settings are saved to the knowledge graph, you can view the custom Overview tab in your Knowledge Studio project.
