Change visualization of nonspatial records
Link charts allow you to visualize spatial and nonspatial data in a knowledge graph. The Spatial visibility effects settings provide additional tools to distinguish between spatial and nonspatial records through visual effects. For these settings, spatial records are all entities that have spatial geometry and all relationships that connect two spatial entities. Nonspatial data is all entities that do not have geometry, including records whose geometry is null, and any relationship that connects to a nonspatial entity.
Hide nonspatial records
To hide the nonspatial records on a link chart without removing them, turn on the Hide nonspatial records toggle button.
If you export this link chart from Knowledge Studio and import it into ArcGIS Pro, this setting is maintained.
Change nonspatial effects
You can use the same effects settings to change the visualization of the spatial or nonspatial data in the link chart. The link chart automatically updates as you move the sliders for each effect.
To change the effects settings, complete the following steps:
  1. Click Visualization on the context toolbar.
  2. Click Spatial Visibility Effects from the drop-down menu.
    The Nonspatial tab is active by default.
  3. Move the sliders for each effect to customize the visualization of nonspatial records as described in the following table:
    Opacity
    This effects option changes how transparent the records appear. The lower the value, the more transparent the record, de-emphasizing the records and allowing what is underneath to show through.
    Drop Shadow
    This effects option makes objects look like they are floating. It applies a drop shadow that follows the outline of the feature. The Drop Shadow option has the following properties:
    • Width—The width of the drop shadow. The larger the value, the larger and more blurred the shadow is.
    • Offset—The distance between the drop shadow and its associated feature. The drop shadow always occurs on the low right of the feature.
    • Opacity—The opacity or transparency of the effect.
    A larger drop shadow value increases all properties, making the shadow farther from the record, larger, more transparent, and more blurred.
    Grayscale
    This effects option decreases or removes color. This effect is useful for muting or decreasing the visual strength of the records.
    The higher the value, the more the features appear gray.
    Blur
    This effects option decreases the focus or softens the edges of the features. It makes the layer look out of focus or blurry, as though it's being viewed through a translucent screen.
    The higher the value, the stronger the blur.
    Brightness
    This effects option adjusts the lightness and darkness of the records.
    The higher the value, the lighter the records.
    Contrast
    This effects option determines the visual difference between the records. Higher contrast values increase the visual difference.
    Hue Rotation
    This effects option uses a color wheel to transform colors relative to one another. The colors in the layer are shifted to the colors at the specified angle.
    The value is the number of degrees around the color wheel.
    Inversion
    This effects option transforms all colors to their opposite, similar to a film negative.
    The result of applying this effect is like flipping the color ramp when styling a layer. For example, this effect can be useful if you are in geographic layout and you want to replace a light basemap with a dark one. It allows you to invert the records so they remain visible or emphasized with the new basemap.
    The higher the value, the more the color is inverted.
    Saturation
    This effects option increases or decreases the intensity of the colors.
    The higher the value, the more intense the color.
    Sepia
    This effects option converts colors to shades of brown to mimic old photographs. This effect gives the layer a warmer, more yellow and brown appearance.
    T he higher the value, the more yellow and brown the layer appears.
  4. Optionally, click the Spatial tab and move the sliders for each effect to customize the visualization of spatial records.
  5. Optionally, click Reset to reset all effects to the defaults, including the Hide nonspatial records toggle button.
