ArcGIS Linear Referencing authorization
ArcGIS Linear Referencing includes two options:
  • The ArcGIS Linear Referencing extension, which requires an extension license and provides advanced enterprise capabilities.
  • Basic linear referencing, which does not require an extension license and supports creating and managing basic linear referencing datasets.
To use the ArcGIS Linear Referencing extension, you must authorize it in ArcGIS Enterprise and ArcGIS Pro.
ArcGIS Linear Referencing for ArcGIS Enterprise
You must authorize the software by entering an ArcGIS Linear Referencing license key on each machine that hosts linear referencing system (LRS) data and uses the Linear Referencing REST API. You can obtain the license key through My Esri.
Depending on the user type and the versioning operation, you may or may not need the Advanced Editing user type extension.
For more information about licensing, refer to the ArcGIS Enterprise Geodatabase Capabilities table in the ArcGIS Enterprise Functionality Matrix (PDF).
ArcGIS Linear Referencing for ArcGIS Pro
To run the ArcGIS Linear Referencing extension tools in ArcGIS Pro, you need the Linear Referencing extension license.
Learn more about authorizing and managing extension licenses in ArcGIS Pro
