Configure pop-ups
A map can show descriptive information about imagery and features configured to display in a pop-up. Pop-ups can bring focus to the attributes associated with each layer in the map, such as hiking trails, land use types, or unemployment rates. They can contain attachments, images, charts, and text, and they can link to external web pages.
Tip:
For point layers with clustering enabled, you can also configure pop-ups for clusters.
In ArcGIS Maps for Fabric, the default pop-up appearance for a feature layer is a list of fields and values. The default pop-up appearance for an imagery layer is the pixel values. As a map owner, you can reconfigure the pop-ups to define the list of visible and hidden fields and define how the information is presented. You can also add content to provide more meaning to the pop-up. For example, you can include a list of fields, provide an interactive experience using custom-formatted text and images, and show related records.
Tip:
To learn more about designing and configuring pop-ups, see the following blog articles:
To access ArcGIS Maps for Fabric, you must have a supported ArcGIS organizational account. By signing in with your ArcGIS organizational account, you can access your ArcGIS Online content as well as your organization's content, basemaps, and ArcGIS Living Atlas layers. You cannot access ArcGIS Maps for Fabric with an ArcGIS Public account.
Configuration options
As a map author, the main decisions you'll make about pop-ups are what information is displayed and the best way to present it. For example, to show the public where they can swim, fish, and boat along the Mississippi Gulf Coast, you can configure pop-ups to show the address, type of access, and images of public access points. Even though the layer may have other fields regarding the location and type of point, you may not want to show them in the pop-up, as they detract from the more relevant information.
Depending on what you are trying to show in pop-ups for feature or imagery layers, you can choose from a variety of configuration options. These are described in the sections below.
Tip:
Some configurations are illustrated in this map of California peaks. On the Contents toolbar, click the Layers pane and turn on one layer at a time to compare the configurations by clicking features on the map.
Enable and remove pop-ups
Layers can contain a large amount of feature data, and maps can include several layers, so pop-ups generally look better if you configure them with selected fields, formatting, media, and so on. Pop-ups are enabled on feature layers by default.
To remove pop-ups from a layer, complete the following steps:
Tip:
Confirm that your ArcGIS organizational account user type is Creator or higher and that your user role is Contributor or higher in the Microsoft Fabric workspace where you are working to save changes to the map.
  1. In ArcGIS Maps for Fabric, open the map containing the layer or add the layer directly.
  2. On the Contents toolbar, click Layers Layers to open the Layers pane, and select the layer that contains the feature data you want to show in a pop-up.
  3. On the Settings toolbar, click Pop-ups Pop-ups, and turn off the Enable pop-ups toggle button.
To enable pop-ups on a layer with pop-ups turned off, turn on the Enable pop-ups toggle button.
Configure pop-ups
To configure pop-ups, complete the following steps:
Tip:
  3. On the Settings toolbar, click Pop-ups Pop-ups.
  4. Optionally, for imagery layers, turn on the Ignore NoData toggle button to disable pop-up information for NoData areas in the image.
    If the Ignore NoData toggle button is turned off, no pixel information will be displayed in the pop-up.
  5. Optionally, for imagery layers, turn on the Display topmost item only toggle button to display pop-up information for the topmost layer in a mosaic dataset.
    If the Display topmost item only toggle button is off, pixel information for all the mosaic dataset layers at the location will be displayed.
  6. Click Title and enter a title for the pop-up.
    1. Click Add field Add field and select fields from the data.
    2. Optionally, enter static text instead of or in addition to the field values.
  7. Click Fields list.
  8. Enter a title for the list of fields shown in the pop-up.
    1. Click Add field Add field and select a field value or expression from the data. Use this option if you want a unique title for each feature in the data.
    2. Optionally, enter static text instead of or in addition to the field value.
    3. Leave the field blank if you do not want a title for the fields list.
  9. Enter a description for the list of fields.
    3. Leave the field blank if you do not want a field description.
  10. Rearrange and remove fields, and click Select fields to add fields to the list.
    You can configure the fields to better display the field names and values.
    If the feature layer includes attachments, they are automatically added to the pop-up under attachments. Attachments are supported as a related table to a feature class in a feature service.
  11. Optionally, click Add content and add media such as images, charts, or text to the pop-up.
  12. Optionally, use the Reorder handles Reorder to change the order in which the content appears.
  13. Optionally, save your map.
Configure fields
You can configure the field or fields you want to display by changing the display name and formatting the field values.
  1. On the Settings toolbar, click Fields Fields.
  2. Select the field you want to configure.
    Tip:
    You can select multiple fields of the same type to configure their formatting at the same time.
    1. Change the display name of the field.
    2. For number fields (such as population), select the number of decimal places to display and whether to use a thousands separator.
    3. For Date, Date only, and Timestamp offset fields, select a date format from the Date format drop-down menu.
    4. For Date and Timestamp offset fields, turn on the Show time toggle button and select an hour and time format for displaying time.
    5. For a Time only field, select an hour and time format from the drop-down menus.
    To learn more about supported field types, see Date and time fields in ArcGIS Online.
    1. Click Done.
Use expressions
You can use custom expressions written in the Arcade expression language when configuring pop-ups. Using expressions allows you to create and display new information from existing fields in the layer. For example, you can create an expression that converts values from feet to meters, or dynamically create a URL based on feature attributes. If an expression is available for the layer—for example, for labeling or styling—you can copy and reuse it in your pop-up configuration.
You can create expressions in pop-ups or use existing expressions created for the layer.
Tip:
You can use the ArcGIS Arcade assistant (beta) to generate ArcGIS Arcade expressions from instructions typed in natural language.
  1. Follow the first three steps in the Configure pop-ups section to open the Pop-ups pane for the layer you want to configure.
  2. Click Attribute expressions.
    The Attribute expressions pane appears.
  3. Click Add expression to open the editor window and create the expression.
    Tip:
    If you need help with any of the Arcade functions, click the arrow next to the function to see reference information about it.
  4. In the editor, click Done when you are finished.
    Tip:
    Before closing the editor, give the Arcade expression a title that makes it easily identifiable in the list of fields.
    The new expression is added to the Attribute expressions list. To edit it, select it from the list and make changes in the editor. To remove it, click Remove expression Remove next to it.
    If you used a list of field attributes in the pop-ups, the new expression is added to the Fields list section, and you can change its formatting in the Fields pane.
  5. Optionally, save your map.
Add attachments
When a feature layer includes attachments in its data, the attachments are added to the layer's pop-up. You can show the attachments as a list or in a gallery. You can also remove attachments from the pop-up. Clicking attachments in a pop-up opens the attachment in a new browser tab.
If pop-ups have not been previously configured for the layer and you are configuring the pop-ups in your map for the first time, ArcGIS Maps for Fabric automatically chooses the most appropriate display for your attachments.
  1. Follow the first four steps in the Configure pop-ups section to open the Pop-ups pane for the layer you want to configure.
  2. Click Attachments.
  3. Choose one of the following options for displaying attachments in the pop-up:
    • Auto—Allows the app to choose the best experience.
    • List—Displays the attachments as links.
    • Gallery—Displays the attachments as images.
  4. Enter a title for the attachment.
    3. Leave the field blank if you do not want a title.
  5. Enter a description for the attachment.
    1. Click Add field Add field and select a field or expression from the data. Use this option if you want a unique description for each feature in the data.
    3. Leave the field blank if you do not want a description.
  6. Click the Sort by drop-down menu and choose an attachment property by which attachments are sorted in the pop-up.
    Attachment properties are characteristics associated with the attachment files, such as content type, name, or size.
  7. Click the Sort order drop-down menu and choose the order by which attachments are sorted in the pop-up.
  8. Optionally, under Filters, turn on the Keyword toggle button to filter attachments displayed in the pop-up by selected keywords. To filter by attachment type, turn on the Type toggle button and click Add types, then choose one or more attachment file types to be displayed in the pop-up.
    To filter attachments by selected keywords, keywords must exist on the feature layer. To learn more about keywords, see the ArcGIS Survey123 and ArcGIS Field Maps documentation.
  9. Optionally, click Options Options and click Delete to remove attachments from the pop-up.
  10. Optionally, save your map.
Add images
You can include images in pop-ups by providing a URL to an image (PNG, JPEG, or GIF format). The images can include a title, caption, links to related websites, and alternative text.
Tip:
For the best display, create images that are 400 pixels wide and optimized for web use. If the width of the image is less than 400 pixels, a white border is visible in the window. If the image is wider and not optimized for web use, the web browser automatically rescales the image and it may appear warped.
When adding images to pop-ups, you can set a refresh interval. This allows the pop-up to refresh and display a frequently updated image at a specific interval (in minutes). For example, you can use this option to refresh images captured by a traffic camera.
  2. Click Add content and choose Image.
  3. Provide the URL to the image.
    1. Click Add field Add field and select a field or expression from the data. Use this option if you want a unique image for each feature in the data.
    2. Optionally, provide the URL to an image stored on an external website, in ArcGIS Online, or as an attachment in the layer's data.
      PNG, JPEG, and GIF formats are supported. If the image is stored as an item in ArcGIS Online, you must provide the URL copied from the URL field on the item page, which is only available if the image item is shared with the public.
  4. Click Options to reveal additional fields for the title, caption, link, and refresh interval.
  5. Enter a title for the image.
  6. Enter a caption.
    The caption appears below the title and above the image. It is useful for giving a short explanation of the image.
    1. Click Add field Add field and select a field or expression from the data. Use this option if you want a unique caption for each feature in the data.
    3. Leave the field blank if you do not want a caption.
  7. Enter alternative text for the image.
    Alternative text is hidden on the pop-up and is used by screen readers.
    1. Click Add field Add field and select a field or expression from the data. Use this option if you want unique alternative text for each feature in the data.
    3. Leave the field blank if you do not want alternative text.
  8. Enter the URL of a related link.
    When the image is clicked, this URL opens in a new browser tab.
    1. Click Add field Add field and select a field or expression from the data. Use this option if you want a unique URL for each feature in the data.
    2. Optionally, enter the URL of a related link.
    3. Leave the field blank if you do not want a related link.
  9. Optionally, turn on the Refresh interval toggle button and enter a value in minutes in the text box to set a refresh interval for the image.
    When the pop-up is displayed, the image is refreshed at the interval specified.
  10. Optionally, click the Reorder button Reorder next to the item in the Media section and drag it to a new position if you have more than one image (or other media items) and want to change the order in which they appear in the pop-up.
  11. Optionally, save your map.
Add charts
You can add charts to graphically display the values of numeric attribute fields. You can add bar charts, line charts, and pie charts.
  2. Click Add content and choose Chart.
  3. Choose the type of chart you want to show.
  4. Enter a title for the chart.
  5. Enter a caption for the chart.
    The caption appears below the title and above the chart. It is useful for giving a short explanation of the data in the chart. You can include an indication of units for column, bar, or line charts in the chart description. A pie chart shows percentages when hovering over each segment.
  6. Enter alternative text for the chart.
  7. Click Select fields and select the fields to include in the chart.
  8. Optionally, adjust the chart colors by doing the following:
    • For line charts, select a color from the color picker or specify a custom color using RGB, HSV, or hexadecimal values. Click Add Add to save a custom color and click Remove Remove to remove a saved color. Click Done when you are finished selecting a color.
    • For bar charts and pie charts, select a color ramp and click Done. To filter the color ramp options, choose a color ramp category from the drop-down menu—for example, Best for dark backgrounds or Bright—and optionally click Flip ramp colors to change the direction of the colors in the ramp. Alternatively, click the colored symbol next to each field in the list to customize any of the colors individually.
      Tip:
      To see the name of a color ramp, point to it.
    Click Reset to default colors Reset to return to the default chart colors at any time.
  9. Optionally, turn on the Horizontal orientation toggle button to display a bar chart horizontally.
  10. Optionally, turn on the Normalize toggle button and select a normalization field.
    The values in this field are used to divide the value field to create ratios. Normalization ratios are useful when other factors influence the numerical values you are classifying and displaying. For example, population can be influenced by each county's size, so you can divide population by area to standardize the data. Data normalization is also useful for providing a meaningful comparison if the values in the fields do not use the same units of measurement.
  11. Optionally, click the Reorder button Reorder next to the item in the Media section and drag it to a new position if you have more than one image (or other media items) and want to change the order in which they appear in the pop-up.
  12. Optionally, save your map.
Add text
You can include text in pop-ups to add context and information.
  2. Click Add content and choose Text.
    A text element is added and the text editor appears.
  3. In the text editor, do any of the following:
    • Click Fields list Fields list or type { and select a field or expression from the data. Use this option if you want unique text for each feature in the data.
    • Provide plain text in the text editor.
    • Use the text formatting tools to format the text.
    Tip:
    To give you the most control and flexibility over your display, you can also use supported HTML in your pop-ups by clicking Source Source in the text editor.
  4. Click OK.
Add an Arcade element
In addition to using attribute expressions to return values that function like existing fields, you can use Arcade to create and define entire content elements in pop-ups. Using an Arcade element helps to avoid duplication of logic when working with multiple attribute expressions. Arcade elements allow you to define the data and other aspects of the element in a single expression.
Choose a template for rich text, chart, or fields list elements and create an Arcade expression that defines the element's content.
  2. Click Add content and choose Arcade.
    The editor window appears.
  3. Click Suggestions and choose a template from the Templates tab to create the expression.
    Tip:
    Arcade elements return a dictionary that defines your pop-up element. Templates help you get started with the correct dictionary structure. Learn more about the structure of pop-up elements and the pop-up element profile in Arcade.
    Tip:
    Before closing the editor, give the Arcade element a title that makes it easily identifiable in the list of pop-up content elements.
