Set map properties
Adjust settings that apply to an entire ArcGIS web map in the Map properties pane. You can enable a background color to improve your users’ experience interacting with your map. You can also view your map title and description and sign out of your ArcGIS organizational account from Map properties pane.
Enable a background color
You can use a background color on its own or in combination with layer blending. In some cases, especially when using a custom basemap, you may need to set a background color for areas the basemap doesn't cover. The basemap color can be part of the overall thematic focus of the map, or it can be a color that corresponds with organizational themes.
To access ArcGIS Maps for Fabric, you must have a supported ArcGIS organizational account. By signing in with your ArcGIS organizational account, you can access your ArcGIS Online content as well as your organization's content, basemaps, and ArcGIS Living Atlas layers. You cannot access ArcGIS Maps for Fabric with an ArcGIS Public account.
To enable a background color, do the following:
Tip:
Confirm that your ArcGIS organizational account user type is Creator or higher and that your user role is Contributor or higher in the Microsoft Fabric workspace where you are working to save changes to the map.
Open ArcGIS Maps for Fabric and sign in to your ArcGIS organizational account.
On the Contents toolbar, click Map properties
.In the Background section of the Map properties pane, turn on the Enable background color toggle button.
The color picker appears.
Select a color from the color picker or type an RGB, HSV, or hexadecimal value in the text box. Click Add
to save a custom color and click Remove
to remove a saved color. Colors are saved only for the browser session. Click Done when you are finished selecting a color.The background color changes in real time as you make a color selection. View the background color by zooming out to the map's full extent.
Save the map.
View map information
Your ArcGIS web map's title and description can be viewed from the Map properties pane.
To view map information, do the following:
.In the About section of the Map properties pane you can view the map title and description you set when you created your map.
Tip:
You can edit the map title and description by clicking Settings
on the ribbon menu.
Sign out of your ArcGIS organizational account
You can sign out from your ArcGIS organizational account in the Map properties pane.
To sign out of your ArcGIS organizational account, do the following:
.Click the Sign out button next to your account username.
