ArcGIS web map
You can save maps in ArcGIS Maps for Microsoft Fabric using the ArcGIS web map format.
To make a new map in ArcGIS Maps for Fabric you will have to save a new ArcGIS web map to a workspace in Microsoft Fabric. After you choose a name and location for this file, the ArcGIS web map will appear in the workspace you selected. Learn more about creating a new map and how to create a new map from within the ArcGIS Maps for Fabric workload.
Open an ArcGIS web map
To open an existing ArcGIS web map:
  1. Navigate to the map you would like to open within your Microsoft Fabric workspace.
  2. Double click on the ArcGIS web map.
    ArcGIS Maps for Fabric opens with the selected map loaded.
You can also open an existing ArcGIS web map from inside the ArcGIS Maps for Fabric workload.
Manage ArcGIS web maps in Microsoft Fabric
You can move or delete ArcGIS web maps from your Microsoft Fabric workspace.
To move an existing map owned by you or someone else within your organization to another workspace:
  1. Navigate to the map you would like to move within your Microsoft Fabric workspace.
  2. Open the More options More options menu.
  3. Click Move to Move to and choose a new workspace.
    The ArcGIS web map is moved to the selected workspace.
To delete an existing map owned by you or someone else within your organization:
  1. Navigate to the map you would like to delete within your Microsoft Fabric workspace.
  3. Click Delete Delete.
    The ArcGIS web map is deleted.
    Tip:
    You can restore deleted items from the Recycle bin in your workspace.
You can copy an existing map between and within Microsoft Fabric workspaces from the ArcGIS Maps for Fabric workload.
Considerations
If you would like other users in your Microsoft Fabric tenant to access your ArcGIS web map, be sure to save it in a workspace that those users can access. Learn more about sharing a map.
