Common upgrade questions
Answers to frequently asked questions about upgrading ArcGIS Maritime server are provided below.
If I have a multimachine server deployment, do I need to upgrade each machine?
Do I need to back up anything before installing the Maritime server extension?
Do I need to stop my GIS services and ArcGIS Server before installing the Maritime server extension?
If I upgrade to ArcGIS Server 12.0, do I also need to upgrade my Mapping and Charting Solutions?
Yes, all machines in a multimachine deployment must be upgraded to the same version of ArcGIS GIS Server and the Maritime server extension.
Do I need to uninstall a previous version of Maritime server before installing the Maritime server extension?
No, if you already have Maritime server installed, the Maritime server extension setup will automatically upgrade it to ArcGIS Maritime 12.0. After the upgrade, you will only see the ArcGIS Maritime 12.0 server extension in your list of programs.
Yes, previous versions of Maritime Chart Service do not come with an installer and need to be manually removed. Refer to Upgrade Maritime Chart Service for details.
You do not need to back up anything before the first installation of ArcGIS Maritime. If you are upgrading Maritime server, refer to Upgrade Maritime Chart Service for details.
No, the setup restarts ArcGIS Server after the installation.
No, the installation process does not require services to be stopped.
Yes, the version of the Maritime server extension must match ArcGIS Server. You cannot run mismatched versions of software. When you upgrade, you will no longer see Mapping and Charting Solutions; the ArcGIS Maritime server extension will appear in your programs list instead.
No. There are no Mapping and Charting Solutions components installed with Maritime Chart Service for Linux.
