Download ArcGIS Mission Responder
This workflow describes how to begin using ArcGIS Mission Responder. It assumes that you have access to ArcGIS Mission Responder but have not yet installed it on your device.
Acquire the app
ArcGIS Mission Responder is a mobile app for use with both Android and iOS smartphones, although the specific device you use is determined by organizational requirements. Esri mobile apps are available through the respective mobile app stores, but your organization may provide the app to you through an MDM managed organizational environment.
For version 10.9.1 and prior ArcGIS Mission Responder is version dependent meaning that you must download the corresponding version of the application with the enterprise version that supports it. Versions 11.0 and later will work with the current app store version
ArcGIS Mission Responder. This application will be the only version of the application in the app store eventually. As enterprise versions 11.1 and earlier are retired, we will remove the version dependent applications from each of the respective stores.
App versions
Using the table below, ensure that your version of Responder matches the version of ArcGIS Mission and ArcGIS Enterprise you are using.
Enterprise version |
10.9.1 |
11.0 and up |
Responder version |
21.2.0 |
26.1 |
While you can find the latest versions of Responder on the app stores, if a different version is required, it is recommended that you download older versions from Esri to a workstation and side-load it onto your device. To do so, follow these steps:
Click the following link while signed in with your ArcGIS account: https://appsforms.esri.com/products/download/index.cfm?fuseaction=download.all#ArcGIS_Server.
Run the
.exefile, extracting the.apkfile to your machine.Transfer the
.apkfile to the device.Tap the
.apkfile to install it.
Open the app
Upon opening the app, the splash screen displays the app title and attempts to connect to your ArcGIS account. If it cannot do so, you are prompted to sign in with your ArcGIS account.
This prompt appears under the following circumstances:
This is your first time signing in to the app from this device.
The app was updated or otherwise changed since your last sign in.
You signed out of the app before closing it after a previous use.
ArcGIS Mission Responder does store your login credentials and does not ask you to provide them every time you sign in. For security reasons, your organization may require that you sign out of the app after every use.
Sign in
If you are prompted to sign in, tapping Sign In prompts you to provide your portal URL.
Your portal URL is provided to you by your organization and reflects the URL used by ArcGIS Mission Manager. Its format is similar to https://myorganization.me.com/portal/
To enter the portal, type your portal URL and tap Continue. Alternatively, you can use your device's QR code reader to sign in to your portal. If you are using an iOS device, you can also scan the text of a portal address. For convenience, if you have multiple mission portals, every time a new portal address is entered and accessed, that portal URL will persist in a drop-down menu on the login screen.
When you have entered the portal, you will be prompted to provide your ArcGIS login credentials. This login information can be your personal ArcGIS account, or it may have been generated by your organization specifically for use in ArcGIS Mission.
After entering your ArcGIS account information and selecting Sign In, you are taken to the mission list and can engage in a mission.
Supported operating systems
ArcGIS Mission Responder supports the following mobile operating systems:
iOS—The most current major release and the previous major release are supported. Users are encouraged to keep their devices up to date to ensure compatibility and security. For additional information, see the System Requirements for 200.0 and later in ArcGIS Maps SDK for Swift.
Android—Devices running Android versions that are actively receiving security updates from the Android Open Source Project (AOSP) are supported. This ensures the application remains secure and reliable on supported platforms. For additional information, see the System Requirements for 200.0 and later in ArcGIS Maps SDK for Kotlin.
Supported user types
ArcGIS Mission Responder works with user accounts of the following user types
Contributor
Mobile Worker
Creator
Professional
Professional Plus
