Configure AI settings
Administrators can allow external artificial intelligence (AI) clients that are compatible with the Model Context Protocol (MCP) to connect to ArcGIS Monitor and query live ArcGIS Monitor data. You can turn external AI client access on or off and limit the sensitive data that ArcGIS Monitor returns to AI clients on the Administration page.
Beta:
External AI client access through Model Context Protocol (MCP) is in beta. Settings, tools, and supported AI clients may change in later releases. Documentation, feedback, and support for the beta are available on the Esri Early Access Community site. To learn more, see Beta features.
You must be assigned the Administrator role to change AI settings.
MCP is an open standard that defines how AI applications connect to external systems, such as ArcGIS Monitor, to retrieve data and use tools.
Learn more about MCP
External AI client access allows AI clients to connect to the MCP endpoint on ArcGIS Monitor Server. External AI client access is turned off by default.
After you turn on external AI client access, you must issue an API key and configure each AI client before it can connect to ArcGIS Monitor. For instructions, see the ArcGIS Monitor MCP beta documentation on the Esri Early Access Community site.
Data shared with AI providers
When an AI client uses ArcGIS Monitor tools, the AI client sends your questions and the tool results to its language model provider. Tool results can include the following information:
  • Component names, types, statuses, and URLs
  • Host names, internal addresses, and system identifiers
  • Alert details, metric values, and log messages
  • Usage session details, including user names and client IP addresses
The AI client, your agreement with the AI provider, and the policies of your organization determine how the AI provider stores, retains, and uses this data. ArcGIS Monitor does not control data after it is returned to the AI client. To reduce the data that is shared, see Limit sensitive data.
Important:
Confirm that your agreement with the AI provider and the policies of your organization permit sharing ArcGIS Monitor data before you turn on external AI client access.
Turn on external AI client access
To turn on external AI client access, complete the following steps:
  1. Access ArcGIS Monitor if necessary.
    The Home page appears.
  2. Click Administration.
    The Administration page appears.
  3. Click AI on the side of the Administration page.
    The AI page appears.
  4. In the External AI client access section, turn on the Enable MCP toggle button.
    External AI client access is turned on, and AI clients with a valid API key can connect to ArcGIS Monitor.
Turn off external AI client access
When you turn off external AI client access, the following occurs:
  • ArcGIS Monitor disconnects all connected AI clients.
  • ArcGIS Monitor rejects new connections to the MCP endpoint.
  • ArcGIS Monitor keeps existing API keys. When you turn external AI client access back on, AI clients can connect with their existing API keys until the keys expire or you revoke them.
To turn off external AI client access, complete the following steps:
  4. In the External AI client access section, turn off the Enable MCP toggle button.
    External AI client access is turned off, and connected AI clients are disconnected.
You can remove sensitive fields from MCP tool results before ArcGIS Monitor returns them to AI clients. When the setting is turned on, ArcGIS Monitor makes the following changes:
  • Component results do not include internal addresses or system identifiers.
  • Usage session results do not include user names or client IP addresses.
The Remove sensitive data from MCP results setting is off by default and applies to all AI clients.
The setting does not remove sensitive information that appears inside other values, such as log messages or component names.
To limit sensitive data in MCP tool results, complete the following steps:
  4. In the External AI client access section, turn on the Remove sensitive data from MCP results toggle button.
    ArcGIS Monitor removes sensitive fields from tool results for all AI clients.
