Collection feature service schema
ArcGIS Monitor collections allow you to make collection data available for use in other ArcGIS applications, such as ArcGIS Dashboards. The following sections list the tables available in the collection feature service.
Hosts
The Hosts table contains attributes for all host components within a collection.
Name |
Description |
Nullable |
Type |
address_internal |
The network address of the host |
False |
String |
class |
The underlying classification and size of the host, if applicable |
True |
String |
cpu_cores_logical |
The CPU's total number of logical cores as reported by the host component's operating system (OS) |
True |
Float |
cpu_cores_physical |
The CPU's total number of physical cores as reported by the host component's OS |
True |
Integer |
cpu_name |
The CPU's vendor and type as reported by the host component's OS |
True |
String |
cpu_speed |
The CPU speed as reported by the host component's OS |
True |
Float |
created_at |
The date and time the host component was registered |
False |
Datetime |
description |
The long-form description of the host component |
True |
String |
id |
The primary key for the host component |
False |
Integer |
location |
The host component's cloud region, if applicable |
True |
String |
memory_page_total |
The total pagefile or swap memory resources available |
True |
Float |
memory_total |
The total amount of physical memory as reported by the host component's OS |
True |
Float |
name |
The name of the host component |
False |
String |
network_speed |
The negotiated network speed as reported by the host component's OS |
True |
Float |
started_at |
The last boot time recorded by the host component's OS |
True |
Datetime |
status |
The current alert status of the host component |
False |
Integer |
subtype |
The host component's OS type (Windows or Linux) |
False |
String |
system_id |
The ID used to uniquely identify the host component within its monitoring scope |
False |
String |
type |
The primary category used to categorize the host component |
False |
String |
version |
The host component's OS version |
True |
String |
Databases
The Databases table contains attributes for all database and geodatabase components in a collection.
Name |
Description |
Nullable |
Type |
address_internal |
The network address of the database component |
False |
String |
connections_max |
The maximum number of connections |
False |
Integer |
created_at |
The date and time the database component was registered |
False |
Datetime |
description |
The long-form description of the database component |
True |
String |
gdb_version |
The underlying geodatabase schema version of the database component, if applicable |
True |
String |
id |
The primary key for the database component |
False |
Integer |
last_backup_at |
The date and time the database was last backed up |
True |
Datetime |
memory_total |
The total amount of physical memory allocated as reported by the database software |
True |
Float |
name |
The name of the database component |
False |
String |
started_at |
The last start time recorded by the database software |
True |
Datetime |
status |
The current alert status of the database component |
False |
Integer |
subtype |
The general database vendor classification (PostgreSQL, Oracle, or SQL Server) |
False |
String |
system_id |
The ID used to uniquely identify the database component within its monitoring scope |
False |
String |
system_mode |
Specifies the state of the system as configured in the database instance:
False |
String |
type |
The primary category used to categorize the database component |
False |
String |
version |
The database component's database software version |
True |
String |
ArcGIS Portals
The ArcGIS Portals table contains attributes for all Portal for ArcGIS components in a collection.
Name |
Description |
Nullable |
Type |
address_internal |
The network address of the Portal for ArcGIS component |
False |
String |
cert_expires_at |
The expiration date and time of the configured SSL certificate for Portal |
True |
Datetime |
created_at |
The date and time the Portal for ArcGIS component was registered |
False |
Datetime |
description |
The long-form description of the Portal for ArcGIS component |
True |
String |
id |
The primary key for the Portal for ArcGIS component |
False |
Integer |
license_expires_at |
The most recent expiration date and time across all configured Portal licenses |
True |
Datetime |
name |
The name of the Portal for ArcGIS component |
False |
String |
started_at |
The last start time recorded by Portal |
True |
Datetime |
status |
The current alert status of the Portal for ArcGIS component |
False |
Integer |
subtype |
The secondary category used to categorize the Portal for ArcGIS component |
True |
String |
system_id |
The ID used to uniquely identify the Portal for ArcGIS component within its monitoring scope |
False |
String |
type |
The primary category used to categorize the Portal for ArcGIS component |
False |
String |
version |
The Portal for ArcGIS component's software version |
True |
String |
Web Applications
The Web Applications table contains attributes for web applications from all Portal for ArcGIS components in a collection.
Attribute name |
Description |
Nullable |
Data type |
access_level |
The shared access level of the web application |
True |
String |
address_internal |
The network address of the web application |
False |
String |
content_status |
The content status of the web application |
True |
String |
created_at |
The date and time the web application was registered |
False |
Datetime |
description |
The long-form description of the web application |
True |
String |
id |
The primary key for the web application |
False |
Integer |
last_modified_at |
The data and time the web application was last modified |
True |
Datetime |
name |
The name of the web application |
False |
String |
owner |
The owner of the web application |
False |
String |
status |
The current alert status of the web application |
False |
Integer |
subtype |
The secondary category used to categorize the web application |
True |
String |
system_created_at |
The date and time the web application was created |
True |
Datetime |
system_id |
The ID used to uniquely identify the web application within its monitoring scope |
False |
String |
type |
The primary category used to categorize the web application |
False |
String |
Web Maps
The Web Maps table contains attributes for web maps from all Portal for ArcGIS components in a collection.
Attribute name |
Description |
Nullable |
Data type |
access_level |
The shared access level of the web map |
True |
String |
address_internal |
The network address of the web map |
False |
String |
content_status |
The content status of the web map |
True |
String |
created_at |
The date and time the web map was registered |
False |
Datetime |
description |
The long-form description of the web map |
True |
String |
id |
The primary key for the web map |
False |
Integer |
last_modified_at |
The data and time the web map was last modified |
True |
Datetime |
name |
The name of the web map |
False |
String |
owner |
The owner of the web map |
False |
String |
status |
The current alert status of the web map |
False |
Integer |
subtype |
The secondary category used to categorize the web map |
True |
String |
system_created_at |
The date and time the web map was created |
True |
Datetime |
system_id |
The ID used to uniquely identify the web map within its monitoring scope |
False |
String |
type |
The primary category used to categorize the web map |
False |
String |
ArcGIS Servers
The ArcGIS Servers table contains attributes for all ArcGIS Server components in a collection.
Name |
Description |
Nullable |
Type |
address_internal |
The network address of the ArcGIS Server component |
False |
String |
cert_expires_at |
The expiration date and time of the configured SSL certificate for ArcGIS Server |
True |
Datetime |
created_at |
The date and time the ArcGIS Server component was registered |
False |
Datetime |
description |
The long-form description of the ArcGIS Server component |
True |
String |
id |
The primary key for the ArcGIS Server component |
False |
Integer |
instances_shared_max |
The configured maximum shared instance pool for ArcGIS Server, if applicable |
True |
Integer |
instances_shared_min |
The configured minimum shared instance pool for ArcGIS Server, if applicable |
True |
Integer |
is_remote |
Specifies whether the ArcGIS Server component is remote |
False |
Boolean |
The most recent expiration date and time across all configured ArcGIS Server licenses |
True |
Datetime |
name |
The name of the ArcGIS Server component |
False |
String |
started_at |
The last start time recorded by ArcGIS Server |
True |
Datetime |
status |
The current alert status of the ArcGIS Server component |
False |
Integer |
subtype |
The secondary category used to categorize the ArcGIS Server component |
True |
String |
system_id |
The ID used to uniquely identify the ArcGIS Server component within its monitoring scope |
False |
String |
type |
The primary category used to categorize the ArcGIS Server component |
False |
String |
version |
The ArcGIS Server software version |
True |
String |
Services
The Services table contains attributes for GIS services from all ArcGIS Server components in a collection.
Name |
Description |
Nullable |
Type |
address_internal |
The network address of the service |
False |
String |
created_at |
The date and time the service was registered |
False |
Datetime |
description |
The long-form description of the service |
True |
String |
id |
The primary key for the service |
False |
Integer |
idle_time_max |
The service's configured SOC idle time-out, if applicable |
True |
Integer |
instance_type |
The underlying service provider (shared, dedicated, or hosted) |
True |
String |
instances_max |
The service's configured maximum SOC instances, if applicable |
True |
Integer |
instances_min |
The service's configured minimum SOC instances, if applicable |
True |
Integer |
is_remote |
Specifies whether the service is remote |
False |
Boolean |
is_service_cached |
Specifies whether the service is a map or a vector cache |
True |
Boolean |
name |
The name of the service |
False |
String |
status |
The current alert status of the service |
False |
Integer |
subtype |
The general service classification (map, geoprocessing, and so on) |
False |
String |
system_id |
The ID used to uniquely identify the service within its monitoring scope |
False |
String |
system_state |
The configured state of the service (stopped or running) |
True |
String |
type |
The primary category used to categorize the service |
False |
String |
wait_time_max |
The service's configured SOC wait time-out, if applicable |
True |
Integer |
Metrics
The Metrics table contains attributes for metrics that are associated with components in a collection.
Name |
Description |
Nullable |
Type |
component_id |
The unique ID of the component associated with the metric |
False |
Integer |
component_name |
The name of the component associated with the metric |
False |
String |
description |
The long-form description of the metric |
True |
String |
id |
The primary key of the metric |
False |
Integer |
name |
The name of the metric |
False |
String |
observed_at |
The date and time the metric was measured |
False |
Datetime |
observer_id |
The unique ID of the observer that recorded the metric |
False |
Integer |
r_id |
The namespaced reference ID of the metric |
False |
String |
status |
The current alert status of the metric |
False |
Integer |
unit |
The unit of measure used to describe the metric, if applicable |
True |
String |
value |
The metric's measured value |
False |
Float |
Alerts
The Alerts table contains attributes for alerts that are associated with components in a collection.
Name |
Description |
Nullable |
Type |
aggregation |
The mathematical function used to aggregate metric samples for comparison with the alert rule |
True |
String |
closed_at |
The date and time the alert was closed |
True |
Datetime |
component_address |
The IP address, host name, or URL of the component associated with the alert |
False |
String |
component_id |
The unique ID of the component associated with the alert |
False |
Integer |
component_name |
The name of the component associated with the alert |
False |
String |
component_subtype |
The subtype of component associated with the alert |
False |
String |
component_type |
The type of component associated with the alert |
False |
String |
created_at |
The date and time the alert was created |
False |
Datetime |
critical_threshold |
The metric threshold value that results in a critical alert being opened |
True |
Float |
duration |
The alert's duration in minutes |
False |
Integer |
id |
The primary key of the alert |
False |
Integer |
info_threshold |
The metric threshold value that results in an info alert being opened |
True |
Float |
metric_id |
The unique ID of the metric associated with the alert |
False |
Integer |
metric_name |
The name of the metric associated with the alert |
False |
String |
metric_r_id |
The reference ID of the metric associated with the alert |
False |
String |
metric_unit |
The ID of the metric associated with the alert |
False |
String |
observer_id |
The unique ID of the observer associated with the component that triggered the alert |
False |
Integer |
opened_at |
The date and time the alert was first opened |
False |
Datetime |
operator |
The mathematical operator used to compare the aggregated metric samples against the alert thresholds |
True |
String |
samples |
The total number of consecutive historical metric samples used to determine the alert's status |
True |
Integer |
state |
The current state of the alert |
False |
String |
status |
The status of the alert when it was opened |
False |
Integer |
warning_threshold |
The metric threshold value that results in a warning alert being opened |
True |
Float |
Connectors
The Connectors table contains attributes for connector components in a collection.
Name |
Description |
Nullable |
Type |
address_internal |
The network address of the connector |
False |
String |
created_at |
The date and time the connector was registered |
False |
Datetime |
description |
The long-form description of the connector |
True |
String |
id |
The primary key of the connector |
False |
Integer |
name |
The name of the connector |
False |
String |
status |
The current alert status of the connector |
False |
Integer |
subtype |
The secondary category used to categorize the connector |
True |
String |
system_id |
The ID used to uniquely identify the connector within its monitoring scope |
False |
String |
system_state |
The state of the connector |
False |
String |
type |
The primary category used to categorize the connector |
False |
String |
Storage
The Storage table contains attributes for storage components in a collection.
Name |
Description |
Nullable |
Type |
address_internal |
The network address of the storage component |
False |
String |
created_at |
The date and time the storage component was registered |
False |
Datetime |
description |
The long-form description of the storage component |
True |
String |
id |
The primary key of the storage component |
False |
Integer |
name |
The name of the storage component |
False |
String |
status |
The current alert status of the storage component |
False |
Integer |
storage_total |
The total amount of storage space |
False |
Float |
subtype |
The secondary category used to categorize the storage component |
True |
String |
system_id |
The ID used to uniquely identify the storage component within its monitoring scope |
False |
String |
type |
The primary category used to categorize the storage component |
False |
String |
ArcGIS Data Stores
The Data Stores table contains attributes for ArcGIS Data Store components in a collection.
Name |
Description |
Nullable |
Type |
address_internal |
The network address of the Data Store component |
False |
String |
connections_max |
The maximum number of connections that can be open at one time |
False |
Integer |
created_at |
The date and time the Data Store component was registered |
False |
Datetime |
description |
The long-form description of the Data Store component |
True |
String |
id |
The primary key of the Data Store component |
False |
Integer |
last_backup_at |
The last time Data Store was backed up |
True |
Datetime |
memory_total |
The total amount of memory (RAM) allocated to Data Store |
False |
Integer |
name |
The name of the Data Store component |
False |
String |
started_at |
The date and time Data Store was last started |
False |
Datetime |
status |
The current alert status of the Data Store component |
False |
Integer |
subtype |
The secondary category used to categorize the Data Store component |
True |
String |
system_id |
The ID used to uniquely identify the Data Store component within its monitoring scope |
False |
String |
system_mode |
Specifies the mode of the system:
False |
String |
type |
The primary category used to categorize the Data Store component |
False |
String |
version |
The software version of Data Store |
False |
String |
