Manage collections
You can view and manage collections on the Collections page and access a collection's Overview, Components, Observers, Metrics, Alerts, and Settings pages by clicking the name of a collection. The Overview page provides information about status, collected attributes, important metrics, and the number of open alerts. The Components page provides a list of the collection's components and their individual alert status. The Observers page provides a list of observers for components that are associated with the collection. The Alerts page provides a list of alerts for components that are associated with the collection. The Metrics page provides a list of metrics for components that are associated with the collection. The Settings page allows you to edit the name, description, and feature service settings for a collection; edit the expression; and configure notifications and incidents specific to that collection.
Learn more about the collection feature service schema
View collection details
You can view collection details on the collection's Overview page and view a list of its components on its Components page.
To view a collection's details and its components, complete the following steps:
  1. Access ArcGIS Monitor if necessary.
    The Home page appears.
  2. Click Collections.
    The Collections page appears with one of the following status indicators displayed next to each collection name:
    Status
    Icon
    Incident active
    There is an active incident and monitoring and alerting are paused for all components in the collection.
    Monitoring off
    One or more observers are turned off and monitoring is disabled.
    Alerting off
    Alerting is turned off for all metrics in the collection.
    No data
    Observers for all metrics in the collection failed to collect data.
    Nominal
    No alerts are open.
    Info
    There is an open info alert.
    This may require further investigation.
    Warning
    There is an open warning alert.
    This requires further investigation.
    Critical
    There is an open critical alert.
    This requires immediate investigation.
    The status of a collection is inherited from its components and reflects the status of the component with the most severe status.
  3. Optionally, do any or all of the following:
    • Click a category on the side of the page to filter the list by that category.
    • Click Sort and change the sorting method.
    • Click Filter and create a query to filter the list.
    • Type a keyword in the Search by collection name or description text box to search for specific collections.
  4. Click the name of the collection you want to view.
    The collection's Overview page appears with collection details and metrics.
  5. Optionally, click the Filter by date drop-down arrow, choose a predefined time range or use the date picker to define a custom time range, and click Apply to constrain the metric data to the specified time range.
  6. Click the Components tab.
    The collection's Components page appears with a list of the collection components sorted alphabetically by name.
    Learn more about managing components
  7. Optionally, do any or all of the following:
    • Click Columns and specify the columns to hide or show.
    • Position the pointer at the edge of a column's header and drag the column's edge to resize it.
    • Click Labels to filter the list by the labels that you choose.
    • Type a keyword in the Search by component name or address text box to search for specific collections.
  8. Optionally, click the Metrics tab to view a list of metrics associated with the collection.
  9. Optionally, click the Observers tab to view a list of observers associated with the collection.
  10. Optionally, click the Alerts tab to view a list of alerts associated with the collection.
Edit collections
You can edit the name and description of a collection on its Settings page. You must be assigned the Administrator or Manager role to edit collections.
To edit a collection, complete the following steps:
    The Collections page appears with a list of collections sorted alphabetically by name.
  4. Click More options for the collection you want to edit and click Edit in settings.
    The collection's Settings page appears.
  5. On the Settings page, in the Collection details section, click Edit.
    The Collection details dialog box appears.
  6. Edit the name and description of the collection in the Collection name and Description text boxes as necessary.
  7. Click Save.
    The collection is updated.
Edit collection feature service settings
You can turn the collection feature service on or off and configure its security settings. You must be assigned the Administrator or Manager role to edit collection feature service settings.
To edit collection feature service settings, complete the following steps:
  4. Click More options for the collection with the feature service you want to edit and click Edit in settings.
  5. On the Settings page, in the Feature service settings section, click Edit.
    The Feature service settings dialog box appears.
  6. Edit the collection's feature service settings as necessary.
  7. Click Save.
    The collection's feature service settings are updated.
Edit collection expressions
You can edit collection expressions from a collection's Settings page. You must be assigned the Administrator or Manager role to edit collection expressions.
To edit a collection expression, complete the following steps:
  4. Click More options for the collection that contains the expression that you want to edit and click Edit in settings.
  5. Click Expression on the side of the page.
    The Expression page appears.
  6. Click Edit.
    The expression builder changes to edit mode.
  7. Edit the expression as necessary.
  8. Optionally, click Test and click the Results tab to show a list of components that match the expression.
  9. Click Save.
    The collection expression is updated.
Add a collection to your favorites
You can add collections that you want to closely monitor to your favorites and access them using the Favorites category filter on the Collections page.
To add a collection to your favorites, complete the following steps:
  4. Click Add to favorites next to a collection to add it to your favorites.
    Tip:
    To remove a collection from your favorites list, click Remove from favorites .
Delete a collection
When a collection is deleted, it is also removed from linked notifications and incidents. All the components in the collection remain registered, retain their labels, and are still subject to qualifying incidents and custom notifications. You must be assigned the Administrator or Manager role to delete collections.
To delete a collection, complete the following steps:
  3. Click More options for the collection you want to delete and click Delete.
    A confirmation dialog box appears.
    Caution:
    Deleting a collection is permanent and can't be undone.
  4. Click Delete.
The collection is deleted. All components in the collection remain registered and retain their labels. The collection is also deleted from linked notifications and analyses.
