Metrics reference
The sections below list the metrics that are collected for each component type in ArcGIS Monitor.
Amazon Web Services (AWS)
The subsections below describe the metrics that are collected for AWS and tagged RDS resources.
AWS metrics
The following table lists the metrics that are collected for AWS:
Metric name
Data type
Unit
Connectivity
The agent's ability to successfully connect to the component.
Float
Percent
CPU utilized
The average proportion of CPU resources in use across all monitored AWS components.
Values approaching 100 percent may indicate that more resources are needed to handle the workload.
Float
Percent
Memory Available
The cumulative amount of available physical memory across all monitored AWS components.
Float
Gigabytes
Memory Used
The cumulative amount of memory in use across all monitored AWS components.
Float
Gigabytes
Memory Utilized
The average proportion of memory in use across all monitored AWS components.
Float
Percent
Network Incoming
The cumulative rate of network data received across all monitored AWS components.
Float
Megabits/second
Network Incoming Utilized
The average proportion of incoming network bandwidth in use across all monitored AWS components.
Float
Percent
Network Outgoing
The cumulative rate of network data sent across all monitored AWS components.
Float
Megabits/second
Network Outgoing Utilized
The average proportion of outgoing network bandwidth in use across all monitored AWS components.
Float
Percent
Storage Capacity Available
The cumulative amount of available storage space across all monitored AWS components.
Float
Gigabytes
Storage Capacity Used
The cumulative amount of storage space in use across all monitored AWS components.
Float
Gigabytes
Storage Capacity Utilized
The average proportion of storage capacity in use across all monitored AWS components.
Float
Percent
Storage Read Rate
The cumulative speed at which data is read from the disk across all monitored AWS components.
Float
Gigabytes/second
Storage Write Rate
The cumulative speed at which data is written to the disk across all monitored AWS components.
Float
Gigabytes/second
RDS metrics
The following table lists the metrics that are collected for RDS resources:
Metric name
Data type
Unit
CPU utilized
The proportion of CPU resources in use.
Float
Percent
Memory Available
The total amount of available physical memory.
Float
Gigabytes
Memory Used
The amount of memory in use.
Float
Gigabytes
Memory Utilized
The proportion of memory in use.
Float
Percent
Network Incoming
The rate of network data received.
Float
Megabits/second
The proportion of incoming network bandwidth in use.
Float
Percent
Network Outgoing
The rate of network data sent.
Float
Megabits/second
The proportion of outgoing network bandwidth in use.
Float
Percent
The amount of available storage space.
Float
Gigabytes
The amount of storage space in use.
Float
Gigabytes
The proportion of storage capacity in use.
Float
Percent
Storage Read Rate
The speed at which data is read from the disk.
Float
Gigabytes/second
Storage Write Rate
The speed at which data is written to the disk.
Float
Gigabytes/second
ArcGIS Data Store
The subsections below describe the metrics that are collected for Data Store and its underlying datasets.
Data store metrics
The following table lists the metrics that are collected for a data store:
Metric name
Data type
Unit
Cache Hit
The percentage of requests served from the cache, as opposed to requests served from disk.
Float
Percentage
Connectivity
Float
Percent
Database Connections
The total number of active connections.
Float
Percent
Database Connections Utilized
The proportion of allocated database connections in use.
Values approaching 100 may indicate that the current allocation is insufficient.
Float
Percent
Datasets
The total number of datasets.
Float
Total
Open Cursors
The number of open cursors in the database.
Float
Total
Rows Total
The total number of rows in all tables in the database.
Float
Total
Storage Used
The total amount of storage used by all tables in the database.
Float
Total
Data store dataset metrics
The following table lists the metrics that are collected for datasets in a data store:
Metric name
Data type
Unit
Rows Total
The total number of rows in the dataset
Float
Total
Storage Used
The total amount of storage used by the dataset
Float
Total
ArcGIS GeoEvent Server
The subsections below describe the metrics that are collected for GeoEvent Server and its connectors and services.
GeoEvent Server metrics
The following table lists the metrics that are collected for GeoEvent Server:
Metric name
Data type
Unit
Connectivity
Float
Percent
Connectors
The total number of GeoEvent Server connectors.
Float
Total
Events Received
The total number of received events.
Float
Total
Events Received Rate
The receive rate of received events.
Float
Events/second
Events Sent
The total number of sent events.
Float
Total
Events Sent Rate
The send rate of sent events.
Float
Events/second
Events Total Ratio
The ratio of all sent to received events.
Values approaching one indicate the rate of sent events is equal to that of received events.
Float
Total
Events Rate Ratio
The ratio of sent to received event rates.
Float
Total
Services
The total number of GeoEvent Server services.
Float
Total
GeoEvent Server connector and service metrics
The following table lists the metrics that are collected for GeoEvent Server connectors and services:
Metric name
Data type
Unit
Events Received
Float
Total
Float
Events/second
Events Sent
Float
Total
Events Sent Rate
Float
Events/second
ArcGIS Online organization
The subsections below describe the metrics that are collected for the remote ArcGIS Server site and its monitored services.
ArcGIS Online organization metrics
The following table lists the metrics that are collected for the ArcGIS Online organization:
Metric name
Data type
Unit
Connectivity
Float
Percent
Response Code
The request HTTP response code
Float
Total
Response Size
The size of the response payload
Float
Kilobytes
Response Time
The response time of the ArcGIS Online organization
Float
Seconds
ArcGIS Online organization web services metrics
The following table lists the metrics that are collected for the ArcGIS Online organization's monitored web services:
Metric name
Data type
Unit
Connectivity
The agent's ability to successfully connect to the web service
Float
Percent
Response Code
Float
Total
Response Size
Float
Kilobytes
Response Time
The response time of the web service
Float
Seconds
Metric name
Data type
Unit
Connectivity
The agent's ability to successfully connect to the web service.
Float
Percent
Response Code
The request HTTP response code.
Float
Total
Response Size
The size of the response payload.
Float
Kilobytes
Response Time
The response time of the web service.
Float
Seconds
ArcGIS Online organization web services optional metrics
The following table lists the optional metrics that can be collected by configuring the Check - Remote Service observer for remote ArcGIS Server services:
Metric name
Data type
Unit
Check Response Code - <observer_name>
Float
Total
Check Response Matches - <observer_name>
The total number of matches returned by the regular expression defined in the observer.
If no regular expression is defined, a null value is returned.
Float
Total
Check Response Size - <observer_name>
Float
Kilobytes
Check Response Time - <observer_name>
The response time of the check.
Float
Seconds
ArcGIS Server
The subsections below describe the metrics that are collected for the ArcGIS Server site and its underlying services.
ArcGIS Server metrics
The following table lists the metrics that are collected for the ArcGIS Server site:
Metric name
Data type
Unit
Connectivity
Float
Percent
Instances Saturation Percent
The percentage of maximum configured service instances in use.
This metric is calculated by dividing the service's busy time with its maximum potential busy time, and multiplying this value by 100.
The service busy time is calculated by multiplying the service's average response time (RT) by the number of requests (RR) over the interval.
The maximum potential busy time is calculated by multiplying the service's maximum configured instances (IC) by the interval (I).
The following is an example:
(RT*RR)/(IC*I)*100
(0.1*1000)/(2*60)*100
83% of maximum configured service instances
Values approaching 100 percent may indicate that more instances are needed to handle incoming service requests.
Float
Percent
Instances Used
The total number of service instances in use.
This metric is calculated by dividing the instances saturation percent metric value (ISP) by 100, and multiplying this value by the maximum configured instances (IC).
The following is an example.
(ISP/100)*IC
(83/100)*2
1.66 instances used
Float
Total
Request Rate
The average request rate of all ArcGIS Server site services.
Float
Requests/second
Request Response Time Avg
The average response time of all ArcGIS Server site services.
Float
Seconds
Request Response Time Max
The maximum response time of all ArcGIS Server site services.
Float
Seconds
Request Wait Time Average
The average time that all requests waited for an available ArcSOC instance over a period of time (total wait time for all requests divided by the number of requests).
Float
Seconds
Request Wait Time Max
The maximum time that a service request waited for an available ArcSOC instance over the specified period.
Float
Seconds
Request Wait Time Min
The minimum time that a service request waited for an available ArcSOC instance over the specified period.
Float
Seconds
Requests Error Percent
The percentage of failed and timed-out requests of all ArcGIS Server site services.
Float
Percent
Requests Failed
The total number of failed requests of all ArcGIS Server site services.
Float
Total
Requests Received
The total number of received requests of all ArcGIS Server site services.
Float
Total
Requests Timed Out
The total number of timed-out requests of all ArcGIS Server site services.
Float
Total
Services
The total number of ArcGIS Server services.
Float
Total
Site Machines Availability
The total percentage of machines that are available in the ArcGIS Server site.
Values under 100 percent indicate that some of the machines in the site are unavailable for processing and may require further investigation.
Float
Percent
ArcGIS Server services metrics
Monitor collects information about the following ArcGIS Server service types:
  • Feature
  • Geocode
  • Geodata
  • Image
  • Map
  • Network Analyst
  • Geoprocessing
The following table lists the metrics that are collected for the ArcGIS Server site's underlying services:
Metric name
Data type
Unit
Float
Percent
Instances Used
Float
Total
Request Rate
The service's average request rate.
Float
Requests/second
The service's average response time.
Float
Seconds
The service's maximum response time.
Float
Seconds
The percentage of failed and timed-out service requests.
Float
Percent
Requests Failed
The total number of failed service requests.
Float
Total
Requests Received
The total number of received service requests.
Float
Total
Requests Timed Out
The total number of service requests that timed out.
Float
Total
CPU Utilized
The average percentage of CPU resources used by the service's ArcSOC processes across all machines in the site.
This metric only applies to services with a dedicated instance type. Services with a shared or hosted instance type are not included.
Higher values may indicate that more CPU resources are needed to handle the current workload. This metric can help determine whether to adjust the number of configured service instances to better balance workload with available resources.
Float
Percent
CPU Utilized - <machine_name>
The percentage of CPU resources used by the service's ArcSOC processes on the machine.
For sites with multiple machines, a separate metric is reported for each machine. The metric name includes the machine name (for example, CPU Utilized - SERVER1.DOMAIN.COM).
Float
Percent
Memory Utilized
The average percentage of memory used by the service's ArcSOC processes across all machines in the site.
Higher values may indicate that more memory resources are needed to handle the current workload. This metric can help determine whether to adjust the number of configured service instances to better balance workload with available resources.
Float
Percent
Memory Utilized - <machine_name>
The percentage of memory used by the service's ArcSOC processes on the machine.
For sites with multiple machines, a separate metric is reported for each machine. The metric name includes the machine name (for example, Memory Utilized - SERVER1.DOMAIN.COM).
Float
Percent
ArcGIS Server services optional metrics
The following table lists the optional metrics that can be collected by configuring the Check - Service observer for ArcGIS Server services:
Metric name
Data type
Unit
Float
Total
Float
Total
Float
Kilobytes
Float
Seconds
ArcGIS Server (Remote)
ArcGIS Server (Remote) metrics
The following table lists the metrics that are collected for the remote ArcGIS Server site:
Metric name
Data type
Unit
Connectivity
Float
Percent
Response Code
Float
Total
Response Size
Float
Kilobytes
Response Time
The response time of the ArcGIS Server site
Float
Seconds
Remote ArcGIS Server services metrics
The following table lists the metrics that are collected for the remote ArcGIS Server site's monitored services:
Metric name
Data type
Unit
Connectivity
The agent's ability to successfully connect to the service
Float
Percent
Response Code
Float
Total
Response Size
Float
Kilobytes
Response Time
The response time of the service
Float
Seconds
Remote ArcGIS Server services optional metrics
Metric name
Data type
Unit
Float
Total
Float
Total
Float
Kilobytes
Float
Seconds
Linux hosts
The subsections below describe the metrics that are collected for Linux hosts.
Host metrics
The following table lists the metrics that are collected for Linux hosts:
Metric name
Data type
Unit
Connectivity
Float
Percent
CPU Cores Utilized
The number of logical CPU cores in use.
Float
Total
CPU Utilized
Float
Percent
Memory Available
The total amount of physical memory available.
Float
Gigabytes
Memory Used
Float
Gigabytes
Memory Utilized
Float
Percent
Network Incoming
Float
Megabits/second
Float
Percent
Network Outgoing
Float
Megabits/second
Float
Percent
Pagefile Available
The total pagefile or swap memory resources available.
Float
Gigabytes
Pagefile Used
The total pagefile or swap memory resources in use.
Float
Gigabytes
Pagefile Utilized
The proportion of pagefile or swap memory resources in use.
Float
Percent
Process metrics
Monitor collects information about the following processes:
  • arcgisserver
  • arcsoc
  • arcgisportal
  • geoeventserver
  • python
  • sqlserver
  • postgres
  • oracle
The following table lists the metrics collected for a Linux host's processes:
Metric name
Data type
Unit
Process CPU Utilized
The proportion of CPU resources in use by the process.
Float
Percent
Process Instances
The total number of process instances that are running.
Float
Total
Process Memory Used
The amount of memory resources in use by the process.
Float
Gigabytes
Process Memory Utilized
The proportion of memory in use by the process.
Float
Percent
Storage metrics
The following table lists the metrics collected for a Linux host's storage resources:
Metric name
Data type
Unit
Float
Gigabytes
Float
Gigabytes
Float
Percent
Storage Read Rate
Float
Gigabytes/second
Storage Write Rate
Float
Gigabytes/second
Oracle databases
The subsections below describe the metrics that are collected for registered databases and geodatabases in Oracle.
Database metrics
The following table lists the metrics that are collected for databases in Oracle:
Metric name
Data type
Unit
Cache Hit
Float
Percent
Connectivity
Float
Percent
The total number of database connections in use
Float
Total
The proportion of database connections in use
Float
Percent
Database Sessions
The number of open sessions in the database
Float
Total
Open Cursors
Float
Total
Storage Used
Float
Total
Geodatabase metrics
The following table lists the metrics that are collected for geodatabases in Oracle:
Metric name
Data type
Unit
Datasets
Float
Total
GDB Branch Version Conflicts
The total number of branch version conflicts in the geodatabase
Float
Total
GDB Branch Version Locks
The total number of locks on branch versions in the geodatabase
Float
Total
GDB Branch Versions
The total number of branch versions in the geodatabase
Float
Total
GDB Connections
The total number of active connections to the geodatabase
Float
Total
GDB Connections - editors
The total number of active editor connections to the geodatabase
Float
Total
GDB Connections - viewers
The total number of active viewer connections to the geodatabase
Float
Total
GDB Default Version Depth
The depth in the state tree of the default version
Float
Total
GDB Shared Locks
The total number of shared table locks in the geodatabase
Float
Total
GDB State Lineages
The total number of edits in the geodatabase for datasets that use traditional versioning
Float
Total
GDB Version States
The total number of states in the geodatabase for datasets that use traditional versioning
Float
Total
GDB Versions
The total number of versions in the geodatabase that use traditional versioning
Float
Total
Rows Total
Float
Total
Storage Used
Float
Total
Geodatabase dataset metrics
The following table lists the metrics that are collected for geodatabase datasets in Oracle:
Metric name
Data type
Unit
Rows Total
Float
Total
Storage Used
Float
Total
To minimize performance impacts on monitored geodatabases, Monitor uses the database's statistics capability to collect dataset metrics. The accuracy of the metrics may diverge as statistics become obsolete and need to be recalculated.
Optional metrics
The following table lists the optional metric that can be collected by configuring the Database Query observer:
Metric name
Data type
Unit
Database Query - <observer_name>
The response of the SQL query
Float
Total
Portal for ArcGIS
The following table lists the metrics that are collected for Portal:
Portal for ArcGIS
The following table lists the metrics collected for Portal for ArcGIS:
Metric name
Data type
Unit
Active Sessions
The total number of active sessions over the interval for all apps in the portal.
Float
Total
Active Session Time
The duration of all active sessions in all of the apps in the portal over the interval.
Float
Time
Connectivity
Float
Percent
Groups
The total number of groups in Portal.
Float
Total
Groups Access - private
The total number of private groups in Portal.
Float
Total
Groups Access - public
The total number of public groups in Portal.
Float
Total
Groups Access - org
The total number of organization groups in Portal.
Float
Total
Health Check Status - federation
The overall status of the federation between Portal and all federated ArcGIS Server machines.
A value of 100% is returned if the status is healthy.
Float
Percent
Health Check Status - index
The overall status of all Portal indexes.
Float
Percent
Items
The total number of items in Portal.
Float
Total
Items Type - app
The total number of app items in Portal.
Float
Total
Items Type - data_store
The total number of ArcGIS Data Store items in Portal.
Float
Total
Items Type - file
The total number of file items in Portal.
Float
Total
Items Type - insight
The total number of ArcGIS Insights items in Portal.
Float
Total
Items Type - layer
The total number of layer items in Portal.
Float
Total
Items Type - map
The total number of map items in Portal.
Float
Total
Items Type - org
The total number of organization items in Portal.
Float
Total
Items Type - private
The total number of private items in Portal.
Float
Total
Items Type - public
The total number of public items in Portal.
Float
Total
Items Type - scene
The total number of scene items in Portal.
Float
Total
Items Type - shared
The total number of shared items in Portal.
Float
Total
Items Type - tool
The total number of tool items in Portal.
Float
Total
Licenses Used - creator
The total number of the Creator user type in Portal.
Float
Total
Licenses Used - editor
The total number of the Contributor user type in Portal.
Float
Total
Licenses Used - field_worker
The total number of the Mobile Worker user type in Portal.
Float
Total
Licenses Used - gis_advanced
The total number of the Professional Plus user type in Portal.
Float
Total
Licenses Used - gis_basic
Float
Total
Licenses Used - gis_standard
The total number of the Professional user type in Portal.
Float
Total
Licenses Used - insight_analyst
The total number of the Insights Analyst user type in Portal.
Float
Total
Licenses Used - storyteller
The total number of the Storyteller user type in Portal.
Float
Total
Licenses Used - viewer
The total number of the Viewer user type in Portal.
Float
Total
Users
The total number of users in Portal.
Float
Total
Users Active - last day
The total number of users that signed in to Portal within the past 24 hours.
Float
Total
Users Active - last hour
The total number of users that signed in to Portal within the last hour.
Float
Total
Users Active - last month
The total number of users that signed in to Portal within the last 30-day period.
Float
Total
Users Active - last week
The total number of users that signed in to Portal within the past week.
Float
Total
Users Active - never
The total number of users that have never signed in to Portal.
Float
Total
Web applications
The following table lists the metrics collected for web apps:
Metric name
Data type
Unit
Active Sessions
The total number of active sessions over the interval for the specific web app.
Float
Total
Active Session Time
The duration of all active sessions in the specific web app over the interval.
Float
Time
Web maps
The following table lists the metrics collected for web maps:
Metric name
Data type
Unit
Active Sessions
The total number of active sessions over the interval for the specific web map.
Float
Total
Active Session Time
The duration of all active sessions in the specific web map over the interval.
Float
Time
PostgreSQL databases
The subsections below describe the metrics that are collected for registered databases and geodatabases in PostgreSQL.
Database metrics
The following table lists the metrics that are collected for databases in PostgreSQL:
Metric name
Data type
Unit
Cache Hit
Float
Percent
Connectivity
Float
Percent
Float
Total
Float
Percent
Open Cursors
Float
Total
Storage Used
Float
Total
Geodatabase metrics
The following table lists the metrics that are collected for geodatabases in PostgreSQL:
Metric name
Data type
Unit
Datasets
Float
Total
Float
Total
Float
Total
GDB Branch Versions
Float
Total
GDB Connections
Float
Total
Float
Total
Float
Total
Float
Total
GDB Shared Locks
Float
Total
GDB State Lineages
Float
Total
GDB Version States
Float
Total
GDB Versions
Float
Total
Rows Total
Float
Total
Storage Used
Float
Total
The following table lists the metrics that are collected for geodatabase datasets in PostgreSQL:
Metric name
Data type
Unit
Rows Total
Float
Total
Storage Used
Float
Total
Optional metrics
Metric name
Data type
Unit
Float
Total
SQL Server databases
The subsections below describe the metrics that are collected for registered databases and geodatabases in SQL Server.
Database metrics
The following table lists the metrics that are collected for databases in SQL Server:
Metric name
Data type
Unit
Cache Hit
Float
Percent
Connectivity
Float
Percent
Float
Total
Float
Percent
Database Sessions
Float
Total
Open Cursors
Float
Total
Storage Used
Float
Total
Geodatabase metrics
The following table lists the metrics that are collected for geodatabases in SQL Server:
Metric name
Data type
Unit
Datasets
Float
Total
Float
Total
Float
Total
GDB Branch Versions
Float
Total
GDB Connections
Float
Total
Float
Total
Float
Total
Float
Total
GDB Shared Locks
Float
Total
GDB State Lineages
Float
Total
GDB Version States
Float
Total
GDB Versions
Float
Total
Rows Total
Float
Total
Storage Used
Float
Total
The following table lists the metrics that are collected for geodatabase datasets in SQL Server:
Metric name
Data type
Unit
Rows Total
Float
Total
Storage Used
Float
Total
Optional metrics
Windows hosts
The subsections below describe the metrics that are collected for Windows hosts.
Host metrics
The following table lists the metrics collected for Windows hosts:
Metric name
Data type
Unit
Connectivity
Float
Percent
CPU Cores Utilized
Float
Total
CPU Utilized
Float
Percent
Memory Available
The total amount of memory available.
Float
Gigabytes
Memory Used
The amount of physical memory in use.
Float
Gigabytes
Memory Utilized
Float
Percent
Network Incoming
Float
Megabits/second
Float
Percent
Network Outgoing
Float
Megabits/second
Float
Percent
Pagefile Available
The total page file or swap memory resources available.
Float
Gigabytes
Pagefile Used
The total page file or swap memory resources in use.
Float
Gigabytes
Pagefile Utilized
The proportion of page file or swap memory resources in use.
Float
Percent
Terminal Sessions
The total number of terminal sessions.
Float
Total
Terminal Sessions Active
The total number of active terminal sessions.
Float
Total
Terminal Sessions Inactive
The total number of inactive terminal sessions.
Float
Total
Process metrics
  • arcgispro.exe
  • arcmap.exe
  • arccatalog.exe
  • arcgisserver.exe
  • arcsoc.exe
  • arcgisportal.exe
  • geoeventserver.exe
  • python.exe
  • powershell.exe
  • sqlserver.exe
  • postgres.exe
  • oracle.exe
The following table lists the metrics collected for a Windows host's processes:
Metric name
Data type
Unit
Float
Percent
Process Instances
The number of process instances that are running.
Float
Total
Process Memory Used
Float
Gigabytes
Float
Percent
Storage metrics
The following table lists the metrics collected for a Windows host's storage resources:
Metric name
Data type
Unit
Float
Gigabytes
Float
Gigabytes
Float
Percent
Storage Read Rate
Float
Gigabytes/second
Storage Write Rate
Float
Gigabytes/second
