Attributes reference
The sections below list the attributes that are collected for each component type in ArcGIS Monitor.
Amazon Web Services (AWS)
The following table lists the attributes that are collected for RDS resources:
Attribute name
Data type
Class
The resource's instance type.
String
CPU cores logical
The CPU's total number of logical cores.
Integer
CPU cores physical
The CPU's total number of physical cores.
Integer
CPU name
The CPU name and model information.
String
CPU speed
The speed of the CPU.
Float
Location
The AWS availability zone.
String
Memory total
The resource's total amount of memory (RAM).
Float
Network speed
The speed of the network.
The network speed is displayed as 1000 Mbps.
Integer
System state
The status of the resource (available, running, or stopped).
String
Storage total
The size of the volume.
Float
Version
The version of the underlying database.
String
ArcGIS Data Store
The subsections below describe the attributes that are collected for Data Store and its underlying datasets.
Data store
The following table lists the attributes that are collected for a data store:
Attribute name
Data type
Connections max
The maximum number of connections that can be open at one time
Integer
Last backup at
The last time the data store was backed up
Datetime
Memory total
The total amount of memory (RAM) allocated to Data Store
Integer
Started at
The date and time Data Store was last started
Datetime
System mode
Specifies the mode of the system:
  • read
  • read/write
String
System state
Specifies the state of the system as it is configured in Data Store:
  • started
  • stopped
String
Version
The software version of Data Store
String
Data store datasets
The following table lists the attributes that are collected for datasets in a data store:
Attribute name
Data type
Geometry type
Specifies the geometry type of the dataset:
  • Line
  • Point
  • Polygon
  • - (None)
String
Is archived
Specifies whether the dataset is archived:
  • No
  • Yes
String
Last modified at
The data and time the dataset was last modified
Datetime
Versioned type
Specifies the dataset's versioned type:
  • Branched
  • Traditional
  • - (None)
String
ArcGIS GeoEvent Server
The subsections below describe the attributes that are collected for GeoEvent Server and its connectors and services.
GeoEvent Server attributes
The following table lists the attribute that is collected for GeoEvent Server:
Attribute name
Data type
Version
The software version of GeoEvent Server
String
GeoEvent Server connector and service attributes
The following table lists the attribute that is collected for GeoEvent Server connectors and services:
Attribute name
Data type
Configured state
The state of the GeoEvent Server connector or service
String
ArcGIS Online Organization
The following table lists the attribute that is collected for remote ArcGIS Online organization web services:
Attribute name
Data type
Is remote
Specifies whether the service is remote.
Boolean
ArcGIS Server
The subsections below describe the attributes that are collected for the ArcGIS Server site and its underlying services.
ArcGIS Server
The following table lists the attributes that are collected for the ArcGIS Server site:
Attribute name
Data type
License expiration
The date and time the ArcGIS Server site's license expires
Datetime
Machines
The list of machines or hosts that participate in the ArcGIS Server site
Array
Roles
The list of ArcGIS Server roles assigned to the ArcGIS Server site
Array
Shared instances max
The maximum number of shared service instances
Integer
Shared instances min
The minimum number of shared service instances
Integer
Started at
The date and time the ArcGIS Server site was last started
Datetime
Version
The software version of the ArcGIS Server site
String
ArcGIS Server services
The following table lists the attributes that are collected for the ArcGIS Server site's underlying services:
Attribute name
Data type
Cached service
Specifies whether data is returned dynamically or returned from a cache when queried.
Boolean
Configured state
Specifies the state of the service as it is configured in ArcGIS Server (started or stopped).
String
Idle time max
The maximum number of seconds a service instance is allowed to persist before it shuts down.
Integer
Instance type
Specifies the infrastructure of the underlying service provider (hosted, shared, dedicated, or custom).
String
Instances max
The maximum number of service instances configured across the ArcGIS Server site.
For hosted and custom instances, this value is always displayed as zero. For shared instances, this value is the maximum number of shared instances configured for the site. For dedicated instances, this is the maximum number of instances configured for the service.
Integer
Instances min
The minimum number of service instances configured across the ArcGIS Server site.
For hosted and custom instances, this value is always displayed as zero. For shared instances, this value is the minimum number of shared instances configured for the site. For dedicated instances, this is the minimum number of instances configured for the service.
Integer
Is remote
Boolean
Wait time max
The maximum number of seconds a client waits to connect to the service before it times out.
Integer
ArcGIS Server (Remote)
The subsections below describe the attributes that are collected for the remote ArcGIS Server site and its monitored services.
The following table lists the attribute that is collected for the remote ArcGIS Server site:
Attribute name
Data type
Version
String
Remote ArcGIS Server services
The following table lists the attribute that is collected for remote ArcGIS Server services:
Attribute name
Data type
Is remote
Boolean
Linux hosts
The subsections below describe the attributes that are collected for Linux hosts.
Host attributes
The following table lists the attributes that are collected for Linux hosts:
Attribute name
Data type
Class
The instance type (virtual or physical)
String
CPU cores logical
Integer
CPU cores physical
Integer
CPU name
String
CPU speed
The speed of the host's CPU
Float
Memory total
The host's total amount of memory (RAM)
Float
Network speed
Integer
Started at
The date and time the host was last started
Datetime
UTC offset
The host's UTC time zone offset
Integer
Version
The software version of the operating system
String
Storage attributes
The following table lists the attribute collected for a Linux host's storage resources:
Attribute name
Data type
Storage total
Float
Oracle databases
The subsections below describe the attributes that are collected for registered databases and geodatabases in Oracle.
Database attributes
The following table lists the attributes that are collected for databases in Oracle:
Attribute name
Data type
Connections max
Integer
Last backup at
The date and time the database was last backed up
Datetime
Memory total
The total amount of system global area (SGA) memory for the database instance
Float
Started at
The last start time of the database instance
Datetime
System mode
Specifies the state of the system as it is configured in Oracle:
  • Read
  • Read Write
String
UTC offset
The UTC time zone offset for the database instance
Integer
Version
The software version of the Oracle instance
String
Geodatabase attributes
The following table lists the attribute that is collected for geodatabases in Oracle:
Attribute name
Data type
Geodatabase version
The version of the enterprise geodatabase
String
Geodatabase dataset attributes
The following table lists the attributes that are collected for geodatabase datasets:
Attribute name
Data type
Geometry type
  • Line
  • Point
  • Polygon
  • - (None)
String
Is archived
  • No
  • Yes
String
Versioned type
  • Branched
  • Traditional
  • - (None)
String
Portal for ArcGIS
The subsections below describe the attributes that are collected for Portal and portal items.
Portal
The following table lists the attributes that are collected for Portal:
Attribute name
Data type
Certificate expiration
The date and time the configured server certificate for Portal expires
Datetime
License expiration
The date and time the Portal license expires
Datetime
Started at
The date and time Portal was last started
Datetime
Version
The software version of Portal
String
Web applications
The following table lists the attributes that are collected for web applications:
Attribute name
Data type
Content status
The content status of the web application
String
Last modified at
The data and time the web application was last modified
Datetime
Owner
The owner of the web application
String
Sharing level
The shared access level of the web application
String
System created at
The date and time the web application was created
Datetime
Web maps
The following table lists the attributes that are collected for web maps:
Attribute name
Data type
Content status
The content status of the web map
String
Last modified at
The data and time the web map was last modified
Datetime
Owner
The owner of the web map
String
Sharing level
The shared access level of the web map
String
System created at
The date and time the web map was created
Datetime
PostgreSQL databases
The subsections below describe the attributes that are collected for registered databases and geodatabases in PostgreSQL.
Database attributes
The following table lists the attributes that are collected for databases in PostgreSQL:
Attribute name
Data type
Connections max
Integer
Memory total
The total amount of physical memory for the database instance
Float
Started at
Datetime
System mode
Specifies the state of the system as it is configured in PostgreSQL:
  • Read
  • Read Write
String
UTC offset
Integer
Version
The software version of the PostgreSQL instance
String
The following table lists the attribute that is collected for geodatabases in PostgreSQL:
Attribute name
Data type
Geodatabase version
String
Attribute name
Data type
Geometry type
  • Line
  • Point
  • Polygon
  • - (None)
String
Is archived
  • No
  • Yes
String
Versioned type
  • Branched
  • Traditional
  • - (None)
String
SQL Server databases
The subsections below describe the attributes that are collected for registered databases and geodatabases in SQL Server.
Database attributes
The following table lists the attributes that are collected for databases in SQL Server:
Attribute name
Data type
Connections max
Integer
Last backup at
Datetime
Memory total
Float
Started at
Datetime
System mode
Specifies the state of the system as it is configured in SQL Server:
  • Read
  • Read Write
String
UTC offset
Integer
Version
The software version of the SQL Server instance
String
The following table lists the attribute that is collected for geodatabases in SQL Server:
Attribute name
Data type
Geodatabase version
String
Attribute name
Data type
Geometry type
  • Line
  • Point
  • Polygon
  • - (None)
String
Is archived
  • No
  • Yes
String
Versioned type
  • Branched
  • Traditional
  • - (None)
String
Windows hosts
The subsections below describe the attributes that are collected for Windows hosts.
Host attributes
The following table lists the attributes that are collected for Windows hosts:
Attribute name
Data type
Class
String
CPU cores logical
Integer
CPU cores physical
Integer
CPU name
String
CPU speed
Float
Memory total
Float
Network speed
Integer
Started at
Datetime
UTC offset
Integer
Version
String
Storage attributes
The following table lists the attribute that is collected for a Windows host's storage resources:
Attribute name
Data type
Storage total
Float
