ArcGIS Monitor Information Model
The ArcGIS Monitor Information Model supports the management of data necessary to monitor the system health, usage, and performance of an enterprise GIS implementation.
The following diagram shows the high-level entity relationships in the information model:
The sections below list the primary tables and fields that compose the information model.
Agents
The Agents table includes the following fields:
Field name |
Display name |
Description |
Nullable |
Type |
address |
Address |
The host name or IP address of the ArcGIS Monitor Agent machine. |
False |
String |
created_at |
Created at |
The date and time the entity was created. |
False |
Datetime |
description |
Description |
The long-form description of the Monitor Agent machine. |
True |
String |
id |
ID |
The primary key. |
False |
Integer |
is_connected |
Connected |
Specifies whether Monitor Agent is connected to Monitor Server. |
False |
Boolean |
name |
Name |
The name of the Monitor Agent machine. |
False |
String |
platform |
Platform |
The host operating system (OS) where Monitor Agent is installed. |
False |
String |
version |
Version |
The software version of Monitor Agent. |
False |
String |
Alerts
The Alerts table includes the following fields:
Field name |
Display name |
Description |
Nullable |
Type |
aggregation |
Aggregation |
The mathematical function used to aggregate metric samples for comparison with the alert rule. |
True |
String |
closed_at |
Closed at |
The date and time the alert was closed. |
True |
Datetime |
component_address_internal |
Component address internal |
The common network address. |
False |
String |
component_id |
Component ID |
The unique ID of the component associated with the alert. |
False |
Integer |
component_name |
Component name |
The name of the component. |
False |
String |
component_subtype |
Component subtype |
The secondary category used to categorize components. |
True |
String |
component_type |
Component type |
The primary category used to categorize components. |
False |
String |
created_at |
Created at |
False |
Datetime |
critical_threshold |
Critical threshold |
The metric threshold value that results in the opening of a critical alert. |
True |
Float |
duration |
Duration |
The number of minutes the alert was open. |
False |
Integer |
id |
ID |
The primary key. |
False |
Integer |
info_threshold |
Info threshold |
The metric threshold value that results in the opening of an info alert. |
True |
Float |
metric_id |
Metric ID |
The unique ID of the metric associated with the alert. |
False |
Integer |
metric_name |
Metric name |
The name of the metric. |
True |
String |
metric_r_id |
Metric registry ID |
The namespace registry ID of the metric. |
True |
String |
observer_id |
Observer ID |
The unique ID of the observer associated with the component that triggered the alert. |
False |
Integer |
opened_at |
Opened at |
The date and time the alert was opened. |
False |
Datetime |
operator |
Operator |
The mathematical operator used to compare the aggregated metric samples with the alert thresholds. |
True |
String |
samples |
Samples |
The total number of consecutive historical metric samples used to determine the alert status. |
True |
Integer |
state |
State |
The current state of the alert. |
False |
String |
status |
Status |
The status of the alert when it was opened. |
True |
Integer |
warning_threshold |
Warning threshold |
The metric threshold value that results in the opening of a warning alert. |
True |
Float |
Analysis
The Analysis table includes the following fields:
Field name |
Display name |
Description |
Nullable |
Type |
configuration |
Configuration |
The persisted configuration for an analysis view's visual elements. |
False |
Object |
created_at |
Created at |
False |
Datetime |
description |
Description |
The long-form description of the analysis view. |
True |
String |
id |
ID |
The primary key. |
False |
Integer |
name |
Name |
The name of the analysis view. |
False |
String |
user_id |
User ID |
The ID of the user who created the analysis view. |
True |
Integer |
Collections
The Collections table includes the following fields:
Field name |
Display name |
Description |
Nullable |
Type |
created_at |
Created at |
False |
Datetime |
description |
Description |
The long-form description of the collection. |
True |
String |
expression |
Expression |
The query expression used to dynamically group components into a collection. |
False |
Object |
id |
ID |
The primary key. |
False |
Integer |
is_security_enabled |
Security enabled |
Specifies whether the collection's feature service requires a token. |
False |
Boolean |
is_service_enabled |
Service enabled |
Specifies whether the collection's data is available through a feature service. |
False |
Boolean |
name |
Name |
The name of the collection. |
False |
String |
service_url |
Service URL |
The URL of the collection's feature service. |
True |
String |
status |
Status |
The collection's current status as evaluated from its attached components. |
True |
Integer |
Comments
The Comments table includes the following fields:
Field name |
Display name |
Description |
Nullable |
Type |
alert_id |
Alert ID |
The unique ID of the related alert. |
True |
Integer |
created_at |
Created at |
False |
Datetime |
id |
ID |
The primary key. |
False |
Integer |
incident_id |
Incident ID |
The unique ID of the related incident. |
True |
Integer |
message |
Message |
The comment's message content. |
False |
String |
type |
Type |
The comment's origin. |
False |
String |
user_id |
User ID |
The ID of the user who created the comment. |
False |
Integer |
Components
The Components table includes the following fields:
Field name |
Display name |
Description |
Nullable |
Type |
address_internal |
Internal address |
False |
String |
cert_expires_at |
Cert expires at |
The date and time the component's configured server certificate expires. |
True |
Datetime |
class |
Class |
The system classification (virtual or physical). |
True |
String |
cpu_cores_logical |
CPU cores logical |
The system's total number of logical CPU cores. |
True |
Float |
cpu_cores_physical |
CPU cores physical |
The system's total number of physical CPU cores. |
True |
Integer |
cpu_name |
CPU name |
The CPU manufacturer name and model information. |
True |
String |
cpu_speed |
CPU speed |
The speed of the system's CPU. |
True |
Float |
created_at |
Created at |
False |
Datetime |
description |
Description |
The long-form description of the component. |
True |
String |
gdb_version |
GDB version |
The ArcGIS software version of the geodatabase. |
True |
String |
id |
ID |
The primary key. |
False |
Integer |
idle_time_max |
Idle time max |
The maximum time a service instance remains idle before shutting down. |
True |
Integer |
instance_type |
Instance type |
The type of service instance (dedicated or shared). |
True |
String |
instances_max |
Instances max |
The maximum number of allowed service instances. |
True |
Integer |
instances_min |
Instances min |
The minimum number of allowed service instances. |
True |
Integer |
instances_shared_max |
Instances shared max |
The service's maximum number of shared instances. |
False |
Integer |
instances_shared_min |
Instances shared min |
The service's minimum number of shared instances. |
False |
Integer |
is_service_cached |
Is service cached |
Specifies whether the service is cached. |
True |
Boolean |
license_expires_at |
License expires at |
The date and time the component's software license expires. |
True |
Datetime |
location |
Location |
The availability zone where the component is located. |
True |
String |
memory_page_total |
Memory page total |
The total amount of page file memory. |
True |
Float |
memory_total |
Memory total |
The total amount of system memory. |
True |
Float |
name |
Name |
False |
String |
network_speed |
Network speed |
The network adapter's negotiated network speed. |
True |
Float |
started_at |
Started at |
The date and time the service was last started. |
True |
Datetime |
state |
State |
The current registration state of the component. |
False |
String |
status |
Status |
The current status of the component as evaluated from its attached metrics. |
True |
Integer |
storage_total |
Storage total |
The total amount of storage space of a storage subcomponent. |
True |
Float |
strategy_r_id |
Strategy registry ID |
The component's monitoring strategy. |
True |
String |
subtype |
Subtype |
True |
String |
system_id |
System ID |
The ID used to uniquely identify the component within its monitoring scope. |
True |
String |
system_state |
System state |
The value of the entity's system state configuration. |
True |
String |
type |
Type |
False |
String |
version |
Version |
The current software version of the component. |
True |
String |
wait_time_max |
Wait time max |
The maximum time a client will wait for the service to respond before it times out. |
True |
Integer |
Component logs
The Component logs table includes the following fields:
Field name |
Display name |
Description |
Nullable |
Type |
code |
Code |
The log code associated with the log entry. |
True |
Integer |
component_id |
Component ID |
The unique ID of the related component. |
True |
Integer |
level |
Level |
The log level associated with the log entry. |
True |
String |
logged_at |
Logged at |
The date and time the logged event occurred. |
True |
Datetime |
Dataviews
The Dataviews table includes the following fields:
Field name |
Display name |
Description |
Nullable |
Type |
created_at |
Created at |
False |
Datetime |
created_by |
Created by |
The ID of the user who created the dataview. |
True |
Integer |
description |
Description |
The long-form description of the dataview. |
True |
String |
expression |
Expression |
The persisted configuration for a dataview query expression. |
False |
Object |
id |
ID |
The primary key. |
False |
Integer |
name |
Name |
The name of the dataview. |
False |
String |
updated_by |
Updated by |
The ID of the user who updated the dataview |
True |
Integer |
Incidents
The Incidents table includes the following fields:
Field name |
Display name |
Description |
Nullable |
Type |
created_at |
Created at |
False |
Datetime |
description |
Description |
The long-form description of the incident. |
True |
String |
id |
ID |
The primary key. |
False |
Integer |
name |
Name |
The name of the incident. |
False |
String |
occurrence |
Occurrence |
The occurrence configuration used to determine when an incident is active. |
False |
Object |
state |
State |
The current state of the incident. |
True |
String |
Labels
The Labels table includes the following fields:
Field name |
Display name |
Description |
Nullable |
Type |
color |
Color |
The background color of the label. |
True |
String |
created_at |
Created at |
False |
Datetime |
description |
Description |
The long-form description of the label. |
True |
String |
id |
ID |
The primary key. |
False |
Integer |
name |
Name |
The name of the label. |
False |
String |
Metrics
The Metrics table includes the following fields:
Field name |
Display name |
Description |
Nullable |
Type |
aggregation |
Aggregation |
True |
String |
base_r_id |
Base registry ID |
The registry name of the metric that defines its core attributes. |
False |
String |
component_id |
Component ID |
The unique ID of the component associated with the metric. |
True |
Integer |
component_name |
Component name |
False |
String |
created_at |
Created at |
False |
Datetime |
True |
Float |
description |
Description |
The long-form description of the metric. |
True |
String |
id |
ID |
The primary key. |
False |
Integer |
info_threshold |
Info threshold |
True |
Float |
is_alerting_enabled |
Alerting enabled |
Specifies whether alerts are created using status evaluation. |
False |
Boolean |
name |
Name |
True |
String |
observer_id |
Observer ID |
The unique ID of the observer that recorded the metric. |
True |
Integer |
operator |
Operator |
True |
String |
r_id |
Registry ID |
True |
String |
samples |
Samples |
True |
Integer |
status |
Status |
The current alert status of the metric. |
True |
Integer |
units |
Units |
The metric's unit of measure. |
False |
String |
warning_threshold |
Warning threshold |
True |
Float |
Metrics data
The Metrics data table includes the following fields:
Field name |
Display name |
Description |
Nullable |
Type |
metric_id |
Metric ID |
The ID of the related metric. |
True |
Integer |
observed_at |
Observed at |
The date and time the metric was measured. |
True |
Datetime |
value |
Value |
The metric's measured value. |
True |
Float |
Notifications
The Notifications table includes the following fields:
Field name |
Display name |
Description |
Nullable |
Type |
collection_id |
Collection ID |
The unique ID of the collection used to scope notifications. |
True |
Integer |
created_at |
Created at |
False |
Datetime |
description |
Description |
The long-form description of the notification. |
True |
String |
email_interval |
Email interval |
The number of minutes between email notifications. |
True |
Integer |
events |
Events |
The configured events that cause a notification to be sent. |
False |
Object |
id |
ID |
The primary key. |
False |
Integer |
is_email_enabled |
Email enabled |
Specifies whether email notifications are enabled. |
False |
Boolean |
is_webhook_enabled |
Webhook enabled |
Specifies whether webhook notifications are enabled. |
False |
Boolean |
name |
Name |
The name of the notification. |
False |
String |
webhook_delivery_failures |
Webhook delivery failures |
The maximum number of retry attempts before the webhook fails. |
False |
Integer |
webhook_delivery_on_empty |
Webhook delivery on empty |
Specifies whether delivery will occur on the interval, even if no events were captured. |
True |
Boolean |
webhook_delivery_reattempt_interval |
Webhook delivery reattempt interval |
The time between redelivery attempts when a delivery failure occurs. |
False |
Integer |
webhook_delivery_timeout |
Webhook delivery timeout |
The maximum wait time for a response from the receiver. |
False |
Integer |
webhook_secret |
Webhook secret |
The secret used by the receiver to verify the payload. |
True |
String |
webhook_status |
Webhook status |
The current status of the webhook. |
True |
Integer |
webhook_url |
Webhook URL |
The URL of the webhook receiver. |
True |
String |
Observers
The Observers table includes the following fields:
Field name |
Display name |
Description |
Nullable |
Type |
component_id |
Component ID |
The unique ID of the component associated with the observer. |
True |
Integer |
created_at |
Created at |
False |
Datetime |
description |
Description |
The long-form description of the observer. |
True |
String |
id |
ID |
The primary key. |
False |
Integer |
interval |
Interval |
The time between observer runs. |
False |
Integer |
is_enabled |
Enabled |
Specifies whether the observer is enabled. |
False |
Boolean |
name |
Name |
The name of the observer. |
False |
String |
r_id |
Registry ID |
The registry ID of the observer. |
True |
String |
status |
Current status |
The current running health of the observer. |
True |
Integer |
strategy_r_id |
The registry ID of the component's monitoring strategy. |
False |
String |
Sessions
The Sessions table includes the following fields:
Field name |
Display name |
Description |
Nullable |
Type |
address |
Address |
The application address associated with the session |
False |
String |
component_id |
Component ID |
The unique ID of the component associated with the session |
False |
Integer |
duration |
Duration |
The number of minutes the session was active |
False |
Integer |
ended_at |
Ended at |
The date and time the session ended |
True |
Datetime |
id |
ID |
The primary key |
False |
Integer |
started_at |
Started at |
The date and time the session started |
False |
Datetime |
updated_at |
Updated at |
The date and time the session was last updated |
False |
Datetime |
user_agent |
User agent |
The client type used by the user during the session |
False |
String |
username |
Username |
The username associated with the session |
True |
String |
