Configure alert rules
You can configure alert rules for component metrics to notify ArcGIS Monitor users when metrics are outside of a predefined set of threshold values. You must be assigned the Administrator or Manager role to configure alert rules.
Tip:
You can also configure default alert rules for metrics from the Administration page.
Configure alert rules for a metric
To configure alert rules for a metric, complete the following steps:
Access ArcGIS Monitor if necessary.
The Home page appears.
Click Monitoring.
The Monitoring page appears with registered components listed alphabetically by name.
Optionally, do any or all of the following:
Click a category on the side of the page to filter the list by that category.
Click Sort and change the sorting method.
Click Filter and create a query to filter the list.
Click Columns and specify the columns to hide or show.
Position the pointer at the edge of a column's header and drag the column's edge to resize it.
Click Labels to filter the list by the labels that you choose.
Type a keyword in the Search by component name or address text box to search for specific components.
Click the name of the component for which you want to configure alert rules.
The component's Overview page appears with component details and metrics.
Click the Metrics tab.
A list of component metrics appears sorted by name.
Type a keyword in the Search by metric name text box to search for specific metrics.
Click More options
next to the metric for which you want to configure an alert rule, and click Edit alert rules.The Edit alert rules dialog box appears.
Turn on the Alerting toggle button to enable alerts for the chosen metric.
Caution:
If you don't turn on Alerting, no alerts are created when the metric's values fall outside the alert rule's configured threshold values.
Click the Aggregation drop-down arrow, and choose one of the following options:
Minimum—The lowest value in the group of collected samples is used as the comparison value.
Maximum—The highest value in the group of collected samples is used as the comparison value.
Average—The average of all values in a group of collected samples is used as the comparison value. This is the default value.
95th percentile—The collected samples are used to determine if they are at or outside the specified threshold 95 percent of the time.
5th percentile—The collected samples are used to determine if they are at or outside the specified threshold 5 percent of the time.
Click the Operator drop-down arrow, and choose a comparison method.
Provide a value for the Info setting.
When the metric's value is outside the configured range, an info alert is opened.
Provide a value for the Warning setting.
When the metric's value is outside the configured range, a warning alert is opened.
Provide a value for the Critical setting.
When the metric's value is outside the configured range, a critical alert is opened.
Provide the number of samples to use for the calculation in the Samples text box.
Samples allow you to filter short-term increases in metric data values and outlier data. For example, when an alert rule is configured to use the average of three samples and the metric's observer is configured for one-minute intervals, the average of the metric data samples must be outside the configured threshold for three consecutive minutes before an alert is opened. If the average of three consecutive samples doesn't fall outside the configured alert threshold, no alert is opened.
Click Save.
The alert rule is saved and activated.
Configure multiple alert rules for a single component
You can configure multiple alert rules for metrics that share the same unit of measure for a single component.
To configure multiple alert rules for a single component, complete the following steps:
Click Monitoring.
Check the check box next to the names of the metrics for which you want to configure alert rules.
The metrics you choose must have the same unit of measure.
Click Edit alert rules.
If you chose metrics with different units of measure, Edit alert rules is unavailable.
To use the same values for multiple metrics, check the check boxes next to the various metrics.
The Batch edit row becomes available and the chosen rows become unavailable. Values that you provide in the Batch edit row are reflected in the rows for the chosen metrics.
Turn on the Alerting toggle button for each metric to enable alerts.
Caution:
If you don't turn on Alerting, no alerts are created when the metric values fall outside the alert rule's configured threshold values.
Click the Aggregation drop-down arrow for each metric and choose one of the following options:
Click the Operator drop-down arrow for each metric and choose a comparison method.
Provide a value for the Info setting for each metric.
Provide a value for the Warning setting for each metric.
Provide a value for the Critical setting for each metric.
Provide the number of samples to use for the calculation in the Samples text box for each metric.
Click Save.
The alert rules for the chosen metrics are saved and activated.
Configure alert rules across multiple components
To configure alert rules for metrics that share the same unit of measure across multiple components, complete the following steps:
Click Monitoring.
The metrics page appears with a list of metrics for all registered components.
Type a keyword in the Search by metric name or component name text box to search for specific metrics.
The metrics that you choose must have the same unit of measure.
Turn on the Alerting toggle button for each metric for which you want to enable alerts.
Caution:
Click Save.
