Reset alert rules to their default settings
You can reset customized metric alert rules to their default settings on the Monitoring page. You must be assigned the Administrator or Manager role to reset alert rules to their default settings.
  1. Access ArcGIS Monitor if necessary.
    The Home page appears.
  2. Click Monitoring.
    The Monitoring page appears with registered components listed alphabetically by name.
  3. Optionally, do any or all of the following:
    • Click a category on the side of the page to filter the list by that category.
    • Click Sort and change the sorting method.
    • Click Filter and create a query to filter the list.
    • Click Columns and specify the columns to hide or show.
    • Position the pointer at the edge of a column's header and drag the column's edge to resize it.
    • Click Labels to filter the list by the labels that you choose.
    • Type a keyword in the Search by component name or address text box to search for specific components.
  4. Click the name of the component that contains the metric alert rule that you want to reset to its default setting.
    The component's Overview page appears with component details and metrics.
  5. Click the Metrics tab.
    A list of component metrics appears sorted by name.
  6. Optionally, do any or all of the following:
    • Type a keyword in the Search by metric name or component name text box to search for specific metrics.
  7. Click More options next to the metric with the alert rules you want to reset to their default settings, and click Reset alert rules to default.
    The Reset alert rules to default dialog box appears.
  8. Click Reset to reset the metric's alert rules to their default settings.
    Caution:
    Resetting a metric's alert rules to their default settings is permanent and cannot be undone.
    The default alert rules are applied to the metric.
