View metrics
Metrics are properties with corresponding numerical values that are associated with registered components in ArcGIS Monitor and can be used to track various aspects of an environment and its components over time. Refer to the sections below to view metrics for registered components.
View metrics for individual components
To view a complete list of metrics associated with a component on the component's Metrics page, complete the following steps:
  1. Access ArcGIS Monitor if necessary.
    The Home page appears.
  2. Click Monitoring.
    The Monitoring page appears. Registered components are listed alphabetically by component name.
  3. Optionally, do any or all of the following:
    • Click a category on the side of the page to filter the list by that category.
    • Click Sort and change the sorting method.
    • Click Filter and create a query to filter the list.
    • Click Columns and specify the columns to hide or show.
    • Position the pointer at the edge of a column's header and drag the column's edge to resize it.
    • Click Labels to filter the list by the labels that you choose.
    • Type a keyword in the Search by component name or address text box to search for specific components.
  4. Click the name of the component that contains the metrics you want to view.
    The component's Overview page appears with component details and an overview of its metrics.
  5. Click the Metrics tab.
    A list of the component's metrics appears with the following status indicators displayed next to each metric's name:
    Status
    Icon
    Incident active
    There is an active incident and monitoring and alerting are paused.
    Monitoring off
    One or more observers are turned off and monitoring is disabled.
    Alerting off
    Alerting is turned off.
    No data
    The observer failed to collect data.
    Nominal
    No alerts are open.
    Info
    There is an open info alert.
    This may require further investigation.
    Warning
    There is an open warning alert.
    This requires further investigation.
    Critical
    There is an open critical alert.
    This requires immediate investigation.
  6. Optionally, do any or all of the following:
    • Type a keyword in the Search by metric name text box to search for specific metrics.
  7. Optionally, click a metric's status button to display a pop-up with a chart that shows the metric's most recent data values and alert information.
  8. Click the name of a metric to view more information about the metric, including its alert rules.
  9. Optionally, click the Filter by date drop-down arrow, choose a predefined time range or use the date picker to define a custom time range, and click Apply to constrain the metric data to the specified time range.
View metrics associated with an ArcGIS Monitor Agent machine
To view a list of metrics collected by a specific Monitor Agent machine, complete the following steps:
  2. Click the Monitoring tab.
    The Monitoring page appears. Registered components are listed alphabetically by name.
  3. Click the Agents tab.
    The Agents page appears with a list of Monitor Agent machines.
  4. Optionally, do any or all of the following:
    • Type a keyword in the Search by agent name text box to search for specific Monitor Agent machines.
  5. Click the name of the Monitor Agent machine that contains the metrics that you want to view.
    The Monitor Agent machine's Overview page appears with its details and an overview of its components' metrics.
  6. Click the Metrics tab.
    The Metrics page appears with a list of metrics associated with the Monitor Agent machine and the following status indicators:
    Status
    Icon
    Incident active
    Monitoring off
    Alerting off
    No data
    Nominal
    No alerts are open.
    Info
    Warning
    Critical
  7. Optionally, do any or all of the following:
    • Type a keyword in the Search by metric name or component name text box to search for specific metrics.
  8. Optionally, click a metric's status button to display a pop-up with a chart that shows the metric's most recent data values and alert information.
  9. Click the name of a metric to view more information about the metric, including its alert rules.
  10. Optionally, click the Filter by date drop-down arrow, choose a predefined time range or use the date picker to define a custom time range, and click Apply to constrain the metric data to the specified time range.
View metrics for all registered components
To view metrics for all registered components on the Monitoring page, complete the following steps:
  3. Click the Metrics tab.
    The Metrics page appears with a list of metrics for all registered components and the following status indicators:
    Status
    Icon
    Incident active
    Monitoring off
    Alerting off
    No data
    Nominal
    No alerts are open.
    Info
    Warning
    Critical
  5. Optionally, click a metric's status button to display a pop-up with a chart that shows the metric's most recent data values and alert information.
  6. Click the name of a metric to view more information about the metric, including its alert rules.
  7. Optionally, click the Filter by date drop-down arrow, choose a predefined time range or use the date picker to define a custom time range, and click Apply to constrain the metric data to the specified time range.
