ArcGIS Notebook Server system requirements
ArcGIS Notebook Server is an ArcGIS Server role, licensed and configured for the purpose of hosting ArcGIS Notebooks. The server role uses Docker containers to host and run notebooks and provides an isolated and secure environment for the notebooks without interfering with operations of the host operating system.
Learn more about Docker and its role in ArcGIS Notebook Server
The system and hardware requirements to run ArcGIS Notebook Server are listed below. A diagnostics tool runs during the setup to help you determine whether your machine meets the system requirements.
Learn more about Mirantis Container Runtime and Docker Engine from binaries and their role in ArcGIS Notebook Server.
Hardware requirements
An ArcGIS Notebook Server node using Linux containers requires, at minimum, a 4-core processor, 16 GB of RAM, and 75 GB of disk space.
An ArcGIS Notebook Server node using Windows containers requires, at minimum, a 4-core processor, 32 GB of RAM, and 100 GB of disk space.
For a production environment, hardware requirements are not listed because the user and business needs of the software may vary. These requirements must be considered in determining hardware needs to meet performance and scalability expectations.
Ensure that the /var directory, where ArcGIS Notebook Server stores its Docker container images locally, has at least 50 GB of available disk space. For more information, see Container engines and ArcGIS Notebook Server.
General-purpose computing on a GPU
Support for general-purpose computing on a GPU (GPGPU) using CUDA is not required to run the software but is required to run most deep learning functionality. Deep learning is computationally intensive, and it is recommended that you use a powerful GPU to process large datasets.
Item
Supported and recommended
GPU type
NVIDIA GPU with CUDA compute capability 5.0 minimum; 7.5 or later recommended. See the list of CUDA-enabled cards to determine compute capability of a GPU.
GPU driver
NVIDIA GPU drivers: version 551.61 or later is required.
Dedicated graphics memory
Minimum: 6 GB.
Recommended: 16 GB or more.
Memory requirements depend on the model architecture and batch size being used.
An out-of-date GPU driver will cause deep learning tools to fail with run time errors indicating that CUDA is not installed or an unsupported tool chain is present. Verify that you have up-to-date GPU drivers directly provided by NVIDIA.
Firewall settings
ArcGIS Notebook Server communicates on port 11443. You'll need to open this port on your firewall before installing the software.
To communicate with the ArcGIS Enterprise organization with which it's federated, ArcGIS Notebook Server needs access to port 7443 on the portal machine.
This component is only one part of an ArcGIS Enterprise deployment. See ArcGIS Enterprise system requirements for a diagram and links to information about the ports needed to communicate with other components in ArcGIS Enterprise.
Temporary space requirements
By default, resources are extracted to the system /tmp directory. This directory must have read, write, and run permissions enabled. If the required space is not available in the /tmp directory, the setup program will attempt to extract resources to the user's HOME directory. If the required space is not available in the user's HOME directory, the setup program will report an error indicating this problem. Optionally, you can specify an alternate temporary location by setting the IATEMPDIR environment variable.
File handles and process limits
ArcGIS Notebook Server is a data-intensive server product, and many of its data formats consist of hundreds of thousands of files. In heavily used systems, thousands or tens of thousands of files may be in use at any given time. If there are insufficient file handles and processes, requests may fail randomly, leading to system downtime. The number of file handles and processes you'll need varies based on the data and the number of instances (threads and processes) running. Setting a file handle minimum of 65,535 and a process minimum of 25,059 ensures that the system remains running.
There are soft and hard limits for file handles and processes on Linux. To determine the hard limits, use the ulimit -Hn -Hu command (or limit -h descriptors if you're using csh). To determine the soft limits, use the ulimit -Sn -Su command (or limit descriptors if you're using csh).
To increase the soft and hard limits, you must edit the /etc/security/limits.conf file with superuser access. You can add the following four lines to the file to change the limit values:
<ArcGIS Notebook Server installation user> soft nofile <file limit>
<ArcGIS Notebook Server installation user> hard nofile <file limit>
<ArcGIS Notebook Server installation user> soft nproc <process limit>
<ArcGIS Notebook Server installation user> hard nproc <process limit>
After making this change, you must sign out and sign in again with the particular user for the new values to take effect. To verify that the limits have been modified appropriately, use the ulimit -Hn -Hu and ulimit -Sn -Su commands as described above.
Operating system requirements on Linux containers
The following 64-bit operating systems satisfy the operating system requirements. Support is not provided for 32-bit operating systems; the setup will only proceed if the operating system is 64 bit.
Container engines for ArcGIS Notebook Server on Linux
There are two container engines available for Linux systems: Docker Engine and Mirantis Container Runtime.
If you're running Ubuntu or Red Hat Enterprise Linux Server, you can use either Docker edition.
Container engine
Operating system
Docker Engine Community edition 29.6.0 or later
If you are using Docker Engine version 29 or later and it was upgraded from a previous version, edit /etc/docker/daemon.json to enable containerd image store. See step 4 in Configure Docker settings and environments for more information.
Ubuntu Server LTS 24.04.4
Ubuntu Server LTS 22.04.5
Red Hat Enterprise Linux Server 8 update 10
Red Hat Enterprise Linux Server 9 update 7
Rocky Linux 8 update 10
Rocky Linux 9 update 7
AlmaLinux 8 update 10
AlmaLinux 9 update 7
Mirantis Container Runtime version 29.4.1 or later
Refer to the Mirantis Container Runtime 29.0 compatibility matrix for the most up to date information.
Ubuntu Server LTS 22.04.3
Ubuntu Server LTS 24.04.2
Oracle Linux 9 update 6
SUSE Linux Enterprise Server (SLES) 15 SP7
ArcGIS Notebook Server on Windows with Mirantis Container Runtime supports the following operating systems:
Operating system
Container engine
Additional requirements
Windows Server 2022 Standard and Datacenter
Optionally, you can install Hyper-V.
There are limitations to the maximum number of containers that can run with Hyper-V isolation on Windows Server Standard.
See the Windows FAQ for more information.
Windows Server 2025 Standard and Datacenter
Mirantis Container Runtime version 29.6.1 or later
ArcGIS Notebook Server on Windows with Docker Engine from binaries supports the following operating systems and Docker Engine versions:
Operating system
Container engine
Docker Engine - Community version 29.6.0 or later
Operating system requirements on Windows containers
Windows Server 2022 and 2025 are the only operating systems that are supported for ArcGIS Notebook Server and Windows containers.
Container engine
Operating system
Operating system
Container engine
Operating system
Container engine
Cloud implementations
You can deploy ArcGIS Notebook Server in the cloud. Cloud platforms allow you to add capabilities to your ArcGIS Notebook Server deployment, including resizing computer capacity and automatically distributing application network traffic across multiple instances for better performance.
Esri images
ArcGIS Enterprise on Amazon Web Services (AWS) provides tools to help you deploy the components on AWS. You can use ArcGIS Enterprise Cloud Builder for Amazon Web Services or the AWS CloudFormation template to deploy ArcGIS Notebook Server.
ArcGIS Enterprise on Microsoft Azure provides tools to help you deploy the ArcGIS Enterprise components on Azure. You can use ArcGIS Enterprise Cloud Builder for Microsoft Azure or automation solutions such as Chef Cookbooks for ArcGIS or Microsoft PowerShell Desired State Configuration (DSC) for ArcGIS to deploy ArcGIS Notebook Server.
Other images
To deploy ArcGIS Notebook Server on a different operating system, different machine type, or different cloud platform from what is provided by Esri, you must install and configure the software on an instance offered by your cloud provider. The instance must meet the hardware, software, firewall, temporary space, file handle and process limits, SSL certificate, and domain name requirements described on this page. Keep in mind the following if you install and configure your own cloud instance for ArcGIS Notebook Server:
  • ArcGIS Enterprise Cloud Builder for Microsoft Azure does not support deploying ArcGIS Notebook Server on Linux platforms. To use Azure virtual machines running Linux platforms, you must manually deploy and manage your ArcGIS Notebook Server installation.
To deploy ArcGIS Notebook Server on a different operating system, different machine type, or different cloud platform from what is provided by Esri, you must install and configure the software on an instance offered by your cloud provider. The instance must meet the hardware, software, firewall, SSL certificate, and domain name requirements described on this page. Keep in mind the following if you install and configure your own cloud instance for ArcGIS Notebook Server:
  • Deploying ArcGIS Notebook Server on Windows machines using ArcGIS Enterprise Cloud Builder for Amazon Web Services is not supported. If you plan to use ArcGIS Enterprise Cloud Builder for Amazon Web Services or AWS CloudFormation templates, deploy the software on a supported Linux environment.
  • To use Amazon Web Services (AWS) virtual machines running Windows platforms, you must manually deploy and manage your ArcGIS Notebook Server installation.
  • If you deploy your own Microsoft Azure Windows instance, the Microsoft Server 2022 with Containers image is recommended.
SSL certificates
ArcGIS Notebook Server is preconfigured with a self-signed certificate that allows the server to be initially tested and to help you quickly verify that your installation was successful.
You must request a certificate from a trusted certificate authority (CA) and configure ArcGIS Notebook Server to use it. This can be a domain certificate issued by your organization or a CA-signed certificate. The certificate must have a Subject Alternative Name (SAN) configured, or ArcGIS Notebook Server will not work properly.
Certificates created using IIS do not have the option to include a SAN. Use the script in Create a domain certificate, which includes a SAN, with the certificate created.
Portal for ArcGIS also includes a preconfigured self-signed certificate. Because you'll federate an ArcGIS Notebook Server site with your portal, request a certificate from a trusted CA and configure the portal to use it.
Software prerequisites
Before installing ArcGIS Notebook Server, you must have at least a base deployment of ArcGIS Enterprise ready. During the setup process, you will federate your new ArcGIS Notebook Server site with ArcGIS Enterprise. ArcGIS Notebook Server can be installed on a machine that has other ArcGIS Enterprise software (of the same version) installed.
  • ArcGIS Notebook Server requires Docker runtime to be installed. Follow the steps in Install container engine for ArcGIS Notebook Server to install the appropriate edition of Docker.
  • ArcGIS Notebook Server requires the following package groups to be installed, depending on the operating system:
    • RHEL Server: acl and gettext
    • Ubuntu Server: acl and gettext-base
To install these package groups, run the following commands for your operating system in a terminal:
RHEL Server machines
sudo yum install acl
sudo yum install gettext
Ubuntu Server machines
sudo apt-get install acl
sudo apt-get install gettext-base
Domain name system host name entry
ArcGIS Notebook Server must be installed on a machine that has a domain name system (DNS) host name entry. This may require the system administrators for the site to add an entry to a name server in their network and that this name server be listed in the /etc/resolv.conf configuration file on the system.
Because you'll be federating your site with your portal, it's recommended that you configure your organization's DNS to include fully qualified domain name (FQDN) entries. The portal will request the FQDN of each site when you federate.
Domain name system and fully qualified domain name recommendations
It's recommended that you configure your organization's domain name system (DNS) to include fully qualified domain name (FQDN) entries for the ArcGIS Notebook Server site. Portal for ArcGIS will request the FQDN of the site when you federate.
Supported web browsers
To use the ArcGIS Notebook Server Configuration Wizard, as well as the notebook editor, the following web browsers are supported:
  • Google Chrome version 138 and later
  • Microsoft Edge version 138 and later
  • Mozilla Firefox version 142 and later
  • Mozilla Firefox version 140 (ESR)
  • Safari version 18 and later
