Create an ArcGIS Notebook Server site
After you install ArcGIS Notebook Server and configure it, create a server site. A site is an individual deployment of ArcGIS Notebook Server and is the server unit that can be federated with the ArcGIS Enterprise portal.
ArcGIS Notebook Server supports joining additional machines to your site. In a multiple-machine site, each machine is configured the same, with identical container engine setups, and each can run ArcGIS Notebooks. If you are setting up a multiple-machine site, refer to Join additional machines to an ArcGIS Notebook Server site, which explains the additional steps needed in the installation and configuration process.
There are two ways to create the server site. You can use the ArcGIS Notebook Server configuration wizard, or create the site using the createsite command line utility.
Use the wizard to create your site
The ArcGIS Notebook Server configuration wizard creates an ArcGIS Notebook Server site on the machine.
In the wizard, provide a username and password and click Next.
The username must contain at least six characters and the password must contain at least eight. They cannot contain these characters:
\:/*?|<>".Note:
The primary site administrator account using this username and password is recognized only by ArcGIS Notebook Server; it's not an operating system account, and it's managed separately from the user accounts in your user store. The primary site administrator has unrestricted access to the ArcGIS Notebook Server site. This account is typically used to create the ArcGIS Notebook Server site and to configure and manage security. The primary site administrator account shouldn't be confused with the ArcGIS Notebook Server account you provided during installation.
Type the paths to the directories you want to use for your Root Server directory, Workspace directory, and Logs directory.
By default, they are created in
<ArcGIS Notebook Server installation directory>\arcgisnotebookserver. You can use different directories on your local drive or on your network for the configuration store, content store, and logs. This location must be accessible to the ArcGIS Notebook Server account, and the account must have read and write permissions to it.If you deploy ArcGIS Notebook Server on multiple machines, the content directory and configuration store must use a shared directory referenced by a UNC path. The workspace directory must always use a UNC path as a mapped network, with a matching drive letter, on all machines that are participating in the site. The UNC share must be created on a separate machine that is accessible to all notebook server machines.
By default, the server directories and configuration store are created in
<ArcGIS Notebook Server installation directory>/usrand the workspace directory is created in<Parent of ArcGIS Notebook Server installation directory>/arcgisnotebookserver/directories/arcgisworkspace. You can use different directories on your local drive or on your network for the configuration store, content store, and logs. This location must be accessible to the ArcGIS Notebook Server account, and the account must have read and write permissions to it.Note:
If ArcGIS Enterprise is running on AWS or Azure, the ArcGIS Notebook Server server directories must but be stored using file system storage.
Choose either File System or Cloud Store for your configuration store.
If you chose File System, type the path to the directory you want to use for your configuration store.
To register a Cloud Store as your configuration store, follow these steps:
Select a Cloud Store Type.
Input the Access and Secret Keys (ArcGIS Notebook Server) or Account Name and Account Key (Azure) for the ArcGIS Notebook Server/Azure account you will be using to create the object store.
The connection string will define the name of the object store, along with its region and any additional parameters. At minimum, include the following:
NAMESPACE=<NAMESPACE>;REGION=<REGION>Note:
In the above example,
NAMESPACErefers to the name of the cloud store you want to create. It does not need to be an existing cloud store.ArcGIS appends the text
arcgis-config-store-to the name you provide.Additional parameters may include AccountName, EndpointSuffix, CredentialType, ClientID, TenantID, username, and password.
When the Configure Site form is filled in, the username and password will be automatically appended to your connection string based on the Access and Secret Keys (or Account Name and Account Key).
Click Next.
Review the summary page and click Finish to create your site, or click Back to make changes.
If you are setting up a single-machine site, proceed to install and configure ArcGIS Web Adaptor with your site once the site is created.
If you are setting up a multiple-machine site, join additional machines to the site once it is created, and proceed to install and configure ArcGIS Web Adaptor with your site.
Use the createsite utility to create your site
Once ArcGIS Notebook Server is installed, you can use the createsite command line utility to create a server site. To do so, you have the following options:
Run the
createsiteutility as the ArcGIS Notebook Server account from the command prompt window, and specify the username, password, configuration store location, and directory parameters.Provide the path to the
createsite.propertiesfile that specifies these parameters. This is the recommended option because it is more secure.
The utility is located at <ArcGIS Notebook Server install directory>\tools\CreateSiteUtility\createsite.bat. The command line parameters for the utility are as follows:
The utility is located at <ArcGIS Notebook Server install directory>/tools/createSiteUtility. The command line parameters for the utility are as follows:
Parameter |
Description |
A username for the primary site administrator. The username must be at least six characters and cannot contain these characters: |
A password for the primary site administrator. The password must be at least eight characters and cannot contain these characters: |
The root server directory location. By default, the ArcGIS Notebook Server directories are created in the local directory The root server directory location. By default, the ArcGIS Notebook Server directories are created in the local directory |
The configuration store location for the ArcGIS Notebook Server site. By default, the configuration store is created in the local directory The configuration store location for the ArcGIS Notebook Server site. By default, the configuration store is created in the local directory |
The workspace directory location. This can vary depending on your setup. For a single-machine site, it can be a local path on your notebook server. For sites with multiple machines or a shared directory, establish a UNC path as a mapped network drive. Ensure that all of the machines within this site have this mapped drive with a consistent drive letter. Configure this map drive as the workspace directory for the ArcGIS Notebook Server. The workspace directory location. Provide a directory other than the ArcGIS Notebook Server installation directory—for example, For multiple-machine Notebook Server sites, the workspace directory must be a shared network drive accessible to the ArcGIS Notebook Server account. |
An optional argument to specify the recovery codes file. If this parameter is not specified, a new recovery codes file named recovery_codes.txt will be randomly generated and stored in the local directory An optional argument to specify the recovery codes file. If this parameter is not specified, a new recovery codes file named recovery_codes.txt will be randomly generated and stored in the local directory |
The full path to the properties file for the |
Displays command line help and exits. |
Specify parameters in the utility
If you're specifying parameters in the utility, run the command with the following syntax: createsite.bat [-u <username>] [-p <password>] [-d <directory>] [-c <config-store>] [-w <workspace>] [-r <recovery codes file>]. The arguments are as follows:
If you're specifying parameters in the utility, run the command with the following syntax: createsite.sh [-u <username>] [-p <password>] [-d <directory>] [-c <config-store>][-w <workspace directory>] [-r <recovery codes file>]. The arguments are as follows:
The following code example demonstrates keeping the default directory, configuration store, and recovery codes file locations:
<ArcGIS Notebook Server install directory>\tools\CreateSiteUtility\createsite.bat -u notebookPSA -p my.Password3 -w C:\\AdminFolder\directories\arcgisworkspace
<ArcGIS Notebook Server install directory>/tools/createSiteUtility/createsite.sh -u notebookPSA -p my.Password3 -w /path/to/workspacedirectory
The following code example demonstrates specifying directory and configuration store locations other than the defaults:
<ArcGIS Notebook Server install directory>\tools\CreateSiteUtility\createsite.bat -u notebookPSA -p my.Password3 -d C:\\AdminFolder\directories -c C:\\AdminFolder\config-store -w C:\\AdminFolder\directories\arcgisworkspace
<ArcGIS Notebook Server install directory>/tools/createSiteUtility/createsite.sh -u notebookPSA -p my.Password3 -d /path/to/directories -c /path/to/config-store -w /path/to/workspacedirectory
Specify parameters from a file
If you're specifying parameters from a file, run the command to use the createsite.properties file with the following syntax: createsite.bat [-f <filepath>]. A sample template of this file is located in <ArcGIS Notebook Server install directory>\tools\CreateSiteUtility\. The file must use the following syntax:
# Configuration properties for Server site creation
# User name for primary site administrator.
# Cannot contain these characters: \/:*?<>"
SERVER_ADMIN_USERNAME =
# Password for primary site administrator.
SERVER_ADMIN_PASSWORD =
# Initially, leave SERVER_ADMIN_PASSWORD_ENCRYPTED set to false.
# When you run the tool the first time, the password will be
# encrypted and SERVER_ADMIN_PASSWORD_ENCRYPTED will change to true.
SERVER_ADMIN_PASSWORD_ENCRYPTED = false
# Root server directory. By default, the server directories will be created locally,
# e.g.C:\\arcgisnotebookserver\\directories, or \\\\<Absolute path to>\\<Server directories>.
SERVER_DIRECTORIES_PATH =
# Configuration store for the ArcGIS Notebook Server site. By default, the configuration store will be created locally,
# e.g.C:\\arcgisnotebookserver\\config-store, or \\\\<Absolute path to>\\<Server config-store>.
SERVER_CONFIGSTORE_PATH =
# Workspace for the ArcGIS Notebook Server site. By default, the workspace directory will be created locally,
# e.g.C:\\arcgisnotebookserver\\directories\\arcgisworkspace.
SERVER_WORKSPACE_PATH =
# The recovery codes file used to generate the site invariant keys. If not provided, the create site process will generate one in <installdir>\framework\etc\
# Example : C:\\Users\\<username>\\Documents\<filename>.txt, or \\\\<AbsolutePath To File>\\<filename>.txt - needs to be a txt file.
RECOVERY_CODES_FILE =
Each file path referenced in the createsite.properties file adds a second backslash, such as C:\\arcgisserver\\directories. This is required by the command line utility.
If you're specifying parameters from a file, run the command to use the createsite.properties file with the following syntax: createsite.sh [-f <filepath>]. A sample template of this file is located in <ArcGIS Notebook Server install directory>/tools/createSiteUtility/. The file must use the following syntax:
# e.g./<Parent of ArcGIS Notebook Server installation directory>/arcgisnotebookserver/directories.
# e.g./<Parent of ArcGIS Notebook Server installation directory>/arcgisnotebookserver/config-store.
# e.g./<Parent of ArcGIS Notebook Server installation directory>/arcgisnotebookserver/directories/arcgisworkspace.
# The recovery codes file used to generate the site invariant keys. If not provided, the create site process will generate one in <installdir>/framework/etc/
# Example: /path/to/recovery-codes.txt - must be a .txt file.
When you run the utility successfully, a message appears before the tool closes, indicating that the ArcGIS Notebook Server site was created.
Next steps
If you are setting up a single-machine site, install and configure ArcGIS Web Adaptor with your site once the site is created.
If you are setting up a multiple-machine site, join additional machines to the site once it is created and proceed to install and configure ArcGIS Web Adaptor with your site.
