Join additional machines to an ArcGIS Notebook Server site
ArcGIS Notebook Server supports multiple-machine sites. In a multiple-machine site, each machine is configured the same, with identical Docker setups, and each can run ArcGIS Notebooks.
ArcGIS Notebook Server supports multilicensed sites, allowing all machines that participate in a site to no longer need the same level of license. For example, you can set up a three-machine site with one machine configured with an advanced license and two machines configured with standard licenses. This multilicense capability allows for scaling with a varying number of machines that have either an advanced or standard license.
Multiple-machine ArcGIS Notebook Server sites allow you to support more simultaneous notebook users. If you have many active users, or if your single machine's resources are inadequate for your users' needs, expanding to a multiple-machine site could be beneficial.
If you have a few notebook users who require more machine resources, consider modifying your site's resource limits as a limited alternative to adding machines.
All machines in an ArcGIS Notebook Server site have the same software installed, with the same version. On the first machine you set up, you'll need to create the ArcGIS Notebook Server site. You can then join additional ArcGIS Notebook Server machines to the site.
Unlike other ArcGIS Server roles, ArcGIS Notebook Server does not support adding more machines to a site from the first machine. You must access each machine in turn and join them to the site, using the ArcGIS Notebook Server configuration wizard or the joinsite utility.
Before you install
When you create a site, you determine where to store the configuration store, a directory hosting the critical files and configuration information for your site. Your site also has system and workspace server directories.
When you create an ArcGIS Notebook Server site, you specify locations for the configuration store and server directories. In a multiple-machine site, you must share the configuration store and server directories so that the other machines can access them. Each machine that joins the site must be granted read and write permissions to these shared locations.
Install and configure a multiple-machine site
When you intend to set up a multiple-machine ArcGIS Notebook Server site, there are additional steps to follow in this installation guide.
Review the system requirements for ArcGIS Notebook Server to verify that each machine qualifies. On each machine, adjust the firewalls to open port 11443 for communication from each machine in your ArcGIS Enterprise deployment.
Make sure you install using the same operating system user on both machines. The user account used to install ArcGIS Notebook Server will be the account used to run the software. Group users and all others must have at least execute permissions to the ArcGIS Notebook Server installation directory. Note that installing ArcGIS Notebook Server with the root account is not supported. The user account used to install on two machines, for example, could be as follows:
Install ArcGIS Notebook Server on the first machine at
/data/agsas user ags, with a user ID of 58103.Install ArcGIS Notebook Server on a second machine at
/data/agswith the same username and ID (ags, user ID 58103).
Ensure that you have already done the following during the installation process to this point:
Install a container engine for ArcGIS Notebook Server. On each machine, download the Docker images provided by Esri and save them to a location the system can access.
Install and authorize ArcGIS Notebook Server on each machine. You can also silently install the software.
Run the command line post installer utility (located at
<ArcGIS Notebook Server installation directory>/tools/postInstallUtility) to load the Docker images into the local repository on each machine.Follow the steps to configure ArcGIS Notebook Server after installation.
Create and share two directories on your network, specifying the installation user as the owner. One should be for the configuration store and the other for your server directories. You must grant at least 700 permissions to the folders.
Shared network directories that are hidden or use special characters (for example, $) are not supported by ArcGIS Notebook Server.
For example:
Create a directory named config-store. Specify the owner as ags, with the user ID of 58103. Grant at least 700 permissions to the directory.
Share the config-store folder so that both machines can access the directory using the same path, for example,
/net/myserver/config-store.Create a directory named arcgisnotebookserver. Specify the owner as ags, with the user ID of 58103. Grant at least 700 permissions to the directory.
Share the arcgisnotebookserver folder so that both machines can access the directory using the same path, for example,
/net/myserver/arcgisnotebookserver.Even if the directories reside on the same machine that you will use when creating the site, you must still manually create and share the directories and reference them through a network path.
From one of your machines, create an ArcGIS Notebook Server site. Ensure you use the paths for your server directories and configuration store that you set up earlier.
Once the previous steps have been completed, you can join each additional machine to the site you've created using a configuration wizard. If you prefer to join the site from the command line, see step 6.
From the first additional machine, open the ArcGIS Notebook Server Configuration Wizard.
Review and follow the instructions provided in the wizard, and click Continue.
Click Join Existing Site.
Enter the site URL and credentials for your ArcGIS Notebook Server site as created in step 4.
Repeat substeps a through d for each additional machine you want to join to the site.
As an alternative to using the configuration wizard, you can join the machine to the site using a command line utility, as follows:
Ensure you're signed in to the machine with the ArcGIS Notebook Server account.
Open a command prompt and run the utility, which is located at
<ArcGIS Notebook Server install directory>/tools/JoinSiteUtility/joinsite.sh. The following are the command line parameters for the utility:Parameter
-uor--usernameThe username of the primary site administrator.
The username cannot contain these characters:
\/:*?|<>-por--passwordThe password for the primary site administrator.
The password cannot contain these characters:
\/:*?|<>-for--fileThe configuration store connection file for the
joinsiteutility.-sor--siteUrlThe URL of the existing ArcGIS Notebook Server site to join, in the format
https://notebookserver.domain.com:11443.-hor--helpDisplays command line help and exits.
An example command for the utility:
<ArcGIS Notebook Server install directory>/tools/JoinSiteUtility/joinsite.sh -u notebookPSA -p my.Password3 -s https://notebookserver.domain.com:11443If the account credentials and site URL are entered correctly, the utility will join the machine to the ArcGIS Notebook Server site. Repeat this step for each additional machine.
Once all machines are joined to the site, the remaining setup process is the same as for single-machine sites. Proceed to install and configure ArcGIS Web Adaptor with your site. You will then configure your site with your ArcGIS Enterprise portal.
Join a site from the command line
You can also use the joinSite command line utility to join your machine to an ArcGIS Notebook Server site. This utility requires that you specify the location of the configuration store of the existing site, rather than its URL. Because of this, the utility is advantageous for certain cases in which using the URL would clog up the network requests queue for the site. Consider using this utility if the machines in your ArcGIS Notebook Server site are already overloaded with network requests, or if you want to join a large number of machines to your site at one time.
The join-site utility is installed in \tools\JoinSiteUtility under the ArcGIS Notebook Server installation directory. Run the join-site utility from the ArcGIS Notebook Server machine you want to add to an existing site, using the Run As account for the ArcGIS Notebook Server.
Grant read and write access on the configuration store folder of the existing site to the network account used to run the ArcGIS Notebook Server service on the machine or machines you want to join to the site.
Create a JavaScript Object Notation (JSON) file named
connection.json.Add the following line to the file, replacing
<path to the configuration store>with the configuration store location of the existing ArcGIS Server site:{"configPersistenceType": "FILESYSTEM", "connectionString": "<path to the configuration store>"}In this example, the path to the configuration store of the existing site is
/net/mymachine/data/arcgisnotebookserver/usr/config-store:{"connectionString": "/net/mymachine/data/arcgisnotebookserver/usr/config-store", " configPersistenceType": "FILESYSTEM" }Save and close the
connection.jsonfile.Place the
connection.jsonfile on the machine that will join the site or on a shared directory that you can access from the machine that will join the site.Open a command prompt and run
join-site.
The syntax is as follows:
joinSite -f <The file path to the configuration store JSON file>
In this example, the configuration store JSON file (connection.json) is assumed to be located in the same directory as the join-site tool (\tools\JoinSiteUtility).
joinsite.bat -f connection.json
The machine is joined to the ArcGIS Notebook Server site.
ArcGIS Notebook Server supports multiple-machine sites. In a multiple-machine site, each machine must have the same configuration, with the same OS, identical container engine setup, and mapped network drive with the same drive letter for the workspace directory.
Review the system requirements for ArcGIS Notebook Server to verify that each machine qualifies. On each machine, adjust the firewalls to open port 43 for communication from each machine in your ArcGIS Enterprise deployment.
The installed version of ArcGIS Notebook Server and its license file must be the same on each machine. Enter the same ArcGIS Notebook Server account during each installation. It's recommended that you use a domain or Active Directory account, but if you choose a local account, it must exist on each machine with an identical name and password combination. Keep in mind that the account you specify does not have to be part of the Administrators group.
Ensure that you have already done the following during the installation process:
Install a container engine for ArcGIS Notebook Server on each machine. On each machine, download the Docker images provided by Esri and save them to a location the system can access.
ArcGIS Notebook Server on Windows only supports Windows containers. Download the container images that correspond to your installation from My Esri and run the command line post installer utility (located at
<ArcGIS Notebook Server installation directory>\tools\postInstallUtility) to install the container images for ArcGIS Notebook Server. Repeat this step on all ArcGIS Notebook Server machines. Follow the steps to configure ArcGIS Notebook Server after installation.
Create and share two directories on your network. One should be for the configuration store and the other for some of the server directories. The
workspacedirectory should remain on a UNC share mapped as a network drive. Grant read and write permissions for these two directories to the ArcGIS Notebook Server account on each machine (make sure to do this on both the Sharing tab and the Security tab of Microsoft File Explorer).Note:
Shared network directories that are hidden or use special characters (such as $) are not supported by ArcGIS Notebook Server.
Even if the directories reside on the same machine that you will use when creating the site, you must still manually create and share the directories and reference them through a network (UNC) path.
If the ArcGIS Notebook Server account does not exist on the machine (such as when you put the configuration store and server directories on a file server), you need to create the ArcGIS Notebook Server account using the same name and password that you used in all the other machines in your deployment.
If you are using a group managed service account (gMSA) for the ArcGIS Notebook Server account, you must allow service accounts to have full control permissions on the Sharing and Security tabs. From the Permissions editor, click Add, and open the Object Types. dialog box. Check the box for Service Accounts.
When additional machines are joined to the site, they are considered equal in the site; there is no primary machine.
<ArcGIS Notebook Server install directory>\tools\JoinSiteUtility\joinsite.bat. The following are the command line parameters for the utility:Parameter
<ArcGIS Notebook Server install directory>\tools\JoinSiteUtility\joinsite.bat -u notebookPSA -p my.Password3 -s https://notebookserver.domain.com:11443If the account credentials and site URL are entered correctly, the utility will join the machine to the ArcGIS Notebook Server site. Repeat this step for each additional machine.
\\\\myshare\\arcgisserver\\config-store{" configPersistenceType": "FILESYSTEM", "connectionString": "\\\\myshare\\arcgisserver\\config-store"}
Set up a mapped network drive for the workspace directory
This is an optional process that is only necessary if you plan to set up a multimachine Notebook Server site.
Create a UNC share for the ArcGIS Notebook Server workspace directory on a separate machine that is accessible to the Notebook Server.
This directory must have read-write access to the ArcGIS Notebook Server Windows run-as account. It is recommended that you create a UNC share for the ArcGIS Notebook Server workspace directory on a machine separate from the machine participating in the ArcGIS Notebook Server site. There is a known issue in which SMB shares created on the same machine as the Notebook Server will disconnect when restarting the machine.
On the Notebook Server machine, open a PowerShell window as an administrator.
Save your ArcGIS Notebook Server user account password as a secured string for later using the following command:
$password = ConvertTo-SecureString '<password>' -AsPlainText -ForceAdd credential support to the PowerShell functions:
$credential = New-Object System.Management.Automation.PSCredential('<domain\username>', $password)Mount the folder with the Persistent flag set:
New-SmbGlobalMapping -Persistent $true -RemotePath <shared folder path> -Credential $credential -LocalPath <unassigned drive letter>:Repeat steps 2 through 5 on all machines participating in the ArcGIS Notebook Server site and assign the same drive letter for the mapped drive on all machines.
Use the shared network drive created in the previous step to configure the workspace directory when creating the ArcGIS Notebook Server site.
