Configure organization extensions
Organization administrators can configure extensions that add to the existing capabilities of ArcGIS Online.
Enable Workflow Management
The Workflow Management organization extension enables ArcGIS Workflow Manager to complete workflows on behalf of your organization members. This includes all tasks that a member has the privileges to perform, such as creating and sharing an item and editing data.
This extension is only available if ArcGIS Workflow Manager Advanced is configured for your organization.
To enable this extension, complete the following steps:
Verify that you are signed in and assigned the default administrator role or a custom role with the set of administrative privileges to manage the organization's security settings.
At the top of the site, click Organization and click the Settings tab.
Click Organization extensions on the side of the page.
Under Workflow Management, turn on the Allow workflow manager to complete workflows on behalf of the participating users toggle button.
Enable location sharing
Location sharing is an organization-wide extension, allowing you to record where users are and where they have been. Enabling location sharing creates a location sharing layer to which members in your organization with the appropriate privileges can upload their locations using ArcGIS Field Maps, ArcGIS QuickCapture, ArcGIS Survey123, or ArcGIS Indoors Classic mobile apps. Users only see their own tracks, and additional permissions are required to view the tracks of others.
The Share location and Share location history privileges are general privileges included in specific default roles. Administrators can also add these privileges to custom roles.
If location sharing is enabled, organization administrators can use the Track Viewer web app to share last known locations of users and track data with other users in the organization by creating track views. Track views define which users have tracks included in the view and who can view those tracks. The Field Maps, QuickCapture, Survey123 mobile, or Indoors Classic mobile apps are optimized for sharing locations in the background, minimizing the impact on the device battery. The mobile apps record tracks with or without a data connection and provide mobile users with control of when they are and are not tracked.
Do the following to enable location sharing for organization members:
Verify that you are signed in to your organization and assigned the default administrator role or a custom role with the following privileges:
General privileges
Create, update, and delete
Share with organization
Publish hosted feature layers
Administrative privileges
- Utility services
For information about roles and privileges, see Member roles and Privileges granted to roles.
Click Enable location sharing.
A location sharing layer is created. As the administrator who enables location sharing, you own the location sharing layer. The Location sharing folder that is created and that stores all items (layers and track views) needed for location sharing is in your content and owned by you. Administrators in your organization can create track views using the Track Viewer web app, allowing others to view location tracks, but all such views are owned by you. You're the only administrator who can disable location sharing, although all administrators can pause it.
Caution:
If the role of the administrator who enabled location sharing changes to a role that does not have the required privileges for enabling location sharing, other administrators cannot create track views.
If this happens, change the ownership of the location sharing layer (and all of its views) to a different administrator. Once an administrator owns the location sharing layer, other administrators can create track views.
Optionally, click Honor Location Sharing Privileges so that members of your organization can share their location if they have the privileges to share location or share location history.
Manage location sharing
Once location sharing is enabled, organization administrators can manage it as follows:
Pause location sharing
While location sharing is paused, the location tracks remain but are read-only. No new tracks are collected, and mobile users can't upload tracks to the location sharing layer.
Turn off Honor Location Sharing Privileges
When the Honor Location Sharing Privileges toggle button is turned off, members with privileges to share location and share location history are unable to share their location information. Only the administrator who enabled location sharing can turn this off.
Disable location sharing
When location sharing is disabled, all items associated with location sharing (layers, views, groups, and so on) are deleted. The privilege to view location tracks remains associated with any roles to which it was assigned. Only the administrator who enabled location sharing can disable it. If you do not see Disable location sharing, contact the administrator who enabled it.
Location tracks are stored in your organization for 30 days. The storage of tracks does not consume credits.
View location tracks
While mobile users can see only their tracks, other users who are not administrators—such as supervisors and mobile crew managers—may need to view the tracks of others. A track view contains the last known locations and tracks of a set of mobile users. Anyone with the privilege to view location tracks and access to a track view can view the tracks of the specified mobile users.
The privilege to view location tracks is granted to administrators by default and can be added to custom roles. Administrators create track views in the Track Viewer web app, defining the mobile users whose tracks are included in it. The administrator also adds the track viewers who can see the last known locations and tracks of the included mobile users. When a track view is created, an associated group that controls access to the track view is also created. Adding track viewers to the track view adds them to the group.
When track viewers have access to location tracks, they can view them in the Track Viewer web app or another map or app. Track Viewer provides an overview of the last known locations and the tracks of mobile users and allows the track viewer to do simple filtering and analysis. Add the hosted feature layer view of the tracks to your own map or app for a more complete picture of the locations of your mobile users and where they've been in relation to other assets and information important to you. You can also use the tracks for advanced analysis in ArcGIS. See View tracks and Track layers for details.
Location track security
Location tracks are stored in your organization. With ownership-based access control enabled for the location tracks history, users can only see their own tracks. Users who need to see additional tracks must have the privilege to view location tracks and be assigned to a group that contains the track view they need to access. Organization administrators (including the one who creates the location sharing layer) can access all tracks in the layer.
While tracks are collected using the Field Maps, QuickCapture, Survey123, or Indoors Classic mobile apps, they are stored in an SQLite database on the mobile device. Each shared location is created by the user signed in to the app, and editor tracking stores this information with the shared location. When a user signs out of the Field Maps, QuickCapture, Survey123, or Indoors Classic mobile apps, the tracks are removed from the device. Other users who use the app on the device don't have access to the tracks of previous users.
To learn more about deploying cloud and enterprise GIS to comply with privacy regulations, such as GDPR, for location sharing services, see ArcGIS Location Sharing Privacy Best Practices.
