Manage content
Organization administrators can manage content owned by all members in the organization.
Managing content includes the following tasks:
Categorize content—Define the categories that you and other members can add to items to help other users find the items.
Change the owner—When someone leaves the organization or changes responsibilities, you may need to reassign ownership of that member's items.
Delete items owned by others—You may need to delete items that are no longer relevant to the organization. For example, if a member added draft items and did not remove them or items owned by a member who left the organization are no longer needed, you can delete the items.
Restore deleted items—Certain items are stored in a recycle bin for 14 days after they are deleted. If the items were deleted in error and the owner is not available to restore them, the administrator can restore them.
Delete items from the recycle bin—You can permanently delete items from the recycle bin before ArcGIS Online automatically deletes them. You can do this to save credits.
Manage item details and settings—Update the details for items, such as their descriptions, tags, summary, and usage restrictions. You can also update settings for items.
Share or move items—Manage another member's items by moving them to a different folder owned by that member or change the sharing settings for one or more of the member's items.
Manage running notebooks—View and manage running notebooks from the Notebooks page.
Designate content as authoritative—You can define what content is considered the most accurate and reliable. By marking an item as authoritative, you communicate to users that the item is the best version of the content available in the organization.
Tip:
Before you manage content, decide whether you will manage content for a specific organization member or manage content for the entire organization.
Manage items owned by a specific member
If an item owner is unable to manage their items—for example, if the employee is on vacation or extended leave—you can manage their items. Other situations in which you would manage the items owned by a specific member is if the member leaves the company and you need to transfer their items to another user or you need to restore items from the recycle bin, as you cannot restore items owned by different members at the same time.
To manage content owned by a single user (except notebooks), complete the following steps to access that user's content page:
Verify that you are signed in to your organization.
Your account must be a member of the default administrator role or a custom role assigned the set of privileges to manage all content owned by organization members.
At the top of the site, click Organization, and click the Members tab.
Search for members by name or username and apply filters to narrow the members list. Sort the list as desired, such as by name or last login date.
Click the Options button
in the row for the organization member, and choose Items.The user's content appears.
You can proceed with managing that user's content.
Manage content for the entire organization
To manage items (except notebooks) owned by more than one organization member, complete the following steps to access the content for the organization:
At the top of the site, click Content, and click the My organization tab.
All content stored in the organization is displayed.
You can proceed with managing the organization's content.
Categorize content
If you have the appropriate privileges, you can set up hierarchical categories for organizing content in your organization. Once categories are set up, you can use them to categorize items in your organization so that members can more easily find the content they need when searching or browsing.
Categories help others quickly discover maps, scenes, apps, and other items. You can configure categories to organize content across the organization (as described below) or content shared with specific groups.
Set up categories
You can create custom categories or use standard category sets from ArcGIS (presented in ArcGIS Living Atlas), the International Organization for Standardization (ISO), or INSPIRE as a starting point.
You can configure content categories for your organization from the content page or, if you are a member of the default administrator role, from the Items tab of the organization settings.
To configure categories from the content page, complete the following steps:
Your account must be a member of the default administrator role or a custom role assigned the set of privileges to manage categories.
At the top of the site, click Content.
On the My content tab, under Categories, click Set up content categories.
If you already set up categories, click the Configure categories button
to add, rename, delete, or reorder categories as needed.Choose one of the following:
Custom categories—Create categories to organize content in the organization.
ArcGIS categories—Use ArcGIS categories as a starting point. You can customize them or leave them unchanged. These categories are presented in ArcGIS Living Atlas.
ISO categories—Use topic categories from the ISO as a starting point. You can customize them or leave them unchanged. ISO publication 19139 provides a method to describe and catalog geographic information.
INSPIRE categories—Use theme categories from the INSPIRE Directive as a starting point. You can customize them or leave them unchanged.
If you selected Custom categories in the previous step, create a category hierarchy as follows:
Click the Add category button
, provide a name for the category (using up to 100 characters), and click Add.To create subcategories, click the Add subcategory button
, provide a name for the subcategory (using up to 100 characters), and click Add.Create additional top-level categories and subcategories as needed.
If you selected ArcGIS categories, ISO categories, or INSPIRE categories, do any of the following to review or make changes to the category hierarchy:
Expand and collapse categories in the category tree as needed using the expand button
and collapse button
next to the categories.To add a category or subcategory, click the Add category button
or Add subcategory button
, provide a name for the category or subcategory (using up to 100 characters), and click Add.
Do any of the following to make additional changes to the categories as needed:
Click the Edit category button
for the category or subcategory to rename, provide a new name (using up to 100 characters), and click Update.Click the Delete category button
for the category or subcategory to delete.Hover over the expand button
or collapse button
next to the category and drag it to a different location.
When you finish setting up categories, click Save.
You can have up to three levels of categories in the hierarchy, with a maximum of 900 categories and subcategories in total. For efficiency, it is recommended that you create a comprehensive and complete category hierarchy and naming scheme before assigning items to categories.
Categorize items
Once content categories are configured, you can categorize items in the organization. Categorizing content helps organization members find the content they need.
To categorize items, complete the following steps:
Access the content for a single member or the entire organization.
Select one or more items to categorize, and click Categorize.
Do any of the following:
To categorize all selected items at once, check the boxes next to the categories and subcategories as applicable. Each item card updates to show the categories you selected.
Selecting a subcategory automatically selects all associated categories and subcategories above it in the hierarchy. However, selecting a category does not automatically select its subcategories.
To categorize items individually, click Assign categories on the item card, and select the categories you want. You can assign up to 20 categories to each item.
To remove all selected items from a specific category or subcategory, uncheck the boxes to deselect the appropriate category or subcategory. Each item card updates to reflect the category you removed.
When deselecting categories and subcategories, the following occurs:
Deselecting a category or subcategory automatically deselects all of its associated subcategories.
Deselecting a subcategory when no other subcategories are selected at the same level also deselects the associated categories above it and subcategories below it.
To remove an individual item from a category, click Remove
next to the category on the associated item card.To undo or redo a category assignment, click the Undo button
or Redo button
as needed.
When you finish categorizing the items, click Save.
The items are organized into the categories you specified.
When you categorize an item, it is recommended that you choose the most specific and relevant category possible to ensure that the item is displayed and discovered as expected in an appropriate grouping. For example, to categorize a web map, choose Maps > Web Maps instead of Maps.
Change the owner
You can transfer all items owned by specific members or change the ownership of specific items in the organization.
When you transfer the ownership of an item shared with one or more groups, the new owner must be a member of all groups with which the item is shared. In addition, the Who can contribute content setting of each group must allow the new owner to share items with the group. For example, if the item is shared with a group that only allows the group owner or group managers to contribute content, the new owner of the item must be that group's owner or manager.
Tip:
Changing layer ownership changes ownership of the file from which the layer was created. When you change the owner of a hosted feature layer, ownership changes for its dependent hosted layers as well. However, you cannot change the owner of a hosted feature layer that has dependent layers in the recycle bin. Either restore the dependent layers or, if they are not needed, delete them.
Changing the owner of a layer does not change the owner of the maps and scenes in which the layer is used. Similarly, changing the owner of maps and scenes does not change the ownership of the layers inside them, nor does it change the owner of the apps in which the maps and scenes are used.
Transfer all content owned by specific members
You can transfer content owned by one or more organization members to another member of your organization. Transferring all content in bulk to a new owner is useful when you need to delete members but want to keep their content in the organization. You can also transfer ownership of items during the member deletion process when deleting a single member.
Items in the recycle bin are not transferred to the new owner. Review the contents of each member's recycle bin to ensure that the items do not need to be restored and transferred to another owner.
To transfer content owned by specific members, complete the following steps:
Your account must be a member of the default administrator role or a custom role assigned the administrative privileges to reassign ownership of content.
Organization members with the privilege to reassign content can transfer ownership of only their items to other members, as long as the other members have the privilege to receive content.
Check the box next to each of the members whose content items you want to transfer.
Tip:
You can select up to 100 members at a time. The selected set is maintained while you search and filter all the members in your organization, even across multiple pages. If necessary, click the members selected drop-down menu to review and revise your selection once you've modified your initial search or filter.
Above the list of members, click More, and click Transfer content.
In the Transfer content window, click to select a new owner for the content.
You can search for members by name or username to narrow the members list.
Optionally, to transfer content from a single member, select one of the following target folder options:
Maintain folder structure—Transferred items will be stored in folders that have the same names as the original item owner's folders. If duplicate folder names are detected, the original owner's content will be put into the new owner's existing folder with the same name. The original owner's root folder will not be maintained, and the content in their root folder will be transferred to the new owner's root folder. If the original owner has an empty folder, it will not be maintained for the new owner.
Select one folder for all content—Transferred items are all stored in a single folder. Select or create a folder, or keep the default folder.
Optionally, to transfer content from more than one member, select one of the following target folder options:
Folder for each previous owner—Transferred items are stored in separate folders named for each of the current item owners. Provide a specific prefix for each folder name, or accept the default prefix of
from. For example, typing hosted layers for the prefix creates folders namedhosted layers_[previous owner's username]in which[previous owner's username]is the name of the member from whom the content is being transferred.Only one folder—Transferred items are all stored in a single folder. Select or create a folder, or keep the default folder.
Click Transfer.
Tip:
Before clicking Transfer, you can review the list of items being transferred by clicking the View all items button
under Content to transfer.The items are transferred to the new owner that you specified.
Transfer files in a notebook workspace
To change ownership of a member's workspace, which transfers all content in the workspace to another member in your organization, complete the following steps:
Go to the Notebooks tab, click Manage, and click Workspace files.
Click inside the member dialog box
.Use the search as needed to find the member's workspace.
If you do not see a username listed, the member does not have a notebook workspace.
Select the member, provide their workspace name, review their files, and click the Transfer workspace button
.Select the member to whom you want to transfer the workspace, and provide a folder name or accept the default of
_transferred_[previous owner's username].Transferred items are all stored in a single folder.
Click Transfer content.
The member's workspace is transferred to the new owner that you specified.
Change the ownership of specific items
You can change the ownership of specific items in the organization in bulk. This is useful when you have a large number of items owned by organization members that you want to reassign to a new owner.
Tip:
On the Members tab of the organization page, you can manage content owned by a specific member, including reassigning their content to another member.
To change the ownership of specific items, complete the following steps:
Use the filters, sort options, and search as needed to find the items to reassign.
Select the items, and click Change Owner.
In the Change owner window, search for and select a new item owner, and select or create a folder as needed.
Click Save.
The items are reassigned to the new owner that you specified.
As an organization administrator, you can delete items owned by other organization members. You can delete organization items in bulk from the My organization tab of the content page.
Tip:
You can delete content owned by a specific member and perform other content management tasks for individual members on the Members tab of the organization page.
To delete items owned by others, complete the following steps:
Access content for a single member or the entire organization's content.
Use the filters, sort options, and search to find the items you need to delete.
Select the items to delete, and click Delete.
The items are moved to the recycle bin.
To immediately delete the items instead, click Show more, click Delete permanently, and click Permanently delete to confirm.
Caution:
Once they are permanently deleted, items are no longer available and cannot be recovered.
Dependencies exist between some items, such as between a hosted tile layer and the tile package from which it was published or between the hosted feature layer view and the hosted feature layer from which it was created. Both the item you chose and its dependent items are moved to the recycle bin (if supported for those item types) or permanently deleted. You cannot delete or permanently delete a hosted feature layer before deleting or permanently deleting its dependent layers.
Restore items
Before an item is permanently removed from the organization, you can restore it from the recycle bin.
You cannot restore dependent layers if you do not restore the parent hosted feature layer.
Restore a single item
To restore one item from the recycle bin, complete the following steps:
To access the recycle bin, do one of the following:
If you know who owns the item, open that user's content page, and click Recycle bin
under Folders.If you only know the item name, open the organization's content page, and click Recycle bin
under Content type.
Optionally, type a keyword or sort a page in the recycle bin to help you find the item.
Type a keyword in the find box. Only the current page of the recycle bin is searched. If the item you're trying to find is not returned and the recycle bin contains more than one page, move to the next page and try again.
Click the Size or Date deleted headings to change the sort order for those properties on the page of the recycle bin.
Check the box next to the item to be moved back to My content for the original owner of the item.
Click Restore for the item.
To restore the item to a different folder, do one of the following:
Choose a folder from the Restore to drop-down menu.
To create a folder in which to restore the item, choose Create new folder from the Restore to drop-down menu, provide a name for the folder, and click the check mark button
Tip:
If you don't click the check mark button, the folder is not created and the item is restored to the original owner's default folder.
Click Restore to confirm.
Restore multiple items
All items must belong to the same user for you to restore them all at once.
To restore multiple items at one time from the recycle bin, complete the following steps:
If you know who owns the items to be restored, open that user's content page, and click Recycle bin
under Folders.If you only know the item names, open the organization's content page, and click Recycle bin
under Content type.
Optionally, type a keyword or sort a page in the recycle bin to help you find items.
Click the Size, Date deleted, or Title headers to change the sort order for those properties on the page of the recycle bin.
Check the boxes next to each item on the page to be moved back to My content for the original owner of the items.
If you are working in the organization's content page, ensure that the same user owns the items.
You can select up to 20 items at a time to restore.
Click Restore at the top of the recycle bin item list.
Tip:
All items are restored to the same folder. Create a folder specific for restored items so you can inspect them before sharing them.
If you don't click the check mark button, the folder is not created, and the item is restored to the original owner's default folder.
To delete items from the recycle bin permanently before their expiration date (14 days from the time they were moved to the recycle bin), open the recycle bin, select the items to delete, and permanently delete them.
One reason to delete items from the recycle bin is to save the cost of storing the items. Information about how much space is being used by the recycle bin contents appears at the top of the recycle bin.
To delete items from the recycle bin, complete the following steps:
To permanently delete items owned by a specific user, open that user's content page, and click Recycle bin
under Folders.To permanently delete items across the organization, open the organization's content page, and click Recycle bin
under Content type.
Check the box next to each item to be deleted, and click Permanently delete.
To select and delete all items on the page, check the check box at the top of the recycle bin item list.
Click Permanetly delete to confirm.
You can manage details and settings on other users' items.
To open the item page of a single item to edit properties or settings, complete the following steps:
Use the filters, sort options, and search as needed to find the items to manage.
To edit the properties and settings of a specific item, click the title of the item, and make changes on the Overview and Settings tabs of the item page.
Manage deletion settings for multiple items
You can enable or disable delete protection for multiple items that are owned by the same organization member.
To change the setting for multiple items that you own, complete the following steps:
Access the content for a single member.
Check the box next to each item for which you need to change the delete protection setting.
Click More at the top of the item list, and choose one of the following settings from the drop-down menu:
Enable delete protection—The configuration for the selected items changes immediately.
Disable delete protection—You must click Confirm to proceed with disabling delete protection for the selected items.
Share or move items
You can change the sharing properties of a member's items, such as making a public item private, or you can move one or more items owned by that member to a different folder.
To share or move items, complete the following steps:
Check the box next to each item to manage, and do any of the following:
To change the sharing properties of items, click Share, and select the sharing level to update with whom the items are shared—the owner, the organization, or everyone (public). To update the groups with which the items are shared, click Edit group sharing, and choose the group or groups with which to share the items.
Choose Move from the More drop-down menu at the top of the item list, and select an existing folder or create one.
Neither of the options above change the location on disk or ID of the items.
Click Save.
You can view and manage running notebooks from the Notebooks home page. Additionally, administrators can view and manage all running notebooks in the organization.
Notebook containers are automatically deleted after 30 minutes of inactivity. The maximum uptime of an interactive notebook is 24 hours. After the maximum uptime, the notebook container is automatically deleted.
To view and manage running notebooks, complete the following steps:
At the top of the site, click Notebooks.
The Notebooks home page appears.
Click Manage, and click Running notebooks.
In the Manage running notebooks window, view the following:
Notebook environment—The active notebook runtime
Version—The runtime version corresponding to available Python libraries
Type—The notebook type, which includes the following:
Interactive—Opened notebooks
Scheduled—Tasks
System—Web tools
Notebooks—The number of notebooks running in the environment
Member—The user who launched the container by opening a notebook
Uptime—The length of time the notebook environment has been running
Click Filters to adjust the search filters.
Tip:
You can use filters to help find the notebooks you need to manage. For example, to manage only advanced runtime notebooks, you can filter by notebook environment to only show advanced notebooks.
Optionally, click the expand button
next to the following filter options, and find the notebooks you need to manage:Notebook environment—Standard, Advanced, or Advanced with GPU support.
Version—Available Python libraries.
Username—Search for usernames.
Type—Interactive or Scheduled.
Click the expand button
to display the following information for the notebooks open in each container:Title—The title of the notebook. Clicking the title opens the notebook.
Last active—The time the notebook was last modified.
Close notebook—Close the notebook.
To delete a running container, click Delete container
next to the container you want to delete.Deleting a notebook container stops the associated notebooks from running without deleting any notebook items.
Click Close to exit the manager.
Designate items as authoritative
Items can be designated as authoritative to indicate to others that the item is the best version of specific content. This is helpful when there are many versions of similar content in the organization.
To label an item as authoritative, complete the following steps:
Open the item page and click the Settings tab.
Click the Mark as Authoritative button.
The item is identified to all users with an Authoritative badge, and the Prevent this item from being accidentally deleted option is automatically enabled on the item.
If your organization is verified, items that are shared with everyone (the public) and marked as authoritative display the organization name as the item owner on the Overview tab.
Organization members can use the Status filter to find content marked as authoritative when they browse or search for content in their organization. The Status filter is also available to users outside the organization when a verified organization shares authoritative content with everyone. Authoritative content is boosted in search results, and users can limit searches to layers marked as authoritative when adding layers to a map in Map Viewer.
