Manage members
After you invite or add members to your organization, you can manage their accounts, as described in the sections below.
Tip:
Use the filters and sort options to help find the members you need to manage. For example, to change the user type for members with the same user type, role, and group membership, you can filter the list to show only members who match that set of criteria. You can also filter by assigned licenses, last login date, login type, and more.
Modify profile
You can modify a member's profile and settings, such as their profile photo, bio, profile visibility, language, and email address.
To modify a member's profile and settings, complete the following steps:
  1. Verify that you are signed in to your organization.
    Your account must be a member of the default administrator role or a custom role assigned the set of administrative privileges to manage member profiles.
  2. At the top of the site, click Organization, and click the Members tab.
  3. Search for members by name or username and apply filters to narrow the members list. Sort the list as desired, such as by name or last login date.
  4. Click the More options button for the member whose profile you want to modify, and click Profile.
  5. On the member's profile page, update any of the following: profile photo, member name, bio, or profile visibility.
  6. To edit the member's settings, such as their email address, start page, language, and units, click View <member name>'s settings and modify the settings.
Change email address
If a member's profile is changed or their password is reset, ArcGIS Online sends the member an automated email notification. Always verify that ArcGIS Online has the correct email address for all members. You can see a member's email address on the member's settings page and on the Members tab of the organization page. Default administrators can change the email addresses of members if necessary.
To edit a member's email address on the Members tab, complete the following steps:
    Your account must be a member of the default administrator role.
  4. Click the More options button for the member whose email address you need to modify, and click Edit email address.
  5. Provide the new email address for the member twice to confirm it is correct, and click Save.
Categorize members
As an administrator or a member with the administrative privileges to manage member categories, you can set up hierarchical categories for organizing members in your organization according to characteristics such as department, location, and expertise. Once categories are set up, members with the privilege to update member information can categorize members in the organization. This allows you and others in the organization to filter the members list by member category to find specific members. A member's assigned categories are displayed on their settings page and can be viewed by the member and those with the privilege to view members.
Set up categories
To configure member categories on the Members tab of the organization page, complete the following steps:
    Your account must be a member of the default administrator role or a custom role assigned administrative privileges to manage member categories.
  2. At the top of the site, click Organization.
  3. Click the Members tab.
  4. Under Categories, click Set up member categories.
    Tip:
    If some member categories have already been configured, click Configure categories to add, rename, delete, or reorder categories as needed.
  5. In the text box, provide a category name (using up to 100 characters), and click Save .
  6. Optionally, click Add category , provide a name, and click Save to create a subcategory.
  7. Repeat the previous steps to create additional top-level categories and subcategories.
  8. Do any of the following to make additional changes to the categories:
    • Click Edit category , provide a different name, and click Save to rename a category or subcategory.
    • Click Delete category next to a category or subcategory to delete it.
    • Click Reorder next to a category or subcategory, and drag it to a new position in the hierarchy.
  9. Close the Configure member categories window when you are finished setting up categories.
You can now assign the categories you created to members in the organization.
You can have up to three levels of categories in the hierarchy, with a maximum of 200 categories and subcategories in total. For efficiency, it is recommended that you create a comprehensive and complete category hierarchy and naming scheme before assigning categories to members.
Assign categories to members
Once member categories are configured, those with the privileges to update member information can categorize members in the organization on the Members tab of the organization page. Alternatively, you can assign member categories to one or more members during the invitation process or configure your organization to automatically assign a set of default member categories to new members who are added or invited to join the organization.
To assign member categories on the Members tab of the organization page, complete the following steps:
    Your account must be a member of the default administrator role or a custom role assigned administrative privileges to update members.
  4. Use the filters, sort options, and search capability as needed to find one or more members to categorize.
  5. Select one or more members, and click Categorize.
  6. Do any of the following:
    • Check the check boxes to select categories and subcategories to assign them in bulk to the selected members.
      Selecting a subcategory automatically selects all associated categories and subcategories above it in the hierarchy.
    • Uncheck the check boxes to remove all selected members from a specific category or subcategory.
      When deselecting categories and subcategories, the following occurs:
      • Deselecting a category or subcategory automatically deselects all of its associated subcategories.
      • Deselecting a category or subcategory when no other subcategories are selected at the same level also deselects the associated categories above it and subcategories below it.
    • Click Assign Category on the member card, and select one or more categories to categorize an individual member.
      You can assign up to 20 categories to each member. You can also use the Filter categories text box to narrow the options.
    • Click the remove button next to the category on a member card to remove a category assignment for an individual member.
  7. Click Done when you are finished assigning categories.
    The members are organized into the categories you specified. Members can view their assigned categories on their settings page. Organization administrators and members with the privilege to view members can also view a member's assigned categories on the member's settings page and can use the Categories filter on the Members tab to find specific members.
Manage credit budget
You can allocate a credit budget that assigns a flexible allocation of credits to some or all organization members. This option only appears when credit budgeting is configured for the organization. Credit budgeting applies to transaction-based services and tools, such as data enrichment and spatial analysis.
To allocate a credit budget, complete the following steps:
    Your account must be a member of the default administrator role or a custom role assigned the set of privileges to manage the organization's credit settings.
  4. Select the member or members to whom you want to allocate credits, and click Manage credits.
  5. Set allocation to a specific number of credits or no allocated limit, and click Save.
Change user types
User types determine the privileges and apps that are available to members. Once assigned, user types can be changed by those with the appropriate privileges.
Caution:
User types may be reassigned no more than once in any 30-day period, except in the event of the assigned individual’s permanent role change, extended leave, or departure from the member's organization.
To change user types, complete the following steps:
    Your account must be a member of the default administrator role or a custom role assigned the set of privileges to change a member's user type.
  4. Do one of the following:
    • To change the user type of one member, click the More options button for the member, and click User type.
    • To change the user type of multiple members at once, check the check box next to the name of each member, and above the list of members, click Manage user types.
    Tip:
    You can select up to 100 members at a time. The selected set is maintained while you search and filter all the members in your organization, even across multiple pages. If necessary, click the members selected drop-down menu to review and revise the selection once you've modified the initial search or filter.
  5. In the window that appears, select a user type, select a role (if necessary), and click Save.
    The user type can be changed to one with fewer capabilities if the member satisfies the corresponding requirements. For example, you can change a member from Creator to Viewer as long as the following conditions are met:
    • The member does not own content or groups, and the member's recycling bin is empty.
    • The member does not have add-on licenses assigned that are incompatible with the new user type.
    • The member does not belong to shared update groups.
    If the conditions above are not met, the organization administrator must reassign that member's content and groups, revoke the add-on licenses, and remove the member from these groups before changing their user type.
Change member roles
A role defines the set of privileges assigned to a member. Once assigned, roles can be changed. When you assign a role, it must be compatible with the member's assigned user type.
To change a member's role, complete the following steps:
    Your account must be a member of the default administrator role or a custom role assigned the set of privileges to manage the organization's member roles.
  4. To change the role of one member, click the member's current role, and choose a new role in the window that appears.
  5. Click Save.
  6. To change the role of multiple members at once, do the following:
    1. Check the check box next to the name of each member whose role you want to change.
      Tip:
    2. Above the list of members, click Manage user types.
    3. In the window that appears, search for the role you want (if needed), and select it.
      Only the roles that are compatible with all the user types assigned to the selected members are shown.
    4. Click Save.
Transfer member
Organization administrators can transfer a member's user type, role, content, groups, add-on licenses, settings, and member categories to another existing member.
To transfer a member, complete the following steps:
    You must sign in as a member of the default administrator role or a custom administrative role that has privileges to manage members, content, and groups.
  4. Click the More options button for the member you want to transfer.
  5. Click Transfer member.
    The Transfer member window appears.
  6. On the New member tab, select Keep account or Delete account.
  7. Optionally, select Change user type and role after transfer.
  8. Use the Transfer to search to find and select the member you want to transfer to.
    The current user type and role and the new user type and role of the member you are transferring to appear.
  9. Click Next.
    The Content and groups tab appears.
  10. Select one of the following target folder options:
    • Maintain folder structure—Transferred items will be stored in folders that have the same names as the original item owner's folders. If duplicate folder names are detected, the original owner's content will be put into the new owner's existing folder with the same name. The original owner's root folder will not be maintained, and the content in their root folder will be transferred to the new owner's root folder. If the original owner has an empty folder, it will not be maintained for the new owner.
    • Select one folder for all content—Transferred items are all stored in a single folder. Select or create a folder, or keep the default folder.
  11. Optionally, do any of the following:
    • Under Content to transfer, click View all to review the member's content.
    • Click View content in recycle bin to recover items to the member's content. Otherwise, content in the recycle bin will not be transferred.
    • Under Groups to transfer, click View all to review the member's groups.
  12. Click Next.
    The Additional settings tab appears.
  13. Click Transfer member.
The member's user type, role, content, groups, add-on licenses, settings, and member categories are transferred to the member selected.
Reset password
Organization members who have privileges to update member account information can reset passwords for members. The system sends an email with a temporary password to the member. After the member successfully signs in with the temporary password, they are prompted to change their password. If the member is currently signed in when you reset their password, they are immediately signed out.
You cannot reset passwords for organization-specific (SAML and OpenID Connect) logins.
  1. Verify that you are signed in to your organization and that you have privileges to update member account information.
  4. Click the More options button for the member whose password you want to reset, and click Reset password.
The member receives an email with a temporary password. When they sign in, they are immediately prompted to change their password.
Disable multifactor authentication
Administrators can disable multifactor authentication on an ArcGIS account. This option only appears when the organization is configured for multifactor authentication and the member has enabled it through their profile page.
To disable multifactor authentication, complete the following steps:
  1. Confirm that you are signed in to your organization and have administrative privileges to manage the organization's security settings.
  4. Click the More options button for the member for whom you want to disable multifactor authentication, and click Disable multifactor.
The member receives an email notification that multifactor authentication is disabled for their account.
Enable Esri access
Administrators can enable and disable Esri access on member accounts.
A member whose account has Esri access enabled can use My Esri, take training courses, participate in Esri Community, add comments to ArcGIS Blog articles, and manage email communications from Esri. The member cannot enable or disable their own access to these Esri resources.
The member's full name, username, and email address will be made available to Esri, who may contact or send the member materials through email.
To enable or disable Esri access for individual members on the Members tab of the organization page, complete the steps below. Alternatively, you can enable Esri access for one or more members during the invitation process, or configure your organization to enable Esri access by default for new members who are added or invited to join the organization.
  1. Verify that you are signed in as an administrator of your organization.
  4. Click the More options button for the member for whom you want to enable access, click Enable Esri Access, and click OK.
  5. To disable Esri access for the member, click the More options button , click Disable Esri Access, and click OK.
Disable member accounts
If you are an administrator of your organization or you have the appropriate privileges, you can disable member accounts in your organization.
Disabling a member account prevents the member from consuming organizational resources. This can be useful while you transfer their items to a different member. Members whose accounts have been disabled cannot sign in to the organization, consume organizational resources, create content, or administer the site. They are still members and count toward the number of users in your organization. Disabled accounts are automatically disabled for Esri access.
If the member owns content or groups, you must transfer their content and groups to a different member when you delete the member account.
To disable individual member accounts or accounts for a selected set of members (up to 100 at a time), complete the following steps:
  1. Verify that you are signed in to your organization and that you have privileges to disable member accounts.
  4. Check the check box next to the name of each member whose account you want to disable, and above the list of members, click the More menu, and select Disable member account (or Disable member accounts if multiple members are selected).
    Tip:
  5. To enable one or more disabled member accounts, select the member or members, and above the list of members, click the More menu, and select Enable member accounts.
Delete members
If you are an administrator of your organization or you have the appropriate administrative privileges, you can delete members when you want to remove accounts from your organization. Only members with the default Administrator role can delete other administrators.
If you are deleting a single member who owns content and groups, you must either transfer their content and groups to a different member or delete their content and groups. If you are deleting members in bulk, you can either transfer or delete their content. You cannot transfer groups when deleting members in bulk; their groups will be deleted.
When you transfer the ownership of an item shared with one or more groups, the new owner must be a member of all groups with which the item is shared. In addition, the Who can contribute content setting of each group must allow the new owner to share items with the group. For example, if the item is shared with a group that only allows the group owner or group managers to contribute content, the new owner of the item must be that group's owner or manager.
Tip:
Changing layer ownership changes ownership of the file from which the layer was created. When you change the owner of a hosted feature layer, ownership changes for its dependent hosted layers as well. However, you cannot change the owner of a hosted feature layer that has dependent layers in the recycle bin. Either restore the dependent layers or, if they are not needed, delete them.
Changing the owner of a layer does not change the owner of the maps and scenes in which the layer is used. Similarly, changing the owner of maps and scenes does not change the ownership of the layers inside them, nor does it change the owner of the apps in which the maps and scenes are used.
If the member has licenses assigned, the licenses are automatically revoked when you delete the member. For some Esri products, such as ArcGIS Pro and ArcGIS Drone2Map, licenses must be checked in by the member before you can revoke them.
If the member you delete has items in the recycle bin, those items will be permanently deleted.
Deleted members no longer have access to their organizational account or any content or groups they previously owned. If the organization prevents anonymous access, they cannot access the organization site.
When you delete a member with an ArcGIS account that has Esri access enabled, you can either remove the member from the system completely or retain their Esri account after deletion. If you keep Esri access for the deleted member, their account is still available to use with Esri web resources such as My Esri and Esri Community. This option also converts their ArcGIS organizational account to a public account; however, they will not have access to any content or groups that became associated with the organization.
Deleted members with organization-specific (SAML and OpenID Connect) logins can no longer access the organization and, if they were enabled for Esri access, they no longer have access to Esri web resources. Deleted members can still use these logins to sign in to their organization-specific information systems.
To delete members, complete the following steps:
  1. Verify that you are signed in to your organization and that you have privileges to delete members.
  4. Ensure that the licenses of add-on applications, such as ArcGIS Pro, that are assigned to the member have been checked in.
    When you delete the member, these application licenses will be automatically revoked. If they are still checked out, you can't delete the member.
  5. To delete a single member, do the following:
    1. Click the More options button for the member you want to delete from the organization, and click Delete member.
    2. If the member owns content or groups, either transfer ownership of the items and groups to another member or delete the items and groups by doing one of the following:
      • Click Transfer content and groups, click Next, and in the Delete member window, search for and select the member you want to transfer ownership to. The new owner must have privileges to own content and groups. To review the list of items and groups being transferred, click the View all button .
      • Click Delete content, and click Next.
    3. Optionally, if you selected Transfer content and groups, choose one of the following target folder options:
      • Maintain folder structure—Transferred items will be stored in folders that have the same names as the original item owner's folders. If duplicate folder names are detected, the original owner's content will be put into the new owner's existing folder with the same name. The original owner's root folder will not be maintained, and the content in that folder will be transferred to the new owner's root folder. If the original owner has an empty folder, it will not be maintained for the new owner.
      • Select one folder for all content—Transferred items will be stored in a single folder. Select or create a folder, or keep the default folder.
  6. If you're deleting multiple members, do the following:
    1. Check the check box for each member you want to delete, click the More drop-down menu, and choose Delete members.
    2. If one or more members own content, either transfer ownership of the items to another member or delete the items by doing one of the following:
      • Click Transfer content, and click Next. When deleting multiple members, groups cannot be transferred and will be deleted. In the Delete members window, search for and select the member you want to transfer ownership to. The new owner must have privileges to own content. To review the list of items being transferred, click the View all button .
        Tip:
        Reassign group ownership before deleting members in bulk to retain groups.
    3. Optionally, if you selected Transfer content, choose one of the following target folder options:
      • Folder for each previous owner—Transferred items will be stored in separate folders named for each of the current item owners. Provide a specific prefix for each folder name, or accept the default prefix. For example, typing hosted layers for the prefix creates a folder named hosted layers_[previous owner's username] in which [previous owner's username] is the name of the member from whom the content is being transferred.
  7. Optionally, if the member has Esri access enabled, check the Keep Esri access check box.
    If you check the check box, the member's account is still available to use with Esri web resources such as My Esri and Esri Community. Checking this option also converts the member's ArcGIS organizational account to a public account.
  8. When you finish, click Delete member.
    Only members of the default administrator role can delete other administrators.
    The members are deleted from the organization, and their groups and content are either transferred to the specified member or deleted. Any add-on licenses are revoked and available to assign to other members.
