Create groups
Groups are collections of items, often related to a specific region, subject, or project, that are created and managed by the group owner. If you have privileges to create groups, you decide who can find your groups, whether others can request to join, whether members can update items shared with the group, who can contribute content, and the type of items (for example, maps or layers) displayed by default in the group. You also have control over items shared with the group and can invite others to join, even if your group doesn't accept membership requests. Organization administrators can also restrict who can see the list of group members and restrict members from leaving the group (administrative groups).
Organization administrators also use groups to configure the website with the organization's featured content (gallery page, home page, and basemaps), and to configure an ArcGIS Hub catalog.
Create a group
To create a group, complete the following steps:
  1. Verify that you are signed in to your organization.
    You must be a member of a role with the privilege to create groups.
  2. Click Groups at the top of the site, and click Create group on the My groups tab.
  3. Upload a thumbnail image to represent the group.
    You can drag an image or browse to a file. For best results, add an image that is 400 by 400 pixels or larger with an aspect ratio of 1:1 in a web file format such as PNG, JPEG, or GIF. Pan and zoom to what you want to appear in the thumbnail. Depending on the size and resolution of the image file and how far you zoom in to customize the thumbnail, the image may be resampled and scaled when it's saved. If you add an image in GIF or JPEG format, it will be converted to PNG when it's saved.
  4. Provide a group name and tags.
  5. Optionally, add a short summary.
  6. For Who can view this group?, select one of the following:
    • Only group members—Only members of the group can find and view the group. Members must be invited to join the group.
    • All organization members—Only members of the organization or a partnered organization can find and view the group. Members can be invited to the group or apply to join.
    • Everyone (public)—Anyone can find and view the group, even if they are not a member of the organization. This is the default.
    Your sharing privileges may determine the options you can select. If you have a public account, the Everyone (public) option is the only option and can't be changed.
    Tip:
    If your group will contain curated content to feature on your organization's Gallery page, select the option most appropriate for your intended audience. If you expect public visitors to view the gallery, select Everyone (public). Select All organization members if you expect organization members to visit. Whether content items appear in the gallery also depends on how the items are shared.
  7. For Who can be in this group?, select one of the following:
    • My organization's members only—Only members of your organization can be added to the group.
    • Partnered collaboration and my organization's members only—Only members of your organization or organizations that you are in a partnered collaboration with can join.
      This option is only available when a partnered collaboration has been established.
    • Any organization's members—Any organization member can join the group without being invited or approved. Members of other organizations can join the group as long as they have privileges to join external groups.
  8. For How can people join this group?, select one of the following:
    • By invitation—Only members who are invited by the group owner or a group manager can join the group.
    • By request—Only members who request to join the group and are approved by the group owner or a group manager can join the group.
    • Being a member of a SAML group—Membership is controlled by an external group managed by a SAML 2.0 identity provider (IdP). Each user's membership in the group is defined in the SAML assertion response received from the IdP every time the user successfully signs in.
      This option is only available if the following conditions are met:
      • You are an administrator with the privilege to link to organization-specific groups.
      • An administrator has enabled SAML-based group membership for your organization.
      • The Who can be in this group setting is set to My organization's members only.
      To define the group, type the exact name (not case sensitive) of the group in the text box.
      The group name you provide must match the exact value of the external SAML group as it is returned in the attribute value of the SAML assertion. If you aren't sure of the correct value, contact the administrator who configured your organization's SAML system.
    • Being a member of an OpenID Connect group—Membership is controlled by an external group managed by an OpenID Connect identity provider. Each user's membership in the group is defined in the group's claim response received from the identity provider every time the user successfully signs in.
      To define the group, check the Being a member of an OpenID Connect group check box and type the exact name (not case sensitive) of the group in the Group name text box.
      The group name you provide must match the exact value of the external OpenID Connect group. If you aren't sure of the correct name, contact the administrator who configured your organization's OpenID Connect system.
    • By adding themselves—Any organization member can join the group without being invited or approved. Members of other organizations can join the group as long as they have the privilege to join external groups. Members who click Join this group on the group page are instantly granted membership in the group.
    The options you see depend on the type of account you have (organizational or public), the option you selected in the previous step, and your privileges. If you have a public account, you can choose between By request and By invitation. The By adding themselves option is not available for users with public accounts, as those users can't create (or join) groups with this option enabled.
  9. For Who can contribute content?, select one of the following:
    • All group members—All group members can contribute content to the group.
    • Group owner and managers—Only you (the group owner) and group managers can contribute content to the group. If you choose this option, members can view and access your items, but they can't share their own items with the group. This type of group is a good way to share your authoritative maps and data to a targeted audience. You control what items appear in the group and who can view them.
  10. For Who can see the full list of members on the group's Members tab?, choose one of the following:
    This setting is only available to default administrators and users with a custom role. It is not available for SAML-based groups.
    • Anyone who can view the group—Anyone who can view the group can see the list of group members.
    • Group owner and managers—Only the group owner and managers, and those with administrative privileges to view all members and groups, can see the full list of group members. Other members of the group will only see the group owner and group managers listed on the Members tab. Choose this option for public groups, such as community and crowdsourced groups, for which you want to protect the privacy of group members.
      The item owner will still be displayed on the item page of individual items in the group. This option only applies to the Members tab of the group page. Organization members will be able to see the group as a filtering option when inviting members to a group or when managing members from the organization page Members tab.
  11. Enable any of the following group designations:
    • Shared update—Allow items that are shared to the group to be editable by all group members. Enabling shared update restricts group membership to your organization and organizations you are in a partnered collaboration with.
      Only the owner of the item or an organization administrator can perform the following actions on the item (not all actions apply to all item types): delete, share, move, change owner, change deletion management settings, publish, register an app, overwrite data in hosted feature layers, and manage tiles in hosted tile layers. However, members of this shared update group have other types of administrator privileges depending on the item type and the app used to access the item.
      This setting is only available if you have the privilege to create groups with update capabilities. Updates to an item include changes to the item details and updates to the content. This setting is only available when creating new groups and when membership in the group is only open to those who are invited or request and are approved to join.
    • Administrative—Only group managers and owners can remove members. This option is only available if you are a default administrator or a user with a custom administrative role.
      This setting is only available when creating new groups. It is not available for SAML-based groups or groups that allow users to join the group without being invited or approved. Only users in your organization can be members of a group with this setting enabled.
    • Open data—Allow the group to be labeled as an Open Data group. This option is only available if your organization is configured for Open Data and you have the required privileges.
  12. Click Save.
    The new group is created with the basic information and properties you specified. It is recommended that you add a brief summary about the group (if you have not already done so), as well as an in-depth description.
    The group is ready to be used. As the group owner, you can share items with the group using Add items to group on the group page. You can edit group properties on the Overview tab and group settings on the Settings tab. Click the Members tab or use Invite members on the Overview tab to search for and invite members to the group.
Edit group properties and settings
After creating a group, you, others you designate, and organization administrators can edit its properties and settings. For example, you can modify the group title or description, as well as change settings such as who can contribute content. For more information about working with groups you own, including managing group content and members, see Own groups.
To edit group properties and settings, complete the following steps:
  1. Verify that you are signed in to the organization.
    You must sign in as the group owner, a group manager, or an organization administrator with the set of privileges to manage all groups owned by organization members.
  2. Click Groups at the top of the site, and use the tabs, filters, sort options, and search as needed to find the group you want to edit.
  3. Click the name of the group to open its group page, and do any of the following:
    • On the Overview tab, click Edit next to the property you want to edit (for example, the description or tags), make your changes, and click Save to save your changes. You can edit the group name, summary, description, thumbnail, and tags.
    • On the Settings tab, modify the group settings (for example, how group content is sorted, who can view the group, who can join the group, or who can contribute content). You can also specify the type of items (for example, maps or layers) you want to display by default on the group's Content and Overview tabs.
    Your ability to edit some settings depends on your privileges and group role. With existing groups, you cannot change the Shared update designation and the Administrative designation that restricts members from leaving the group. These settings are only available for new groups. To change any of these settings, you must delete the group and create a new one with the option you want.
Shared update groups
Organization administrators can create groups that allow members to update items that are shared with the group. These shared update groups are useful in collaborative situations in which multiple people need to update the same item—for example, shift workers in operations centers who need to update the maps underlying their apps and dashboards.
When members share an item with a shared update group, they remain the owner of the item. Other group members can update the item. Updates to an item include changes to the item details and updates to the content. For example, they can add layers to a map and save the map with the updated content.
To be added to a shared update group, the organization member must be assigned a role that has the privilege to create, update, and delete content.
To make your group a shared update group, enable the Shared update group designation when creating the group.
Tip:
A common sharing scenario is allowing a team of editors to edit a publicly visible hosted feature layer without enabling editing on the layer for everyone. Because ArcGIS Online supports feature layer views, the recommended way to manage hosted feature layer permissions in scenarios such as this is to create a feature layer view from the hosted feature layer. In this way, you can share a read-only view with everyone, and share the editable hosted feature layer with a group of editors.
Caution:
At this time, shared update groups are intended for updating item details and the contents of maps, apps, and scenes. Some updates are reserved for the item owner or administrator (such as moving, sharing, or deleting an item, changing ownership, and updating the item by overwriting it). However, members of shared update groups also have elevated privileges, such as the ability to edit the contents of hosted feature layers, append and update a hosted feature layer using the content of a file, alter editor tracking settings, enable or disable attachments, and alter the layer's schema. Therefore, proceed with caution when adding members to this type of group.
Currently, most ArcGIS apps do not support updating items shared with a shared update group. To determine whether this capability is supported in a specific ArcGIS app, refer to its product documentation. Additionally, you cannot create an offline area for feature layers that are shared to a shared update group.
