Set up SAML logins
Configuring organization-specific logins, such as Security Assertion Markup Language (SAML) logins (previously known as enterprise logins), allows members of your organization to sign in to ArcGIS Online using the same logins they use to access your organization's internal systems. The advantage of setting up organization-specific logins using this approach is that members do not need to create additional logins in the ArcGIS Online system; instead, they can use the login that is already set up with the organization. When members sign in to ArcGIS Online, they provide their organization-specific username and password directly into your organization's login manager, also known as your organization's identity provider (IdP). Upon verification of the member's credentials, the IdP informs ArcGIS Online of the verified identity for the member who is signing in.
ArcGIS Online supports SAML 2.0 for configuring SAML logins. SAML is an open standard for securely exchanging authentication and authorization data between an IdP (your organization) and a service provider (SP). In this case, ArcGIS Online is compliant with the SAML 2.0 protocol and integrates with IdPs that support SAML 2.0, such as Active Directory Federation Services (AD FS), Google Workspace, and Okta.
You can configure the ArcGIS Online sign-in page to show only the SAML login or to show the SAML login along with any of the following options: ArcGIS login, OpenID Connect login (if configured), and social logins (if configured).
To ensure that your SAML logins are configured securely, review the best practices for SAML security.
Tip:
If your organization has existing ArcGIS accounts for members, you can change member login types to SAML logins.
In most situations, organizations set up their SAML logins using a single IdP. This IdP authenticates users accessing secured resources that are hosted across multiple service providers. The IdP and all service providers are managed by the same organization.
Another way to authenticate users with SAML logins is by configuring your organization to use a SAML-based federation of IdPs. In a SAML-based federation between multiple organizations, each member organization continues to use their own IdP but configures one or more of their SPs to work exclusively within the federation. To access a secured resource shared within the federation, a user authenticates their identity with their home organization's IdP. Once authenticated, this validated identity is presented to the SP hosting the secured resource. The SP then grants access to the resource after verifying the user's access privileges.
SAML sign in experience
ArcGIS Online supports SP-initiated SAML logins and IdP-initiated SAML logins. The sign-in experience is different for each.
SP-initiated logins
With SP-initiated logins, members access their ArcGIS Online website directly and see options to sign in using their SAML SP login or their ArcGIS login. If the member selects the SP option, they are redirected to a web page (known as the login manager) where they are prompted to provide their SAML username and password. Upon verification of the member’s credentials, the IdP informs ArcGIS Online of the verified identity of the member who is signing in, and the member is redirected back to their ArcGIS Online website.
If the member selects the ArcGIS option, the sign-in page for ArcGIS Online appears. The member can then provide their ArcGIS username and password to access the website.
IdP-initiated logins
With IdP-initiated logins, members directly access their organization's login manager and sign in with their account. When the member submits their account information, the IdP sends the SAML response directly to ArcGIS Online. The member is then signed in and redirected to their ArcGIS Online website where they can immediately access resources without having to sign in to the organization again.
Your organization-specific username will include the organization URL key as the suffix. For example, if the SAML username is JohnDoe@example.com, the organization-specific username would be JohnDoe@example.com_OrganizationURLKey.
The option to sign in using an ArcGIS account directly from the login manager is not available with IdP logins. To sign in to ArcGIS Online using ArcGIS accounts, members must access their ArcGIS Online website directly.
Configure SAML logins
The process of configuring IdPs with ArcGIS Online is described below. Before proceeding, it is recommended that you contact the administrator of the IdP or federation of IdPs to obtain the required parameters for configuration. For example, if your organization uses Microsoft Entra ID, the administrator responsible for this is the person to contact to configure or enable SAML on the IdP side and obtain the necessary parameters for configuration on the ArcGIS Online side. You can also access and contribute to detailed third-party IdP configuration documentation in the ArcGIS/idp GitHub repository.
To configure SAML logins, complete the following steps:
  1. Verify that you are signed in to your organization.
    Your account must be assigned the default administrator role or a custom role with the set of privileges to configure the organization's security settings.
    It is recommended that organizations have at least two organization administrators. There is no limit to the number of members who can be assigned the default administrator role. However, for security reasons, only assign this role to those who require the additional privileges associated with it.
  2. At the top of the site, click Organization, and click the Settings tab.
  3. If you plan to allow members to join automatically, configure default settings for new members first by doing the following:
    1. Click New member defaults on the side of the page.
    2. Select the default user type and role for new members.
    3. Select the add-on licenses to automatically assign members when they join the organization.
    4. Select the groups to which members will be added when they join the organization.
    5. If credit budgeting is enabled for the organization, set the credit allocation for each new member to a specified number of credits or no limit.
    6. Optionally, enable Esri access for new members.
      A member whose account has Esri access enabled can use My Esri, take training courses, participate in Esri Community, add comments to ArcGIS Blog articles, and manage email communications from Esri. The member cannot enable or disable their own access to these Esri resources.
    If necessary, you can change these settings for specific members after they have joined the organization.
  4. Click Security on the side of the page.
  5. In the Logins section, click New SAML login.
  6. In the window that appears, choose one of the following:
    • One identity provider—Allow users to sign in using their existing SAML credentials managed by your organization. This is the most common configuration.
    • A federation of identity providers—Allow users belonging to an existing interorganizational federation, such as the SWITCHaai federation, to sign in with credentials supported by the federation.
  7. Click Next.
  8. If you selected One identity provider in step 6, do the following:
    1. Provide the name of your organization.
    2. Choose how members with SAML logins will join your ArcGIS Online organization: automatically or through an invitation.
      The automatic option allows members to join the organization by signing in with their SAML login. With the invitation option, you generate email invitations through ArcGIS Online that include instructions on how to join the organization. If you choose the automatic option, you can still invite members to join the organization or add them directly using their SAML ID.
    3. Provide the source that ArcGIS Online will access to obtain metadata information about the IdP.
      The following are the possible sources for this information:
      • A URL—Provide a URL that returns metadata information about the IdP.
      • A File—Upload a file that contains metadata information about the IdP.
      • Parameters specified here—Directly provide the metadata information about the IdP by supplying the following parameters:
        • Login URL (Redirect)—Provide the IdP URL (that supports HTTP redirect binding) that ArcGIS Online will use to allow a member to sign in.
        • Login URL (POST)—Provide the IdP URL (that supports HTTP POST binding) that ArcGIS Online will use to allow a member to sign in.
        • Certificate—Provide the certificate, encoded in the BASE 64 format, for the IdP. This is the certificate that allows ArcGIS Online to verify the digital signature in the SAML responses sent to it from the IdP.
      Contact the administrator of the IdP if you need help determining which source of metadata information you need to provide.
  9. If you selected A federation of identity providers in step 6, do the following:
    1. Provide the name of the federation.
    3. Provide the URL to the centralized IdP discovery service hosted by the federation, for example, https://wayf.samplefederation.com/WAYF.
    4. Provide the URL to the federation metadata, which is an aggregation of the metadata of all IdPs and SPs participating in the federation.
    5. Copy and paste the certificate, encoded in Base64 format, that allows the organization to verify the validity of the federation metadata.
  10. Configure the following settings as applicable:
    • Allow Encrypted Assertion—Enable this option to indicate to the SAML IdP that ArcGIS Online supports encrypted SAML assertion responses. When this option is enabled, the IdP encrypts the assertion section of the SAML response. All SAML traffic to and from ArcGIS Online is already encrypted by the use of HTTPS, but this option adds another layer of encryption.
      Some IdPs do not encrypt assertions by default. It is recommended that you ask the IdP administrator to ensure that encrypted assertions are enabled.
    • Enable signed request—Enable this option to have ArcGIS Online sign the SAML authentication request sent to the IdP. Signing the initial login request sent by ArcGIS Online allows the IdP to verify that all login requests originate from a trusted SP.
    • Primary SAML certificate—This is the certificate that will be used to sign SAML authentication requests and decrypt assertions received from the SAML certificate. This setting is only displayed if you turn on Allow Encrypted Assertion or Enable signed request.
      You can choose ArcGIS Default for the Primary SAML certificate setting, or you can generate a new certificate and key pair. You cannot edit the expiration date for the ArcGIS default SAML certificate, and it may be shorter than desired.
    • Secondary SAML certificate—The secondary SAML certificate is used to ensure that SAML logins continue working when you need to replace your primary SAML certificate. This setting is only displayed if you turn on Allow Encrypted Assertion or Enable signed request.
    • Generate certificate and key pair—You can create a new certificate and key pair with a chosen name, description, and expiration date.
  11. Click Advanced options to configure the following advanced settings as applicable:
    • Propagate logout to Identity Provider—Enable this option to have ArcGIS Online use a logout URL to sign out the user from the IdP. Provide the URL to use in the Logout URL setting. If the IdP requires the logout URL to be signed, the Enable signed request option also must be enabled. When this option is unavailable, clicking Sign Out in ArcGIS Online will sign out the user from ArcGIS Online but not from the IdP. If the user's web browser cache is not cleared, attempting to immediately sign back in to ArcGIS Online using the SAML login option will result in an immediate login without needing to provide user credentials to the SAML IdP. This is a security vulnerability that can be exploited when using a computer that is accessible to unauthorized users or to the general public.
    • Update profiles on sign in—Enable this option to automatically synchronize account information (full name and email address) stored in ArcGIS Online user profiles with the latest account information received from the IdP. Enabling this option allows your organization to verify, when a user signs in with a SAML login, whether the IdP information has changed since the account was created and if so, to update the user's ArcGIS Online account profile accordingly.
    • Entity ID—Update this value to use a new entity ID to uniquely identify your ArcGIS Online organization to the SAML IdP or SAML federation.
  12. Optionally, if you chose One identity provider in step 6, enable the following options:
    • Enable SAML based group membership—Enable this option to allow organization members to link specified SAML-based groups to ArcGIS Online groups during the group creation process. When you enable this option, organization members with the privilege to link to SAML groups can create an ArcGIS Online group whose membership is controlled by a SAML group managed by an external SAML IdP. Once a group is linked to an external SAML-based group, each user's membership in the group is defined in the SAML assertion response received from the IdP every time the user signs in.
      To ensure that the ArcGIS Online group is linked to the external SAML group, the creator of the group must provide the exact value of the external SAML group as it is returned in the attribute value of the SAML assertion. View the SAML assertion response from your SAML IdP to determine the value used to reference the group. The supported names, which are not case sensitive, for the attribute defining a user's group membership are as follows:
      • Group
      • Groups
      • Role
      • Roles
      • MemberOf
      • member-of
      • https://wso2.com/claims/role
      • http://schemas.xmlsoap.org/claims/Group
      • http://schemas.microsoft.com/ws/2008/06/identity/claims/groups
      • urn:oid:1.3.6.1.4.1.5923.1.5.1.1
      • urn:oid:2.16.840.1.113719.1.1.4.1.25
      For example, a user signing in is a member of the SAML groups FullTimeEmployees and GIS Faculty. In the SAML assertion received from the IdP, as shown below, the name of the attribute that contains group information is MemberOf. In this example, to create a group linked to the SAML group GIS Faculty, the group creator must type GIS Faculty as the group name.
      <saml2p:Response>
        <saml2:Assertion>
            <saml2:AttributeStatement>
              <saml2:Attribute Name="MemberOf">
                <saml2:AttributeValue>FullTimeEmployees</saml2:AttributeValue>
                <saml2:AttributeValue>GIS Faculty</saml2:AttributeValue>
              </saml2:Attribute>
          </saml2:AttributeStatement>
        </saml2:Assertion>
      </saml2p:Response>
      The following is another example using ID values to identify the groups:
      <saml2p:Response>
        <saml2:Assertion>
              <saml2:Attribute Name="urn:oid:2.16.840.1.113719.1.1.4.1.25" FriendlyName="groups">
                <saml2:AttributeValue>GIDff63a68d51325b53153eeedd78cc498b</saml2:AttributeValue>
                <saml2:AttributeValue>GIDba5debd8d2f9bb7baf015af7b2c25440</saml2:AttributeValue>
              </saml2:Attribute>
        </saml2:Assertion>
      </saml2p:Response>
    • Logout URL—If you chose One identity provider in step 6, provide the IdP URL to use to sign out the currently signed-in user. If this property is specified in the IdP's metadata file, it is automatically set.
  13. When finished, click Save.
  14. To complete the configuration process, establish trust with the federation's discovery service (if applicable) and the IdP by registering the ArcGIS Online SP metadata with them.
    You can obtain this metadata in the following ways:
    • Click Download service provider metadata to download the metadata file for your organization.
    • Open the URL of the metadata file and save it as an .xml file on your computer. You can view and copy the URL in the Edit SAML login window under Link to download the service provider metadata.
    Links to instructions for registering the SP metadata with certified providers are available in the SAML IdPs section above. If you selected A federation of identity providers, once you've downloaded the SP metadata, contact the administrators of the SAML federation for instructions on how to integrate your SP metadata into the federation's aggregated metadata file. You will also need instructions from them to register your IdP with the federation.
Manage SAML certificates and keys
Organization-specific logins, such as SAML logins, use certificate and key pairs to support signed requests and encrypted assertions. The certificate used to sign SAML requests and encrypt the assertion response is managed in ArcGIS Online. A default certificate and key pair are provided.
Generate a certificate and key pair
To generate a certificate and key pair, complete the following steps:
  1. Verify that you are signed in to the organization.
    Your account must be assigned the default administrator role or a custom role with privileges to configure the organization's security settings.
  2. Click Security on the Settings tab of your organization page and navigate to the SAML certificates and keys section.
  3. Click Generate certificate and key pair.
    The Generate certificate and key pair window appears.
  4. Provide a certificate name, description, and expiration date.
  5. Click Generate.
A certificate unique to your organization is created and is visible in the table under SAML certificates and keys. This certificate can be configured for use as the ArcGIS Online service provider signing certificate, encryption certificate, or both.
You can view the certificate details, download the X.509 certificate, or delete the certificate by clicking the more options button in the Actions column of the SAML certificates and keys table.
Rotate the ArcGIS Online SAML certificate
SAML certificates have a fixed validity period and expire on a specific date. When the certificate expires, users will no longer be able to sign in to ArcGIS Online.
Administrators are notified when their SAML certificate is about to expire.
Administrators are notified when the replacement to the ArcGIS_Default SAML certificate is available, with instructions on how to rotate to the new certificate.
If your organization is using a custom certificate for SAML, it is recommended that you renew your SAML certificate 30 to 45 days before expiration to avoid disruptions to SAML logins. This allows you to transition to the new SAML certificate without any interruption to SAML logins.
To transition to the new SAML certificate, complete the following steps:
  1. Generate a certificate and key pair.
  2. Configure SAML login certificates for the transition period. Update the Secondary SAML certificate value to the new replacement certificate.
  3. Update your SAML IdP using one of the following methods:
    Uploading your metadata or X.509 certificate and configuring your SAML IdP is done outside the ArcGIS Online system.
    • Use the ArcGIS Online metadata—Download the new ArcGIS Online metadata, which contains both the existing (primary) and new (secondary) SAML certificates. Upload the metadata file to your IdP to update or replace the existing ArcGIS Online SAML registration.
    • Use the replacement certificate—If your IdP requires you to update the certificate manually, download the new (secondary) SAML certificate. Click the more options button in the Actions column of the SAML certificates and keys table, and click Download X.509 certificate. Configure your IdP using the downloaded certificate.
  4. Configure the SAML IdP to use both the existing (primary) and new (secondary) certificates for signature verification and only the new (secondary) certificate for encryption.
  5. Test to ensure SAML logins continue to work in ArcGIS Online with the new primary and secondary certificates in place.
  6. Before the old SAML certificate expires, configure the SAML login certificates to use the new certificate as the primary SAML certificate and set the Secondary SAML certificate to None.
  7. Test to ensure SAML logins continue to work in ArcGIS Online with the primary certificate in place and secondary certificate removed.
Modify or remove the SAML IdP
Once you've set up a SAML IdP, you can update the settings for it by clicking Configure login next to the currently registered SAML IdP. Update the settings in the Edit SAML login window.
To remove the currently registered IdP, click Configure login next to the IdP, and click Delete login in the Edit SAML login window. Once you've removed an IdP, you can set up a new IdP or federation of IdPs.
Update the SAML IdP's signing certificate
When the SAML IdP authenticates a user, it sends an assertion response back to ArcGIS Online. It is recommended that you configure the SAML IdP to sign the assertion response using its x.509 certificate. When the IdP administrator renews the SAML IdP signing certificate, you must immediately update your ArcGIS Online organization's SAML configuration with the new certificate for SAML logins to continue working.
It is recommended that you schedule an appropriate maintenance or downtime window for both your SAML IdP and your ArcGIS Online organization before renewing the IdP's signing certificate.
To replace the IdP certificate for your organization's SAML login configuration, complete the following steps:
  1. Obtain the latest SAML IdP metadata from your SAML IdP administrator.
  2. Verify that you are signed in to the organization.
  3. At the top of the site, click Organization, and click the Settings tab.
  5. In the Logins section, click Configure login next to the SAML login toggle button.
  6. In the Edit SAML login window, click File under Metadata source for Enterprise Identity Provider.
  7. Click Choose File, and browse to and select the new IdP metadata file received from the SAML IdP administrator.
  8. Click Save to update the ArcGIS Online SAML login configuration to use the new certificate.
Best practices for SAML security
To securely administer SAML logins, keep the following best practices in mind:
  • Have both a single sign-on administrator account and a built-in administrator account so that if you experience issues signing in with single sign-on, you can still access your account through www.arcgis.com using the built-in credentials.
  • Ensure that the ArcGIS Online administrative contacts are up to date in your organization to continue receiving communications from Esri Customer Service. It is recommended that you add multiple contacts.
  • Maintain a tightly controlled, multifactor authentication–enforced, default administrator account to recover access to your ArcGIS Online organization if SAML fails due to certificate expiration or configuration error.
  • The certificate used to sign SAML requests and encrypt the assertion response is managed in ArcGIS Online. You can use the default or generate a certificate.
Digitally sign the SAML login and logout requests and sign the SAML assertion response
Signatures are used to ensure the integrity of SAML messages and are a safeguard against man-in-the-middle (MITM) attacks. Digitally signing the SAML request also ensures that the request is sent by a trusted SP, allowing the IdP to better handle denial-of-service (DOS) attacks. Turn on the Enable signed request option in advanced settings when configuring SAML logins.
  • Enabling signed requests requires the IdP to be updated whenever the signing certificate used by the SP is renewed or replaced.
  • Enabling signed requests requires the SP (ArcGIS Online) to be updated whenever the signing certificate used by the IdP is renewed or replaced.
Configure the SAML IdP to sign the SAML response to prevent in-transit altering of the SAML assertion response.
Use the HTTPS endpoint of the IdP
Any communication between the SP, the IdP, and the user's browser that is sent over either an internal network or the internet in an unencrypted format can be intercepted by a malicious actor. If your SAML IdP supports HTTPS, it is recommended that you use the HTTPS endpoint to ensure the confidentiality of data transmitted during SAML logins.
Encrypt the SAML assertion response
Using HTTPS for SAML communication secures the SAML messages sent between the IdP and SP. However, signed-in users can still decode and view the SAML messages through the web browser. Enabling the encryption of the assertion response prevents users from viewing confidential or sensitive information communicated between the IdP and SP.
Enabling encrypted assertions requires the IdP to be updated whenever the encryption certificate used by the SP (ArcGIS Online) is renewed or replaced.
