Manage licenses
You can use ArcGIS Online to specify which members have access to licensed apps that aren't already included in their assigned user type. For example, you can assign add-on licenses for licensed apps such as ArcGIS Pro and other apps available in ArcGIS Online that require a license. You can also assign add-on licenses for apps that were purchased separately, for capabilities and apps included in organization extensions, or for user type extensions.
Organization extensions in ArcGIS Online have unique configurations. Refer to the extension documentation for details.
You can view license and user type details and configure add-on licenses for a single product at a time and multiple products at once. Organizations with ArcGIS Pro licenses also have the option of disabling offline usage of ArcGIS Pro for all users in the organization.
View license and user type details
The licensing page includes details about your organization's add-on licenses and user types, including compatibility tips that help you make decisions when managing licenses.
Tip:
For a preview of the number of licenses and user types available and assigned to members, refer to the Add-on licenses and Members cards on your organization's Overview tab.
To view license and user type details, complete the following steps:
Verify that you are signed in to your organization.
Your account must be a member of the default administrator role or a custom role assigned the administrative privilege to manage licenses.
At the top of the site, click Organization, and click the Licenses tab.
Click the User types tab to see the assigned and available user types in your organization, as well as the included licenses, compatible add-on licenses, and compatible roles for each user type.
Click the Add-on licenses tab to see the add-on licenses you have available and assigned in your organization, as well as compatible user types for each.
In the ArcGIS Pro section, click View license activity to see which members are currently using ArcGIS Pro, the last time they used the app, and whether members have checked out their license (if offline usage is permitted in the organization).
You can only view license activity for members currently assigned ArcGIS Pro licenses.
You can search the members by name to filter the list. A green dot next to the last-used date indicates that the member has used ArcGIS Pro in the last 30 minutes. A red dot and a Disconnected label indicate that the member has checked out their ArcGIS Pro license for offline use.
License:
The ArcGIS Image for ArcGIS Online user type extension is replaced with a new licensing model.
The Image Hosting capability is included in the Creator, Professional, and Professional Plus user types. Additionally, member roles must include the Publish hosted tiled imagery layers or Publish hosted dynamic imagery layers privilege, or both.
The Image Analysis capability is included in the Professional and Professional Plus user types. Additionally, member roles must include the Imagery Analysis privilege.
For more information about licensing, roles, and privileges, review User types, Member roles, and Privileges granted to roles.
Configure add-on licenses for one product
To configure add-on licenses for a particular product, complete the steps below. You can use this workflow to assign or unassign the same product for one or more members at a time.
At the top of the site, click Organization, click the Licenses tab, and click the Add-on licenses subtab if needed.
Locate the add-on license you want to change, searching the licenses by name if necessary, and click Manage.
In the window that appears, find the member or members whose license you want to manage.
To search the list of organization members, type the member's name in the search box. Use the filters to narrow the list of members. For example, you can filter the list to show only members with a particular user type and role, those who have signed in to the organization in the last day or a specified date range, or members in a specific group who are assigned an ArcGIS Pro license.
Turn on the license assignment next to each member, and choose whether you want to notify the member by email. To assign the specified add-on license to all applicable members who appear on the page, click Manage all on page.
If you aren't prompted to notify members by email, you may have saved the email setting when you assigned a license earlier. Sign out, close the browser, and sign back in to see the email options again.
Caution:
To prevent the email notifications from being returned as undeliverable, verify the member's email address first.
If you can't assign the license to a particular member because it's not compatible with their user type, you can update user types on the Members tab.
If you're unassigning a license, turn off the license assignment next to each member. To unassign the specified add-on license from all applicable members, turn on the filter to show only members with that license assigned, and click Manage all on page.
You cannot unassign ArcGIS Pro or ArcGIS Drone2Map licenses from users who checked out a license.
Close the window to return to the licenses page.
End an active ArcGIS Pro session
To end a member's active ArcGIS Pro session to release an add-on license for another member to use, complete the following steps:
In the ArcGIS Pro section, click View license activity.
In the window that appears, search the members list, and click the row for the member to view activity details.
Click End session.
If the member has set an alias name for the workstation in ArcGIS Pro, you can use that to help confirm the session to close. In ArcGIS Pro, the member starts receiving notifications about the session ending as the app begins to shut down. The member can have up to three simultaneous ArcGIS Pro sessions.
Configure add-on licenses for multiple products
To configure add-on licenses for multiple products at once, complete the steps below. You can use this workflow to change the add-on licenses for one member or a selected set of members.
At the top of the site, click Organization, and click the Members tab.
Search for members by name or username and apply filters to narrow the members list. Sort the list as desired, such as by name or last login date.
Click the More options button
in the member's row, and click Manage add-on licenses.Tip:
To change multiple members at once, check the box next to the name of each member for whom you want to assign or unassign the same add-on licenses. You can select up to 100 members at a time. The selected set is maintained while you search and filter all the members in your organization, even across multiple pages. If necessary, click the members selected drop-down menu to review and revise your selection once you've modified your initial search or filter. Above the list of members, click Manage add-on licenses.
In the window that appears, select or deselect the add-on licenses that you want to change.
If you selected multiple members, you can only assign add-on licenses that are compatible with all the selected members' user types. If necessary, click the members selected drop-down menu to remove any members with an incompatible user type. To review what's compatible with your organization's user types, go to the Licenses tab, and click User types.
You cannot unassign ArcGIS Pro or ArcGIS Drone2Map licenses for members who checked out a license.
To notify the member by email that you have assigned a license to them, enable Email members about newly assigned licenses.
Caution:
Click Save.
Manage ArcGIS Pro settings
Organizations requiring more control over ArcGIS Pro licenses, including offline usage, can manage ArcGIS Pro settings from the Licenses tab.
To manage ArcGIS Pro settings, complete the following steps:
Click the Add-on licenses tab.
In the ArcGIS Pro section, click Manage ArcGIS Pro settings.
Do one of the following:
Turn on the Members can take ArcGIS Pro offline for the maximum allowed duration toggle button to allow members to take their ArcGIS Pro license offline until their license is renewed.
Turn on the Members can take ArcGIS Pro offline for a set period toggle button to specify the maximum duration that ArcGIS Pro licenses can be taken offline. This option is available if offline usage of ArcGIS Pro is permitted in your organization and you are using ArcGIS Pro 3.4 or later.
You can set a maximum duration of between 1 and 365 days. However, if you enter a number that is higher than either the number of days remaining in the organization's ArcGIS Online subscription or the number of days remaining before the member's ArcGIS Pro license is renewed, the actual maximum number of days that an organization member will be allowed to take an ArcGIS Pro license offline will be whichever number is lowest.
For example, if the organization's ArcGIS Online subscription is set to expire in 5 days, there are 10 days remaining for a member's ArcGIS Pro license, and you specify 15 days for the Members can take ArcGIS Pro offline for a set period setting, the member will only be allowed to take ArcGIS Pro offline for a maximum of 5 days.
Turn on the Members cannot take ArcGIS Pro offline toggle button to prevent organization members from using ArcGIS Pro offline.
Caution:
ArcGIS Pro users who are already working offline when this setting is enabled will be allowed to check back in, but any future attempts to take an ArcGIS Pro license offline will generate an error.
Optionally, under Workstation alias setting, turn on the Use member's workstation name to identify their current ArcGIS Pro session toggle button to use members' workstation names to identify their active ArcGIS Pro sessions. When this setting is enabled, the license activity page displays the hostname of the machine where ArcGIS Pro is installed for members with an active ArcGIS Pro session. Members cannot change their workstation alias when this setting is enabled.
Changes to this setting are not immediately reflected on the license activity page. After the setting is changed, members must sign out of ArcGIS Pro, close and reopen the app, then sign in again for the updated setting to appear on the page.
If a member has checked out their ArcGIS Pro license for offline use, changes to this setting are not reflected on the license activity page until the license is returned. After the member returns their license, they must sign out of ArcGIS Pro, close and reopen the app, then sign in again for the updated setting to appear on the page.
Optionally, under License expiration notice, modify the notification period for alerting ArcGIS Pro users when their ArcGIS Pro license is about to expire.
You can have ArcGIS Online display notifications starting 1 to 15 days (including weekends) before the expiration date. Once the license has been renewed, notifications are no longer displayed. A longer notification period is recommended for organizations that rely on ArcGIS Pro users alerting administrators that their licenses will expire soon. For subscriptions that are automatically renewed—typically between 4 and 7 days before the expiration date—starting notifications between 4 and 7 days before expiration can help reduce the number of ArcGIS Pro renewal requests sent to administrators. If your organization does not plan to renew licenses, configuring an adequate notification period helps ensure that organization members have sufficient time to complete their work before their ArcGIS Pro licenses expire.
Click Save.
Configure user type extensions
User type extensions are licenses that extend the capabilities of ArcGIS Online for specific users in an organization. They can be included as part of a user type or as an add-on license.
Assign a user type extension license on the Licenses tab
To assign a user type extension license to a member of the organization on the Licenses tab, complete the following steps:
In the User type extensions section, find the license you want to assign, and click Manage.
You can also click Compatible user types to see the list of user types that are compatible with the extension based on the privileges granted to those user types.
Turn on the license assignment next to each member, and choose whether to notify the member by email. To assign the specified user type extension license to all applicable members who appear on the page, click Manage all on page.
If you can't assign the license to a particular member because it's not compatible with their user type or role, you can update user types and roles on the Members tab, or you can assign them a role with the privileges required for the capabilities provided by the extension.
To unassign a license, turn off the license assignment next to each member. To unassign the specified user extension license from all applicable members, turn on the filter to show only members with that license assigned, and click Manage all on page.
You can also manage user type extensions from the Members tab.
Assign a user type extension license on the Members tab
To assign a user type extension license to one or more members of the organization on the Members tab, complete the following steps:
To change multiple members at once, check the check box next to the name of each member for whom you want to assign or unassign the same add-on licenses. You can select up to 100 members at a time. The selected set is maintained while you search and filter all the members in your organization, even across multiple pages. If necessary, click the members selected drop-down menu to review and revise your selection once you've modified your initial search or filter. Above the list of members, click Manage add-on licenses.
In the window that appears, select or deselect the user type extension licenses that you want to assign.
If you selected multiple members, you can only assign user type extension licenses that are compatible with all the selected members' user types. If necessary, click the members selected drop-down menu to remove any members with an incompatible user type. To review what's compatible with your organization's user types, go to the Licenses tab, and click User types.
Caution:
Click Save.
Reset offline ArcGIS Pro licenses
If a member of your organization has an offline ArcGIS Pro license that cannot be recovered, you can reset the license.
To reset one or more offline ArcGIS Pro licenses, complete the following steps:
In the ArcGIS Pro section, under Offline ArcGIS Pro licenses, click View all.
A table that lists the members in your organization with offline licenses appears.
To reset one offline license, do the following:
In the table, locate the offline license you want to reset, and click the More options button
in the Actions column.Click Reset offline license.
The Reset offline ArcGIS Pro licenses window appears.
To reset multiple offline licenses, do the following:
In the table, check the box next to the name of each member for whom you want to reset an offline license.
At the top of the table, click Reset offline license.
In the Reset offline ArcGIS Pro licenses window, read the conditions for offline license resets.
Check the box next to each condition, and verify the number of offline resets remaining for your organization.
Important:
Once a license has been reset, this action cannot be undone.
Click Reset licenses.
After the license is reset, your organization member can login to ArcGIS Pro using a different device.
Considerations for managing licenses
When managing licenses in ArcGIS Online, consider the following:
If an app is included with a member's assigned user type, you don't need to assign the member an add-on license for that app. For example, a member assigned a Creator, Professional, or Professional Plus user type already has a license for ArcGIS Pro, so you don't need to assign ArcGIS Pro to that member as an add-on license. If you're not sure what apps a member can already access, view their profile to see the licenses included with their user type and any assigned add-on licenses. (Go to the Organization page, and click the Members tab. Find the member whose profile you want to view, click the More options button
, and click View profile.)User types may be reassigned no more than once in any 30-day period, except in the event of the assigned individual’s permanent role change, extended leave, or departure from the member's organization.
Administrators of organizations that have purchased products that were sold separately but are now included in a user type may see a notification in ArcGIS Online that some members have licenses assigned twice. You can unassign duplicate licenses directly from the notification, or go to your organization's Licenses tab, and manage duplicate licenses in the Add-on licenses section. It is recommended that administrators review new member default settings.
Your organization must be provisioned for ArcGIS Pro or specific additional products before you see those products on the Licenses tab and can manage add-on licenses for those products.
For ArcGIS Marketplace apps, you only manage licenses that have been licensed by members. Items that have been licensed by the organization must be shared with groups in your organization.
ArcGIS Marketplace will be retired in the first quarter of 2027. The ArcGIS Marketplace website was shut down in March 2026. See the ArcGIS Marketplace Retirement Esri Technical Support article for details.
The first time a licensed member signs in to ArcGIS Navigator, they must be connected to their licensing portal. After that, they can download mobile map packages, go offline, and use Navigator offline. If they choose to sign out of Navigator, they must be able to connect to the licensing portal to sign back in.
Each product has a corresponding card on the licenses page that shows the number of add-on licenses available to assign and compatible user types.
It is possible for your organization to exceed the number of licenses available, resulting in a negative number available. This can happen if you assign licenses to your members but are later entitled to fewer licenses, such as if you make changes to your maintenance agreement or you are using trial licenses. Upon the expiration of any license in your organization, you must unassign the expired license so your organization's members are only assigned valid licenses. Members with an expired user type will not be able to sign in. Members with an expired add-on license will not be able to use the license.
Your organization has a limited number of resets available for offline ArcGIS Pro licenses. Before you reset a license, confirm that you have correctly identified the device with the offline license, that your organization member no longer has access to the device, and that the license cannot be recovered from the device. Once you reset a license, it cannot be undone.
