Create and open models
You can open a ModelBuilder diagram by creating a model or opening an existing model. If multiple models are opened, each diagram will appear on a separate tab.
Create a model
When you create a model, it opens for editing in ModelBuilder. A new model starts as a blank model diagram that you can add data and tools to and connect them to form a workflow.
To create a model, complete the following steps:
  1. Complete the steps to open the ModelBuilder pane if necessary.
  2. In the ModelBuilder pane, click Connect.
    Connecting to an analysis session consumes credits.
    ModelBuilder connects to an analysis session, and Create model is enabled.
  3. Click Create model .
    The Create analysis model window appears.
  4. Do the following for the new item:
    • Provide a title.
    • Choose a folder in My content where you want to save the item.
    • Provide tags and a summary that describe the item.
  5. Click Save.
The empty ModelBuilder diagram opens and an analysis model item is created. The model name is listed under Models in this map. A blue check mark next to the model name indicates the model is active.
Open a model
You can open existing models that you own or that have been shared with you. Users with administrator privileges can open models owned by other members of the organization, regardless of their shared status.
To open a model, click Open in Map Viewer on the analysis model's item page. The analysis model opens in a new web map.
If you already have a web map open, you can open a model by completing the following steps:
  2. Click Browse analysis models .
    The Browse analysis models window appears showing models from My content.
  3. Click My content, and choose a different option from the menu (for example, My groups or My organization) if necessary.
  4. Use the Search bar or Sort by menu to reduce the number of items or reorder the list of items if necessary.
  5. Click an analysis model item to select it.
  6. Click Confirm.
    The ModelBuilder diagram opens, and the model name appears under Models in this map.
Models open in view-only mode. You can connect to an analysis session and click Make active to enable editing.
Model modes
Models can be opened in the following modes:
  • View only—The model diagram and tool dialog boxes can be viewed, but editing—including adding or removing elements and running the model—is not enabled. When you browse to and open an existing model, it automatically opens in view-only mode.
  • Active—The model can be viewed, edited, run, and saved. The active model is associated with the compute resources made available by the analysis session.
    When you create a model, it automatically opens in active mode. You can click Make active on a view-only model to activate it.
You must be connected to an analysis session to open a model in active mode.
Intermediate data is lost when an active model is switched to view-only mode. Tools with intermediate data outputs must be rerun if the model is made active and run again. An active model becomes view only when you make a different model active or disconnect from the analysis session. If there are unsaved edits, you are prompted to save or discard changes.
Multiple models
You can open multiple model diagrams at the same time. Each model appears on a different tab. Other visualizations that open at the bottom of the map—such as tables, charts, raster function templates, and analysis history—can be opened at the same time as the model diagrams and appear on their own tabs.
Only one model can be in active mode at a time.
Save models in a web map
You can save the models you've created or opened in a web map. The models listed under Models in this map are preserved when the web map is saved and reopened.
The model list is also preserved in shared web maps. When you open a shared web map, the following models from the model list are available:
  • Models that you own
  • Models that are shared with you
Users with administrator privileges have access to all models in their organization, including unshared models.
To ensure that the correct users can access both the web map and models, share all necessary models before sharing the web map.
