Analysis sessions
Analysis sessions provide the compute resources for analysis models, which enable you to do the following:
  • Create models.
  • Interactively build models by adding tools, data, and variables.
  • Validate elements in a model.
  • Run models.
  • Temporarily store intermediate data.
Credits are consumed when connected to an analysis session.
Session types
The following session types are available:
  • Standard—Appropriate for feature and raster analysis with smaller input rasters or environment settings limiting processing size. This is the default session type.
  • Raster optimized (beta)—Uses parallel processing to enable analysis with large raster inputs.
    If you do not have access to raster optimized sessions, it may mean that beta apps are blocked for your ArcGIS organization. Contact your ArcGIS administrator to unblock beta apps.
    A raster optimized session can process input rasters up to 10 billion cells, or approximately 100,000 cells by 100,000 cells. If an input raster exceeds the limit, you will be prompted to reduce the processing size of the raster, either by reducing the processing extent or increasing the cell size in the analysis model's environment settings.
Feature and raster tools are supported in both session types.
Connect to a session
To connect to an analysis session, open the ModelBuilder pane and do one of the following:
  • To connect to a standard session, click Connect.
  • To connect to a raster optimized session, click the down arrow to expand the menu and click Raster optimized.
Connect button under Analysis session
If you are unsure which session type to connect to, choose Standard. You will be prompted to switch to a raster optimized session if necessary when you run the model.
The analysis session status is displayed in the ModelBuilder pane under Analysis session and on the map header (Connected to analysis session). The following information is available by expanding either interface:
  • The session type (available if beta apps are enabled)
  • The time elapsed since the analysis session connected
  • The estimated credit consumption
  • The Disconnect button
A user account can start up to two analysis sessions simultaneously in two browser tabs.
Connecting to an analysis session may take from a few seconds to a few minutes. Credits are not charged during this process.
Status
Analysis sessions have the following status types:
  • Connecting—The analysis session connection for the model is being provisioned and the connection is initiating.
  • Connected—The analysis session connection has started.
  • Disconnecting—The analysis session connection is in the process of disconnecting.
  • Disconnected—The analysis session has stopped.
    Analysis sessions are disconnected by default when a web map is opened. A connected analysis session will be disconnected in the following situations:
    • After clicking Disconnect in the ModelBuilder pane or under Connected to analysis session in the Map Viewer header.
    • After 30 minutes of inactivity. Activity in an analysis session includes actions that change the model diagram, running the model, and opening a tool dialog box.
    • After the browser tab is closed, refreshed, or crashes.
    • After the internet disconnects.
    • After signing out of ArcGIS Online.
If you were previously connected to two analysis sessions before the browser crashes or the internet disconnects, you cannot connect to a new analysis session for 10 minutes.
You cannot disconnect from an analysis session or switch the session type (beta) while a model has unsaved edits. If you click Disconnect while the active model has unsaved edits, you are prompted to save or discard the edits.
When the analysis session shows a disconnected status, the following data from a previous connection is lost:
  • Intermediate data
  • Long-running model jobs and any associated messages (warnings, errors, and results)
Credits
Credits are charged at a rate of 50 credits per hour, calculated per minute with a 10 minute minimum.
Beta:
Credit rates are the same for standard and raster optimized sessions while raster optimized sessions are in beta.
Credits are charged when the analysis session has one of the following statuses:
  • Connected
    A user account can start up to two analysis sessions in two browser tabs. Credits are charged for both connected sessions.
  • Disconnecting
    Credits are charged until the state changes to Disconnected.
Credits are not charged when the analysis session state is Disconnected or Connecting.
In addition to the model session cost, premium tools also consume credits at the same rate as the tools run from the tool pane. Credit estimation for these tools is not supported in ModelBuilder. Credit consumption is calculated based on the number of input features for the tool, which cannot be reliably determined in a model before the model is run because some tools in the model may perform spatial operations in which the number of output features is unknown until the tool run is complete. If you know the number of inputs for a tool, you can calculate an estimate for the tool run using the credit consumption rates. For information about credit consumption rates for premium tools, see Understand credits for spatial analysis.
The following table provides examples of how many credits are consumed in different scenarios:
Scenario Credit charges
An analysis session is connected for 3 minutes. Charged for 10 minutes
An analysis session is connected for 15 minutes before the internet disconnects. Charged for 15 minutes
An analysis session is connected and active for 5 minutes, and inactive for 30 minutes before disconnecting. Charged for 35 minutes
An analysis session is connected for 12 minutes. A premium tool is run in the model. Charged for 12 minutes, plus credits for running the premium tool
