ModelBuilder FAQ
What capabilities are available for the beta release of raster tools in ModelBuilder?
Can the output of a model tool be published as a hosted layer?
Can I open a model created and shared by another member of my organization?
Are additional credits consumed for running a tool in ModelBuilder?
How do I disconnect from an analysis session when I can't click the Disconnect button?
What happens to my analysis session if my internet disconnects?
What is ModelBuilder in Map Viewer?
ModelBuilder is an interactive canvas for building analysis workflows using the analysis tools available in Map Viewer. Models are created by chaining together data and analysis tools into workflows in which the output of one tool becomes the input for another tool. These workflows can range from routine data management tasks to complex spatial analysis. Models streamline an analysis by enabling iterative workflow runs, automating multistep processes, and documenting workflows.
How can I access ModelBuilder?
To access ModelBuilder, you must have an ArcGIS organizational account with the following requirements:
User type—Professional or Professional Plus
Role—Publisher, Facilitator, Administrator, or a custom role with privileges to create, update, and delete content; publish hosted feature layers; and perform analysis
Credits—A minimum of 30 credits available for your account
Learn more about licensing requirements for ModelBuilder
Why is the ModelBuilder tab missing from the Analysis pane?
If the ModelBuilder tab is missing, it may mean you do not have the licensing requirements to use ModelBuilder.
Which tools are available to use in ModelBuilder?
The following feature analysis tools are currently supported: Aggregate Points, Calculate Composite Index, Calculate Density, Calculate Field, Create Buffers, Create Viewshed, Create Watersheds, Dissolve Boundaries, Enrich Layer, Filter by Attributes, Find Centroids, Find Hot Spots, Find Outliers, Find Point Clusters, Find Similar Locations, Generate Tessellations, Generate Travel Areas, Interpolate Points, Join Features, Merge Layers, Overlay Layers, Plan Routes, Summarize Center and Dispersion, Summarize Nearby, Summarize Within, and Trace Downstream.
Enrich Layer, Generate Travel Areas, and Plan Routes are premium tools. Premium tools require additional privileges and consume additional credits when run in a model.
The following raster analysis tools are currently supported in beta: Aggregate Multidimensional Raster, Convert Feature to Raster, Convert Raster to Feature, Derive Continuous Flow, Derive Stream as Line, Fill, Flow Accumulation, Flow Direction, Optimal Path as Line, Optimal Region Connections, Sample, Watershed, Zonal Statistics, and Zonal Statistics as Table.
The following analysis tools are not currently supported to add to a model: 80-20 Analysis, Calculate Density (raster analysis), Calculate Travel Cost, Choose Best Facilities, Classify Objects Using Deep Learning, Classify Pixels Using Deep Learning, Derive Stream as Raster, Detect Change Using Deep Learning, Detect Image Anomalies, Detect Objects Using Deep Learning, Detect Target Using Spectra, Distance Accumulation, Distance Allocation, Extract Data, Find Argument Statistics, Find by Attributes and Locations, Find Closest, Flow Distance, Generate Trend Raster, Geodesic Viewshed, Geomorphon Landforms, Interpolate Points (raster analysis), Locate Regions, Multidimensional Principal Components, Nibble, Optimal Path as Raster, Predict Using Trend Raster, Resample Library Spectra, Stream Link, Summarize Categorical Raster, Surface Parameters, Tabulate Area, and Zonal Geometry as Table.
Summarize Nearby and Enrich Layer do not support using a travel mode when run from a model. Find Hot Spots and Find Outliers do not support using Esri population data.
What are premium tools?
Premium tools are analysis tools that require additional privileges and charge additional credits when run in ModelBuilder or as a custom web tool. The following premium tools are currently supported in ModelBuilder:
The following icon on a tool element indicates a premium tool: ![]()
The privileges to run premium tools are included in the default Publisher, Facilitator, and Administrator roles. If your user account is licensed using a custom role and does not include the required privileges to access premium tools, the premium tools will not be available for you to add to a model. Shared models and custom web tools that include premium tools will be available to open, but the premium tools will fail to run if you do not have the required privileges.
Can custom web tools be added to a model?
No, custom web tools cannot currently be added to a model. Support for adding a custom web tool to a model will be available in a future release.
Can I add raster analysis tools to a model?
Yes. Raster analysis in ModelBuilder is currently in beta.
If you do not see raster analysis tools in ModelBuilder, it may mean that you do not have the licensing requirements to perform raster analysis or your organization has blocked apps in beta programs.
To unblock apps in beta programs, the ArcGIS administrator must turn off Block Esri apps and capabilities while they are in beta by clicking Organization > Settings > Security > Apps.
Learn more about app security settings
Can I add raster functions to a model?
No, raster functions cannot be added to a model. The Raster Function Editor is a visual programming interface for building imagery and raster function templates similar to ModelBuilder.
The beta release of raster analysis in ModelBuilder includes the following:
A subset of raster analysis tools and support for raster layer input variables.
Support for chaining raster and feature analysis tools in the same model.
Support for running models in a standard analysis session or using a raster optimized analysis session for large raster analysis workflows that benefit from parallel processing.
Models with raster analysis tools cannot currently be published as web tools.
Can I schedule a model run?
No. Running models as web tools on a schedule is planned for a future update.
What types of data can I add to a model?
Feature layers, raster layers (beta), and hosted tables can be used as input data in a model. For a complete list of supported data, see Build models.
Can I add ArcGIS Living Atlas layers to a model?
Yes, ArcGIS Living Atlas feature layers are supported.
Learn more about adding data to a model
What is intermediate data in a model?
Intermediate data in ModelBuilder refers to temporary data created by the tools as the model runs. These outputs do not publish a hosted service, thereby reducing model run time. Intermediate data cannot be saved or visualized on the map and is solely intended to be used as inputs to other tools in the model.
Learn more about intermediate data
Yes. By default, each tool in the model generates intermediate data. You can create a hosted output by choosing Create hosted layer or Overwrite existing layer for the Result type parameter on the tool dialog box.
Learn more about model outputs
Is it possible to overwrite an existing model output layer?
Yes. You can overwrite an existing result layer by choosing Overwrite existing layer as the result type, or by choosing Create hosted layer and selecting If a layer exists with the same name, automatically overwrite it.
Can I share a model?
Yes. Sharing models with groups, the organization, or the public is supported.
Learn more about sharing models
Can I publish a model?
Yes, models can be published to create a hosted tool item that can be run as a custom web tool.
Learn more about publishing a model
Yes. Users with access to ModelBuilder can open models that have been shared with them. The shared models are opened in view-only mode and can be copied and made active to allow editing and running the model.
Can a model be opened in a different web map?
Yes, model items that you own or that have been shared with you can be opened in a web map.
Learn more about opening models
Can a web map with a model added be deleted?
Yes, a web map with a model can be deleted. The analysis model item will still be available in Content and can be added to other web maps.
Can administrators access and delete models they don't own?
Yes. Organization administrators can open, modify, and delete all models in their organization.
Does ModelBuilder charge credits when used in Map Viewer?
Yes, credits are consumed when you connect to an analysis session. A connected analysis session is required to create, edit, and run a model. Additional credits are charged when running premium tools.
Learn more about credits in ModelBuilder
In addition to the model session cost, premium tools also consume credits at the same rate as the tools run from the tool pane. Credit estimation for these tools is not supported in ModelBuilder. Credit consumption is calculated based on the number of input features for the tool, which cannot be reliably determined in a model before the model is run because some tools in the model may perform spatial operations in which the number of output features is unknown until the tool run is complete. If you know the number of inputs for a tool, you can calculate an estimate for the tool run using the credit consumption rates. For information about credit consumption rates for premium tools, see Understand credits for spatial analysis.
Are credits charged to view a model?
No, you do not need to pay credits to view a model. You can browse and view existing models in view-only mode without connecting to an analysis session. Editing a diagram or tools is not supported in view-only mode.
Can I edit a model without starting an analysis session?
No. A connected analysis session is required to edit a model.
An analysis session can be disconnected by closing or refreshing the browser. This may be necessary in situations in which you cannot click the Disconnect button, such as if a model run is taking a long time to cancel.
The analysis session disconnects and model runs are canceled if your internet connection is lost.
If your internet reconnects and you are still logged in to Map Viewer, you can click Save as
to save a copy of the model. Pending edits are lost if the browser is refreshed, the model is made active, or you are logged out of Map Viewer.
How is ModelBuilder different from ArcGIS Data Pipelines?
ModelBuilder and ArcGIS Data Pipelines are similar in that they both offer a no code, visual user experience for authoring repeatable workflows on the web. Key differences include the following:
ModelBuilder automates analysis workflows using analysis tools in Map Viewer. Data Pipelines automates data integration and preparation workflows, and includes several focused tools that clean, format, and prepare data for visualization and downstream analysis.
ModelBuilder supports feature layers, raster layers (beta), and tables. Data Pipelines supports vector and tabular data. You can also connect to a range of external data sources using Data Pipelines, including Amazon S3, Google BigQuery, Snowflake, feature layers, and uploaded local files, among others.
ModelBuilder is a capability included in Map Viewer and integrated into Map Viewer analysis. Data Pipelines is an ArcGIS app that is used independently from Map Viewer.
