Dissolve Boundaries
The Dissolve Boundaries tool finds polygons that overlap or share a common boundary and merges them to form a single polygon.
The output is a hosted feature layer.
Example
A GIS analyst requires a layer that maps the districts in the Kyushu region of Japan. However, the analyst only has a layer of Kyushu municipalities. Dissolve Boundaries can be used to create a layer of districts using the municipality layer.
Dissolved Boundaries for municipalities in Kyushu, Japan
The first image shows the input features (Kyushu Municipalities). The second image shows the output feature layer with the dissolved boundaries.
Try the Dissolve boundaries tutorial for the complete workflow.
Usage notes
Dissolve Boundaries includes configurations for input features, dissolve settings, and a result layer.
Input features
The Input features group includes the Input features parameter, which specifies the polygon features to be dissolved.
For feature inputs, a count of features is displayed below the layer name. The count includes all features in the layer, except features that have been removed using a filter. If a processing extent is specified, only features within that extent are included in the count.
Dissolve settings
The Dissolve settings group includes the following parameters:
  • Dissolve features with matching field values determines whether the tool dissolves only the polygons that overlap or share a common border and have the same field value (enabled) or all the polygons that overlap or share a common border (disabled).
  • Fields to match specifies the field that will be used to dissolve polygons based on matching values.
    Matching values are case sensitive.
  • Create multipart features determines whether the output can contain multipart polygon features, meaning multiple polygons defined as a single feature (enabled), or can only contain individual features (disabled).
  • Calculate statistics for dissolved features determines whether to calculate statistics for dissolved boundaries. If enabled, choose a number field from the input layer to summarize and the statistics to calculate for the field.
  • Summary statistics determines which number fields from the input polygon layer to summarize. Supported summary statistics include sum, minimum, maximum, mean, and standard deviation. The statistics are calculated for each boundary separately.
    Learn more about summary statistics
Dissolve features with matching field values is not available when running the tool in ModelBuilder. Instead, use Fields to match to specify the fields to dissolve. Calculate statistics for dissolved features is also not available in ModelBuilder. Instead, use Summary statistics when Create multipart features is enabled.
Result layer
The Result layer group includes the following parameters:
  • Output name specifies the name of the layer that is created and displayed. The name must be unique. If a layer with the same name already exists in your organization, the tool will fail, and you will be prompted to use a different name.
  • Save in folder specifies the name of a folder in My content where the result will be saved.
Limitations
Inputs must be a polygon layer. Lines and points cannot be dissolved within boundaries using the Dissolve Boundaries tool.
Environments
Analysis environment settings are additional parameters that affect a tool's results. You can access the tool's analysis environment settings from the Environment settings parameter group.
This tool honors the following analysis environments:
Credits
This tool consumes credits when run from the tool pane. Credits are consumed when connecting to an analysis session in ModelBuilder, but no additional credits are consumed when running this tool.
Use Estimate credits to calculate the number of credits that will be required to run the tool. For more information, see Understand credits for spatial analysis.
Outputs
Dissolve Boundaries creates an output hosted feature layer with the dissolved polygon features. Depending on the tool configurations, the polygon layer includes fields with the following information:
  • Count of polygons
  • Area
Licensing requirements
This tool requires the following user type and configurations:
  • Creator, Professional, or Professional Plus user type
  • Publisher, Facilitator, or Administrator role, or an equivalent custom role
Resources
Use the following resources to learn more:
