Perform analysis in Map Viewer
This topic describes analysis using Map Viewer. For information about using analysis tools in Scene Viewer, visit Perform analysis in Scene Viewer.
When you look at a map, you may start turning that map into information by finding patterns, assessing trends, or making decisions. This process is called spatial analysis.
Some patterns and relationships aren't obvious by looking at a map. There may be too much data to go through to present coherently on a map. The way you display data on a map can change the patterns you see. Spatial analysis tools and functions allow you to quantify patterns and relationships in the data and display the results as maps, tables, and charts. Using spatial analysis tools and functions, you can answer questions and make decisions using more than a visual analysis.
Tip:
Visit the tutorial gallery for tutorials that use spatial analysis in Map Viewer.
Feature analysis
Feature analysis is performed on vector data sources, which is coordinate-based data that represents geographic features using points, lines, and polygons.
Feature analysis can be used to summarize features based on geographic location, measure distances around or between features, and quantify spatial patterns.
Feature analysis tools are identified in the Tools pane by the feature tool icon
If you're a developer, you can access these tools through the ArcGIS REST API Spatial Analysis service and the ArcGIS API for Python arcgis.features.analysis module.
Raster analysis
Raster data consists of a matrix of cells (or pixels) organized into rows and columns (or a grid) where each cell contains a value representing information, such as temperature or elevation. Rasters can be digital aerial photographs, satellite imagery, digital pictures, or scanned maps.
Imagery and raster data contains information that can be used to identify patterns, find features, and understand change across landscapes. To extract information from imagery, you can process or analyze the data. For example, you can calculate a vegetation index to get an understanding of vegetation coverage from a multiband image or find suitable locations to build solar power plants using statewide elevation and land cover raster data.
Raster analysis can be performed by tools that are identified in the Tools pane by the raster tool icon
and by raster functions that are identified by the raster function icon
Raster analysis may fail to run if your ArcGIS organization does not have at least one feature layer and one imagery layer published.
If you're a developer, you can access these tools through the ArcGIS REST API Raster Analysis service and the ArcGIS API for Python arcgis.raster.analytics module and arcgis.raster.functions.gbl module.
Access analysis
To access and use analysis tools and functions in Map Viewer, complete the following steps:
Confirm that you are signed in to your ArcGIS organization and that you have the required privileges to perform analysis.
In Map Viewer, open the map containing the layers you want to analyze or add the layers directly. Optionally, browse for layers when you update the input parameters.
On the Settings (light) toolbar, click Analysis
.Note:
If you do not see the Analysis button, contact your organization administrator. You may not have the privileges or credits required to perform analysis, or your ArcGIS organization may not have any hosted feature layers (required to enable analysis).
For more information, see FAQ: Why don't I see the Analysis button in Map Viewer in Esri Community.
Do one of the following:
Click Tools
to open the analysis tools.Click Raster Functions
to open the raster functions.
Click a category to expand it.
Alternatively, use the search box to search by name or keyword.
Choose a tool or function.
The tool pane appears with the input parameters.
Click the Layer button for the input parameters to select an input layer. If the input layer has not been added to the map, do the following:
Click Browse layers.
The Select layer window appears showing layers from My content.
Click My content, and choose a different option from the menu (for example, My groups or My organization) if necessary.
Use the Search bar or Sort by menu to reduce the number of layers, or reorder the layers if necessary.
On the desired item, click Select layer, and choose a layer from the menu.
Click Confirm or Confirm and add to map.
Update the remaining parameters, including naming the output layers, and updating any required configurations.
Tip:
Click the help button
next to a parameter to view the help. You can also click Learn more to open the help topic.Click Environment settings to view and update the environments that are used during the processing.
Click Estimate credits to calculate the number of credits that will be consumed during analysis.
Click Run.
The analysis runs and the output datasets are added to the web map. Information about the operation, including unsuccessful runs, is added to the analysis history for the web map.
Supported data
One or more input datasets are required for analysis. Some tools and functions only work with certain data types. For example, Aggregate Points requires an input layer containing point features, and the Aggregate Multidimensional Raster tool requires a multidimensional imagery layer.
The following data types are supported for feature inputs:
Feature services
Hosted feature layers, including individual subtype sublayers from subtype group layers
Map Service layers
Sketch layers
Tables
The following data types are supported for raster inputs:
Image services
Hosted imagery layers
Deep learning package files (
.dlpk)
Limitations
Feature services, map services, and image services must be publicly accessible; that is, the URL to the service must be a public URL, not one only accessible behind a firewall.
Subtype group layers and subtype sublayers are not supported as inputs in analysis settings.
Domain descriptions and subtypes are not maintained in analysis results.
Attachments from the input layers will not be included in the output layer.
Some analysis tool parameters do not support DateOnly and TimeOnly field types. TimestampOffset fields cannot be used in analysis. If an input layer includes these field types, they will not be available in parameters in which analysis fields are chosen.
Some tools do not support high-precision date fields. Inputs with high precision may result in output fields with fractional seconds or milliseconds removed.
Renaming a sketch layer will break existing references to the layer made by previous tool runs. The input layer will show an error if the tool pane is reopened from the analysis history.
Curve segments (Bezier, tangent, arc, and endpoint) are not available for sketch layers when drawn from an analysis tool pane.
Parquet feature layers are not supported for analysis.
Analysis outputs
Analysis results produce one or more outputs. When a tool or function runs successfully, the output will be added to the Layers pane. When the analysis produces a table output, it will be added to the Tables pane. The results can also be accessed from the analysis history on the Results tab of the analysis details.
The Extract Data tool doesn't add results to the Layers pane. Instead, the extracted files will be saved as items in your contents.
Output names cannot begin or end with a space and cannot include the following special characters: [, ], (, ), -, <, >, #, %, :, ;, ", ?, &, +, =, |, /, \, *, or @
Layer names must be unique within an organization. If a layer with the same name as the output name for a tool already exists, including in the recycling bin, you will receive an error message. To resolve the error, specify a different output name or delete the layer permanently.
