Licensing requirements for spatial analysis
The organization administrator must grant you the required privileges to perform analysis. You must have the privileges to create, update, and delete content; publish hosted feature layers; and perform spatial analysis.
The required privileges for feature analysis are available through the following user types and roles:
  • Creator, Professional, or Professional Plus user type
  • Publisher, Facilitator, or Administrator role, or an equivalent custom role
Raster analysis tools and raster functions require a Professional or Professional Plus user type and the Imagery Analysis privilege. To run raster analysis, your ArcGIS Online organization must have at least one feature layer and one imagery layer published.
Additional privileges may be required for some tools. The tables below summarize the licensing requirements for all tools.
Summarize data tools
The following table summarizes the licensing requirements for tools in the Summarize data category:
Tool
User type
Aggregate Points
None
Join Features
Summarize Within
Summarize Center and Dispersion
Summarize Nearby
Network Analysis (required to use travel modes)
Tabulate Area
Imagery Analysis
Zonal Geometry as Table
Zonal Statistics
Zonal Statistics as Table
Find locations tools
The following table summarizes the licensing requirements for tools in the Find locations category:
Tool
User type
Find by Attributes and Location
None
Find Centroids
Find Similar Locations
Create Viewshed
Create Watersheds
Trace Downstream
Choose Best Facilities
Network Analysis
Locate Regions
Imagery Analysis
Enrich data tools
The following table summarizes the licensing requirements for the tool in the Enrich data category:
Tool
User type
Enrich Layer
GeoEnrichment privilege
Analyze patterns tools
The following table summarizes the licensing requirements for tools in the Analyze patterns category:
Tool
User type
80-20 Analysis
None
Calculate Density
Find Point Clusters
Interpolate Points
Calculate Composite Index
Find Hot Spots
GeoEnrichment (required to use Esri population data)
Find Outliers
Calculate Density (raster analysis)
Imagery Analysis
Interpolate Points (raster analysis)
Use proximity tools
The following table summarizes the licensing requirements for tools in the Use proximity category:
Tool
User type
Create Buffers
None
Distance Accumulation
Imagery Analysis
Distance Allocation
Optimal Path as Line
Optimal Path as Raster
Optimal Region Connections
Generate Travel Areas
Network Analysis
Plan Routes
Find Closest
Calculate Travel Cost
Manage data tools
The following table summarizes the licensing requirements for tools in the Manage data category:
Tool
User type
Convert Feature to Raster
Imagery Analysis
Convert Raster to Feature
Nibble
Sample
Dissolve Boundaries
None
Extract Data
Generate Tessellations
Merge Layers
Overlay Layers
Analyze terrain tools
The following table summarizes the licensing requirements for tools in the Analyze terrain category:
Tool
User type
Derive Continuous Flow
Imagery Analysis
Derive Stream As Line
Derive Stream As Raster
Fill
Flow Accumulation
Flow Direction
Flow Distance
Geodesic Viewshed
Geomorphon Landforms
Stream Link
Surface Parameters
Watershed
Use deep learning tools
The following table summarizes the licensing requirements for tools in the Use deep learning category:
Tool
User type
Classify Objects Using Deep Learning
Imagery Analysis
Classify Pixels Using Deep Learning
Detect Change Using Deep Learning
Detect Objects Using Deep Learning
Use multidimensional analysis tools
The following table summarizes the licensing requirements for tools in the Use multidimensional analysis category:
Tool
User type
Aggregate Multidimensional Raster
Imagery Analysis
Find Argument Statistics
Generate Multidimensional Anomaly
Generate Trend Raster
Multidimensional Principal Components
Predict Using Trend Raster
Summarize Categorical Raster
Use spectral analysis
The following table summarizes the licensing requirements for tools in the Use spectral analysis category:
Tool
User type
Detect Target Using Spectra
Imagery Analysis
Resample Library Spectra
Detect Image Anomalies
Custom web tools
Custom web tools require the same user type and privileges as spatial analysis.
Custom web tools published from ArcGIS Notebooks and ModelBuilder also require the Run web tools privilege and any privileges required to run the individual tools in the notebook. The Run web tools privilege is included with the Administrator role.
Custom web tools created in Notebooks and ModelBuilder are hosted as Tool items.
Learn more about custom web tools
Resources
Use the following resources to learn more:
