Use custom web tools
Custom web tools are geoprocessing workflows that are published and hosted in your ArcGIS organization. Custom web tools can be added to supported apps, such as Map Viewer and Scene Viewer, and run from the Analysis pane.
Types of custom web tools
Custom web tools include the following item types:
Tool items
published from ArcGIS Notebooks or ModelBuilderGeoprocessing Service items
published from ArcGIS Pro to ArcGIS Enterprise and added to ArcGIS Online with a URL reference
Open and run custom web tools
Custom web tools can be opened and run in Map Viewer or Scene Viewer.
To access and use custom web tools, complete the following steps:
Open the Analysis pane by doing one of the following:
In Map Viewer, on the Settings (light) toolbar, click Analysis
.In Scene Viewer, on the Designer (dark) toolbar, click Analysis
If you do not see the Analysis button, contact your organization administrator. You may not have the privileges or credits required to perform analysis, or your ArcGIS organization may not have any hosted feature layers (required to enable analysis).
For more information, see FAQ: Why don't I see the Analysis button in Map Viewer in Esri Community.
Click Tools
.Click Open custom web tool.
The Browse custom web tools window appears. By default, the window shows the custom web tools available in My content.
Optionally, click My content, and choose My favorites, My groups, My organization, Living Atlas, or ArcGIS Online from the menu to change the source of the items.
Optionally, use the Search bar and Sort by menu to reduce the number of items or reorder the items.
On the desired item, click Select task, and choose a task from the menu.
An item may have multiple tasks associated with it.
You can also click the item to view the item details in a side pane.
Click Confirm.
The custom web tool opens in the Analysis pane.
Custom web tools published from notebooks will not be available if your organization administrator has added ArcGIS Notebooks to the organization's blocked apps.
Update the tool parameters.
Required parameters are marked with a red dot.
Tip:
Click the help button next to a parameter to view the help if available.
Click Environment settings to view and update the environments that are used during the processing.
Environment settings are not currently available for custom web tools published from ModelBuilder.
Click Validate if necessary.
If validation returns errors or warnings, use the inline messages to resolve the issues and re-validate.
The Validate button is only available for geoprocessing services. Web tools published from ArcGIS Notebooks or ModelBuilder do not support the Validate button.
Click Run.
Raster analysis may fail to run if your ArcGIS organization does not have at least one feature layer and one imagery layer published.
Limitations
Custom web tools published from ArcGIS Notebooks and ModelBuilder cannot be shared using the Everyone (public) option.
ArcGIS Pro does not support publishing custom web tools directly to ArcGIS Online. To make geoprocessing services available in ArcGIS Online, you must publish the service to ArcGIS Enterprise and then add an ArcGIS Online item using the service URL.
Result layers for web tools published from analysis models may not be added to the map if the web tool run has one or more tool failures. Some hosted outputs may still be created and saved in My content.
The Validate button is only available for Geoprocessing Service items with the Validate capability enabled upon publishing.
Validation does not currently update domains, filters, or conditional parameters.
Credits
Custom web tools published from ArcGIS Notebooks and ModelBuilder consume credits. Credits are consumed based on the time used to run the custom web tool and the number of credits required for each analysis tool in the notebook or analysis model. For analysis models, only premium tools consume credits.
For web tools published from ModelBuilder, the number of credits consumed is reported in the analysis history. Credit consumption is based on two separate rates as follows:
Run duration—The number of credits consumed based on the run time for the tool. Credits are consumed at a rate of 70 credits per hour, calculated by minute with no minimum run time.
Utility services—The number of credits consumed by ArcGIS Online utility services, such as ArcGIS GeoEnrichment Service and ArcGIS Online routing services. Utility services are used by premium tools.
For more information, visit Understand credits for spatial analysis.
Outputs
Custom web tool outputs vary by tool. For information about the outputs for a specific custom web tool, see the tool description or contact the tool owner.
Some custom web tools create temporary output layers, such as feature collections, as part of their workflow. Temporary layers are only available in the web map where the layers were created until the map is closed, unless the layers are saved to create a hosted layer. The temporary layers will be permanently deleted if the web map is closed without saving the layers. Saving the web map will not save temporary layers.
Temporary layers are not currently supported as outputs in Scene Viewer.
Editing layers is not available for temporary layers. You can save the temporary layer to create a hosted feature layer to enable editing on the layer.
Temporary layers cannot be saved as part of a group layer item. If a custom web tool creates a temporary layer as part of a group layer, you can do one of the following:
Save the temporary layer individually before saving the group layer. The temporary layer will be replaced by a hosted feature layer when it is saved.
Ungroup the group layer or move the temporary layer out of the group and save the temporary layer individually. The temporary layer will be persisted in the web map once it has been saved and replaced with a hosted feature layer.
Temporary layers are indicated in the Layers pane using the following icon:
Save a temporary layer
To save a temporary layer, complete the following steps:
On the Contents (dark) toolbar, click Layers
if the Layers pane is not open.In the Layers pane, click Options
next to the layer you want to save, and click Save as
.Tip:
You can also save the layer by clicking Properties
, expanding the Information section, and clicking Save as
.Provide the following information for the new item:
A title
A folder in My content where you want to save the layer
Categories, if your organization has set up content categories to help people find the layer
Tags and a summary that describe the layer
Click Save.
The current layer properties are saved to a new item in My content. The new item becomes the source for the layer in the map.
Licensing requirements
Custom web tools require the following licensing and configurations:
Creator, Professional, or Professional Plus user type
Publisher, Facilitator, or Administrator role, or an equivalent custom role
Premium content: Run web tools privilege (required for Tool items)
Additional privileges may be required to run custom web tools published from Notebooks and ModelBuilder depending on which analysis tools are included in the notebook or model. For information about the privileges required to run an analysis tool, see Licensing requirements for spatial analysis.
Validation
Web tool validation allows you to check your input configurations before you run a web tool, reducing the likelihood of tool failures.
Validation results will be returned in one of the following states:
Errors—One or more configurations is invalid. Resolve the errors based on the inline messages and revalidate the tool.
Warnings—One or more configurations has associated warnings that may impact the web tool's results or your ability to run the tool successfully. Review the warnings and fix the issues, if necessary, and then revalidate. If the warnings do not require fixes, you can run the tool.
Informative messages—One or more configurations returned information messages. These messages are informative and should not impact your ability to run the tool, but may impact the results. Review the messages before running the tool.
Success—Continue to run the tool.
For more information, visit Validate a task in the ArcGIS REST API.
Troubleshooting
Use the sections below to troubleshoot potential issues when adding or running custom web tools.
Custom web tool fails to open
Custom web tools may fail to open in the following situations:
If a custom web tool fails to open from the Browse custom web tools window, the tool may be temporarily unavailable.
If a custom web tool fails to open from the tool history, the tool item may have been deleted or you no longer have permission to use the tool (for example, the item is no longer shared). Contact the tool owner for information about the tool status.
Unsupported parameter type
Some parameter types are not currently supported for custom web tools. If an unsupported parameter is marked as required and no default is set, the tool cannot be run. The following parameter types are not currently supported:
GPMultivalue:GPComposite
GPMultivalue:GPBoolean
GPMultivalue:GPDataFile
GPMultivalue:GPRasterDataLayer
Unsupported parameter configuration
Parameters using the GPValueTable parameter type do not support empty or duplicate parameter names. If an empty or duplicate name is used, the parameters will not be available in the web tool. Contact the tool owner to update the empty or duplicate parameter names.
Some parameter types, such as GPLinearUnit and GPDataFile, do not support default values stored as strings. If a string is used as the default, the value will be ignored and the tool pane will show no default value.
Unsupported output parameter configuration
Some web tools may be configured to create outputs that are not supported in Map Viewer, such as layers nested within GPValueTable results. These output layers will not be added to the web map when the web tools is run. Depending on the output type, the results may have been generated and saved in your content.
Custom web tools with no input parameters
Some custom web tools may not have input parameters. Custom web tools without input parameters have been configured to use a default input dataset and parameters that cannot be configured. Environment settings, such as Processing extent, can be used to customize the output of the tool. For information about the tool inputs and parameters, review the description on the item page or contact the item owner.
Parameters not repopulated when opened from history
Tool runs can be reopened from the analysis history. If a custom web tool has been updated since the tool was run, some parameters may not be repopulated to match the settings used when the tool was run. Updated parameters will not be populated in the following cases:
A parameter is added
A parameter is deleted
A parameter name is changed
A parameter type is changed
Resources
Use the following resources to learn more:
