Create apps from maps
You can create a web app with a map using a variety of app builders. You can choose an app template with minimal to no configuration required or use one of the available builders to customize an app before publishing. Each of these options offers various functionality, such as query and edit tools, social media feeds, side-by-side map viewers, and layouts and color schemes.
Your organization may have specified brand colors or a logo to apply to apps created by members of your organization. When you create an app that supports these Shared theme settings, the specified settings will be applied instead of the default theme of the app.
When a published web app is based on a map, any changes made to the map, including its extent, layers, description, and so on, are reflected in the web app. If a map that was available to everyone in the organization is made private (or deleted), the map no longer appears in the app.
Tip:
To share an app publicly that contains subscriber content, you can configure it to allow access to the content through your organizational subscription. Your subscription will incur any credit costs. To determine how a specific app builder handles subscriber content, refer to the respective app documentation.
To create a web app from a map, use one of the following methods:
On the Content page, click Create app.
On the web map item page, click Create app.
In Map Viewer, open the web map and click Create app
on the Contents (dark) toolbar.
The following table lists which app builder is available for each method:
App builder |
Map Viewer |
Item page |
Content page |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
No |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
Yes |
All app builders require an organizational account.
Create an app from the Content page
Complete the following steps to create an app from the Content page:
Verify that you are signed in with the privileges to create content, and have access to the app builder you are using.
At the top of the site, click Content and click the My content tab.
Click Create app and choose an app builder.
Depending on your choice of app builder, do the following:
For the app builders listed below, you are taken directly to the app builder and can begin creating your app.
Follow your respective app builder's steps about configuring and publishing an app.
Tip:
To make your app accessible to others, share it.
