Schedule a notebook task
You can create tasks to schedule the automated run of a notebook. Each time the notebook is run according to the schedule you set, the site opens a new container and runs the notebook without you needing to open the notebook.
In the Tasks pane in the notebook editor, you can create one or multiple scheduled tasks to run the notebook. You can schedule it to run once in the future or on a recurring basis. If you are preparing a notebook for an automated run, such as on a recurring basis, consider the following:
You can only create tasks for notebook items that you own. Use the Manage notebook tasks window to view and manage tasks.
You can have a maximum of 10 active tasks across all your notebooks. Pause or delete active tasks if you have 10 active tasks and want to run more
The maximum frequency a scheduled task can run is every 15 minutes.
If a notebook with scheduled tasks is deleted or sent to the recycle bin, the tasks are deleted permanently and cannot be restored.
If you are an organization administrator, consider the following:
Administrators can view and edit tasks for all notebook items in the organization.
The organization can have up to 50 active notebook tasks at any given time. Pause or delete active tasks if you have 50 active tasks and want to run more.
Prepare the notebook
You can configure input and output parameters for a notebook. Input parameters correspond to input variables in a notebook that you want to externalize for a scheduled task. When a scheduled task runs, input parameters are inserted into the notebook at the top of the notebook, similar to global variables. This allows you to author generic notebooks and modify the values for input variables at run time.
Task parameters are inserted by default into a cell at the beginning of a notebook. Alternatively, click View > Activate Command Palette in the menu and search for and open Edit Notebook Metadata, which allows you to edit cell and notebook metadata to create a tag for a cell named injected-parameters. Task parameters are inserted into the cell that follows the injected-parameters tag.
Considerations for content
Other than the parameters cell it can insert, scheduling a notebook does not support user interaction with notebooks. Avoid adding content that requires user interaction while the notebook runs, such as clicking a point on a map.
Any credentials or new variables you want added at the time of an automated run must be inserted in the parameters cell, as indicated above. Ensure that the notebook does not contain content that will stop the notebook from completing.
When authoring notebooks, use full paths to directories and files in the workspace directory.
For example, use /arcgis/home/test.gdb instead of home/test.gdb.
Create a task
When the notebook is ready, you can create a task to schedule its run. Using the Tasks pane in the notebook editor, you can create one or multiple tasks to automate runs of the notebook and specify the task's schedule.
To create a task, complete the following steps:
Verify that you are signed in with privileges to create and schedule notebooks.
Save the notebook with a title if you haven't already.
The Tasks button becomes available on the top ribbon of the notebook editor.
On the top ribbon of the notebook editor, click Tasks.
Click Create task to open the dialog box.
You can also create tasks from the Tasks tab on the notebook's item page.
Provide a title in the Title text box to describe the task schedule, such as Weekly data cleaning run.
If you have not configured parameters for the notebook and there are parameters you want to add to the notebook when it is run by the task, provide them in the Parameters section, and click Add to include the parameter in the workflow.
Provide a key in the Key setting and its paired value in the Value setting for each parameter.
Click Next.
On the Set task schedule details page, specify the schedule for the task.
The schedule you specify is stored based on your web browser's local time zone.
Tip:
When you change the value for Repeat type, the options below it change to fit that selection. For example, if you select Month, a Day of the month box appears, allowing you to specify a day of the month or range of days for the task to run.
Task start times are approximate and may differ from the scheduled time depending on system capacity.
Optionally, expand the Advanced section to do any of the following:
Enter the maximum number of minutes that the task can run.
Turn on the Use workspace toggle button if the notebook you want to schedule reads or creates files in the workspace directory (
/arcgis/home).Note:
With the Use workspace toggle button turned off for a notebook task, you can still write files during a task run. However, the written files will only be retained in a temporary location for the duration of the run and will be removed once the run is complete.
If you added parameters, turn on the Save parameters to notebook toggle button to save the inserted cell with the new parameters to the notebook when it is run.
Turn on the Update notebook on completion toggle button to update the notebook with the results of each run.
When you are satisfied with the title, optional parameters, and task schedule, click Create Task.
The task is active and runs the notebook according to the schedule you set.
For multiple schedules, you can create more tasks for the notebook using the same workflow. You can have a maximum of 10 active tasks across all your notebooks. Pause or delete active tasks if you have 10 active tasks and want to schedule more.
Work with existing tasks
Once you create a task for a notebook, you can view the task's details and edit or delete it at any time. You can make changes to tasks either in the Tasks pane of the notebook editor or on the Tasks tab of the notebook's item page. In both places, you can view all tasks for the notebook with the time each task was created, when it was last modified, and its current status.
To work with existing tasks, complete the following steps:
Verify that you are signed in with privileges to create notebooks.
From the top ribbon of the notebook editor, click Tasks.
In the Scheduled Tasks section, find the task that you want to work with.
Click Actions
next to the task and do any of the following:Click Details to view the details and status of each run of the task. To view the run results, click the Results button. A task's status can be one of the following:
Succeeded—The task completed successfully.
Executing—The task is currently running.
Failed—The task failed to run successfully. If a task fails five times, it is completely stopped.
Skipped—The task was skipped because a previous run was still running.
Click Edit to change the title, parameters, or schedule of the task.
Click Pause to pause an active task, and click Resume to resume the task.
Click Delete to remove the task.
Deleting a task also deletes the run history of the task. To preserve an active task's history, consider pausing the task to stop further runs.
Changing ownership of a notebook also changes the ownership of that notebook's tasks. The tasks are transferred to the new user in an inactive state. The new owner can enable the tasks in the Tasks pane of the notebook editor or on the Tasks tab of the notebook's item page.
